08-16-2017, 02:01 PM
#31
Originally Posted by nevada
the tundra calipers are larger, yes? then, yes if you don't also upsize the MC, you will have a soft pedal.
I didnt have a soft pedal on my TBU. Lately is has gotten soft even after bleeding. I have found the brake booster is failing. If you put your rig in 4wd low and move 10 feet you should beable to get it to stop quickly. If the peddle is soft and then gets hard but you keep moving teh brake booster is most likely failing.
08-16-2017, 03:38 PM
#32
Real Name: Ivan
Real Name: Ivan
Originally Posted by Chim
This is not the case with mine.. I have an 02 with larger Tundra brakes and my pedal feels great with no MC up size.
i have them on my 01 without issues.
2001 SR5,
thundercloud, tundra brake upgrade with 231's, 906's/billies rear, 5100's/stock coils on 4th groove front, ISR/deck plate mod, ford trans cooler mod, 99-00 grille swap, led conversion, 17" 2014 SR5 wheels wrapped with cooper AT3's, 265/70/17
08-16-2017, 04:07 PM
#33
so the tundra calipers aren't bigger? then why do people use them? what is the advantage?
they are either bigger, or they aren't. but if they are, if the piston bore is bigger, you will need to adjust the MC bore accordingly, or you wont have the same feel at the pedal.
its physics.
1985 pickup : EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5 : 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited : stock. Build Thread YouTube Channel
08-16-2017, 04:10 PM
#34
its physics.
Yes, the calipers are bigger, and no I didnt adjust MC.. speaking of physics, my pedal feels great.. not sure what to tell you.
08-16-2017, 06:50 PM
#35
See post #8 (and others on same page) for a side by side pic comparison and related info, that'll make up your mind. This maybe a rotor from a 15" wheel vs the 16s on limiteds and sport models.
Rotor size
08-16-2017, 07:24 PM
#36
Rotor size
yes, physically they are overall bigger. but, that's not what matters, at least not in regards to the MC.
the bore size, the diameter of the piston is what will cause an issue. if its significantly larger, it will require more fluid volume. either by increasing the bore of the MC, or the length of the stroke. if you don't increase the bore, it will cause the pedal to be lower, and possibly soft. as you are now requiring more stroke to get the correct amount of fluid into the pistons.
has anyone pulled the pistons on each and compared them? or even mic'd them while in the calipers?
I just don't see how people are keeping the same pedal feel, while enlarging the piston bores.
08-16-2017, 09:59 PM
#37
its physics.
My brake pedal was the same after the tundra upgrade. Drove for about a year with tundra brakes so far. But now after the MC swap it is spongy
Otherwise truck is fine since swap.
01 4Runner Limited
3" Toytec lift with bilstein 5100 - 861 coils - Cooper ST MAXX - Savage bumpers - aux trans cooler - koyo rad - Tundra brake upgrade - "attic" interior cargo shelf
08-16-2017, 10:26 PM
#38
I THINK, on the 199mm caliper, the pistons are the same while the 231mm calipers have larger pistons. that's why most of the soft brake pedal complaints after the TBU mod are from those using the 231mm calipers. However, most have been resolved after further bleeding.
10-22-2017, 10:17 AM
#39
My 01 4runner has the ABS light, brake light and alarm going off - no brakes at the pedal and the ABS pump isn't coming on when you turn the key switch on. Other than buying a whole setup is there any other options that you or anyone else has found???
10-22-2017, 02:30 PM
#40
^^^ See here: https://forum.ih8mud.com/threads/mas....406533/page-2
It is for the LandCruiser but very similar. I think somewhere there they speak about a shop in CA who fixes the booster pump. The worst thing that can happen to a newer toyota is this ABS brake pump failure!
10-23-2017, 06:39 AM
#41
How many miles do you have?
Most of these Master Assemblies seem to fail around 230k miles.
You might get lucky doing a rebuild of your unit. However, you may not. There's not that much info out there for fixing these when they fail. In fact, Toyota recommends you do not even attempt it. Some guys have had luck tearing theirs apart and replacing cheap little parts like O-rings and springs. It all depends on how much time you can spend on it and how handy you are. I doubt you will find anyone who would rebuild it for you.
The most cost effective and easiest route is to buy a used assembly with 100k miles from eBay for about $490. Install yourself or get an import mechanic to swap the units for $200 or $300. Can get running again for around $750. And it should be good for at least 130k miles.
01 4Runner Limited
10-23-2017, 02:18 PM
#42
I've heard of people swapping out their 01-02 MC with an older one.
2001 4Runner 4WD Sport Package, Millennium silver, 110,000 miles, 2nd gen TRD Supercharger, Toytec BOSS coilovers, 890 OME rear springs, Bilstein 5125 rear shocks, custom Baldlands front bumper, PIAA 520 driving lights and fogs, 4x Innovation Sliders (welded on!), 18" Magnaflow muffler, JDM corners, 65" Thule bars, 20% tint, 16x8 FJ80 wheels on 265/75-16 Duratracs, Husky mats w/ cargo, rear diff breather mod, 3M clear bra, remote start, Pioneer AVIC-8200NEX
10-23-2017, 09:23 PM
#43
Real Name: Skip
Real Name: Skip
Just happened to see this ad and was reading this topic this morning and though if anyone is in this area...South Carolina....you might want to jump on this.
https://charleston.craigslist.org/pt...352241884.html
2004 Limited V8
10-23-2017, 09:42 PM
#44
Real Name: C8H18 Mike
DAYUM, G
It's threads like this that make me glad I own a 99, and I will only ever buy a 99 or 00 4runner, unless just for parts.
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto -> 2WD 4runner Journal Thread
10-24-2017, 08:45 AM
#45
Originally Posted by octanejunkie
DAYUM, G
Don't be scared of technology and the future. You will miss out on a lot. Haha.
