Old 08-04-2017, 05:53 PM #1
Difflock's Avatar
Difflock Difflock is offline
Real Name: Stu
Difflock is on a distinguished road
Difflock's Avatar
Real Name: Stu
Steering rack bushings bad
Redid my upper lower balljoints, inner outer tie rods and sway bar links the other day then limped it to the alignment shop for an alignment and they say my steering rack bushings are bad. It drives true now but the wheel is at like a 30 degree angle to drive true, the shop quoted me 400 bucks for bew bushings and instal and another alignment after wards, whats my best option here, Do it my self for 30 bucks and get them to do the alignment or just let em have it for the 400 bucks? Is it a PITA? Anyone have a write up for them? 1996 sr5
Difflock is offline   Reply With QuoteReply With Quote
Old 08-04-2017, 06:08 PM #2
tystaco's Avatar
tystaco tystaco is offline
Real Name: Tyler
tystaco is on a distinguished road
tystaco's Avatar
Real Name: Tyler
Do it yourself. It isn't that bad. The worst part is getting on the upper steering rack bolt and slipping the rack around, but if you have a second set of hands it isn't that bad...but you can do it solo for sure. Check out some of Timmy the Toolman's videos on Youtube... He is a member here @mtbtim
1999 T4R Limited (Mine)
2000 T4R Limited (Wife's)
2004 Tacoma Xtra Cab TRD
tystaco is offline   Reply With QuoteReply With Quote
Old 08-04-2017, 06:13 PM #3
JayRolla's Avatar
JayRolla JayRolla is offline
JayRolla will become famous soon enough JayRolla will become famous soon enough
JayRolla's Avatar
They are not really that hard to replace. When they are bad the rack will move around and makes it very hard for them to set the toe. I would replace them and bring it back. Most places give you a free alignment within a period of time.
I also had them say the same thing to me after I already replaced my bushings. The rack bolts had just loosened up. You may just need to tighten the rack.
JayRolla is offline   Reply With QuoteReply With Quote
Old 08-04-2017, 07:12 PM #4
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
I had good luck with these:
https://wheelersoffroad.com/product/...96-02-4runner/
My favorite DIY, and it still has PICS!!!!
https://forum.ih8mud.com/threads/ste...6/#post5867828
Here is another one:
http://www.parksoffroad.com/tacomamo...ckbushings.htm
$22 + alignment vs. $400. DIY!!!!
My Backyard Frame Swap
Old 08-04-2017, 07:32 PM #5
JRZEE2000TR4LTD's Avatar
JRZEE2000TR4LTD JRZEE2000TR4LTD is offline
Real Name: John
JRZEE2000TR4LTD will become famous soon enough JRZEE2000TR4LTD will become famous soon enough
Real Name: John
Did they do the alignment with known bad bushings? If so then they technically didn't do an alignment, as there's no way to dial in a solid toe setting with sloppy bushings. I mean you can on an alignment rack while the truck is not moving but as soon as the truck starts to roll and steer, it will change. No way they should double charge the alignment, IF that's what they are going to do.
Secondly, all but one of the four bushings are easy (and the bushing kits are cheap $20-30) The hardest part is getting the one bolt out that goes vertically but if you did all that other work, you shouldn't have too much of a problem doing the bushings. It's a shame because having the driver's side tie rod end disconnected makes the job significantly easier.
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
JRZEE2000TR4LTD is offline   Reply With QuoteReply With Quote
Old 08-04-2017, 08:33 PM #6
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
There are many videos on how to replace them but this one is my favorite, only due to the killer Doors remix. Plus the author uses the bottle jack in the center of the 4runner to jack it up. A little overkill with the silicone grease but it gets the job done:
https://www.youtube.com/watch?v=4lSj8WMKfEs
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 08-04-2017, 11:06 PM #7
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
I haven't watched the DIY vids, this is how I do it.
Remove power steering hard line mounts, two of them.
Remove driver side OTE, remove all rack mounting bolts.
Doing the above gives you enough room between rack and frame to use 1/2" all thread with various 1/2" drive sockets as a puller and pusher on the worst of the bushings which is the drivers side.
A swivel head 3/8" drive ratchet makes short work of center bolt after breaker bar.
96RedRunner limited 4x4 5VZ auto not stock 374k miles totaled 2018.
2001 limited 4x4 5VZ auto work in progress.
2011 Audi S5 Prestige 4.2 V8 6 spd MT.
Old 08-05-2017, 04:00 PM #8
Difflock's Avatar
Real Name: Stu
Difflock's Avatar
Real Name: Stu
Well I was always suspecting my rack bushing were bad, all the fixed was my tie rod alignment, cause I ****ed that one up. I ordered bushing Ill throw em in and get them to align it again. They charged 30 bucks for that only so whatever really.
Steering rack bushings jonb2 4th Gen T4Rs 28 05-24-2021 04:31 PM
'98 4Runner Steering Issues: New Rack or ITRE's and Rack Bushings? TheFriZ 3rd gen T4Rs 23 04-25-2019 12:35 AM
Help with Steering Rack Bushings satek 3rd gen T4Rs 4 12-29-2012 02:21 AM
looking for steering rack bushings for '06 sr5 shakenbake688 4th Gen T4Rs 1 04-04-2012 11:07 AM
inner tie rod, steering rack & bushings Nubie4Runner 3rd gen T4Rs 3 11-19-2010 01:48 AM
