08-11-2017, 05:23 PM
Real Name: Minh
Real Name: Minh
Axle Ratio from 1999 SR5 v6 auto 4wd
Hi guys, new guy here. I did a lot of searches already so be nice . Hope you guys can confirm something for me...
I picked up an e-locker axle from a 1997 4runner Limited 4wd auto v6 at my local junkyard. I counted the ring splines and pinion splines and determined it's a 4.3 ratio (like most of the other threads have stated). 43 splines on ring gear and 10 on the pinion gear.
My question is on my current car. It's a 1999 4runner SR5 4wd auto v6 no locker. I don't want to have to tear it apart to figure out the gears. Most of the threads state it is "probably" and most likely a 4.10 given it's not locked. However, I jacked up 1 rear tire and did the "spin test" and got these results.
13 single tire rotations yielded exactly (or very close to it) 28 axle rotations.
28*2 / 13 (since I think I'm supposed to rotate tire twice) and got 4.30769 gears.
Am I good to say I got 4.30 gears in my v6 auto. That'd make my day since I could just swap the entire axle!
I want to make sure before I start re-buliding the junkyard axle and buying the relays/switches/etc.
Thanks Yoda Fam!
**EDIT 8/13/2017: Did the 20 tire rotation spin test and confirmed I got 43 axle rotations exactly. Both methods seem legit but this one confirmed it's 43 / 10. I'll probably open her up for kicks to confirm.
08-11-2017, 05:27 PM
Real Name: Just call me the Grease Monkey
If it's automatic it is very likely 4.3, not really related to if it is locked or not, except the lockers are more common in Limited editions and all Limited's are automatic which is 4.3, so most locked axles are 4.3.
My Snow and Sand build thread
Mark_BC's 2000 Limited Salvage Build
Determined to keep them from becoming parts trucks. Yes, even the one I just picked up as a parts truck...
08-11-2017, 05:41 PM
My 97 SR5 auto is 4.10........which matches the ratio code on the door sticker. With stock tires at 2000rpm I'm doing 63-64mph.
The 97 Limited e-locker is doing 58-59mph at 2000rpm with a 4.30 gear code on the sticker.
08-11-2017, 06:10 PM
Real Name: Minh
Real Name: Minh
Yah, i confirmed the locker i pulled from the 97 limited is 4.3 via the splines. I just wanted to confirm if my 99 (non locker) was 4.3 or 4.10. I'm fairly sure it's 4.3 based on the spin test but a lot of the forums state they were 4.1!
I will drive on the freeway to see what i am at @2000rpm.
08-11-2017, 08:11 PM
Wow... so you are the one who pulled the axle from the 97 in the yard in Fresno. A friend of mine took the seats off of the same truck and he said there were two who looked very happy to find something near the dash. I said it got to be the rear locker!
Anyways... post the code located on the door jamb or a picture of it.
08-11-2017, 11:10 PM
Real Name: Scramble
Real Name: Scramble
Nope, most non locked Limiteds are 4.10. Locked are 4.30
Manual SR5's Locked are 4.10,
not sure about SR5 Auto's though they are rare.(Highlanders, SE's)
Locked, manual Base models are 4.56
____________
'99 4Runner - 2.7L 3RZ, 5 Speed, 4.56 Gears - Lifted, Locked & Loaded - 166k Original owner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
'99 Limited - E-Locker- Stock (for now) - 233k 2nd Owner http://www.toyota-4runner.org/3rd-ge...ted-build.html
08-11-2017, 11:21 PM
Real Name: Scramble
Real Name: Scramble
Thanks Yoda Fam!
You have to rotate the tire 20 times & count the rotations of the drive shaft. Or do it 10 times & times it by 2. But 20 times gives a more accurate number say if you're trying to figure out 3.90 vs 4.10. etc.
____________
08-11-2017, 11:25 PM
Real Name: Minh
Real Name: Minh
Yah. My brother-in-law and I were there when he took the seats . I was eyeing them too but I wasn't sure if I wanted leather (got them in my other cars and it's hot as f*** in Fresno). And yah, we were happy to find the 4WD ECU. We took the axle first and I recall needing that thing. The ECU was ~$100 when I looked it up real fast and I got charged $5.99 .
Here's my sticker.
08-11-2017, 11:26 PM
Real Name: Minh
Real Name: Minh
I actually recorded the video... i will check again .
08-12-2017, 07:41 PM
You got A04A as the axle code. According to the off-road.com and LCengineering.com, you got 4.56 ratio.
LC ENGINEERING Differential Tech
08-12-2017, 08:57 PM
Originally Posted by nissanh
That list really only applies to the 95-04 Tacoma models.
The typical codes for the 96-02 4Runners are as follows:
A01A 3.73
A02A 3.91
A03A 4.10
A04A 4.30
A05A 4.56
But every now and then, some still don't match these codes.
2000 4Runner SR5 V6 - Was 2wd, now new and improved with 4wd!
- Tundra 199mm brakes, Front(99 Talls/Tundra 5100 at 3rd notch), Rear(OME 906/2-10mm trimpackers per side/Tundra 5100), Trail Gear Rock Defense Taco Crossmember, Taco 5-Stars, 265/75/16 Cooper ATP, DRL disable, ADD Switch, B&M 70268 Trans Cooler
- Next on the list: E-locker swap(hopefully), Better front skid
08-12-2017, 10:20 PM
Real Name: Scramble
Real Name: Scramble
Only the 3rz's came with 4.56 from the factory. And those were only manuals with 16" wheels. I use Sonoran Steel's web site for the codes. LCE is heavily Taco biased. Argh!
____________
08-12-2017, 11:44 PM
Not related to the ratio. If you notice the wheel size, it shows 15 and mine also show 15, but the factory wheel is 16: strange!
08-13-2017, 12:12 PM
Real Name: Scramble
Real Name: Scramble
Yep. my door code says 225/15, but came with 16". From what I've seen they all say 15"
____________
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
