Originally Posted by phattyduck
Factory GVWR should be mostly suspension related. Remember, you can also tow 5000 lbs. while loaded to GVWR (though that is reduced by tongue weight). That means the engine/trans is rated to pull 10k+ lbs and the brakes are designed to work with over 7250 lbs (working trailer brakes are assumed for >2000 lb trailers).
You aren't voiding your warranty at this point... so do what works and feels right!
Thanks for the info!
It felt solid. Before I had the new shocks/springs, I was never able to load it with this kind of weight. Glad to know that it'll be OK!
