Originally Posted by Devo9000
I pulled the drums off for the first time on this truck, 02 4Runner 150k mi 4x4, yesterday and noticed uneven wear pattern.
The leading shoe is worn at the bottom of the shoe much more than the top, same in both sides.
The trailing shoe is hardly worn at all.
No evidence of cylinder leakage
All parts and springs look super clean, no rust
Drum looks clean, no scoring or bluing
Is this because the previous owner never used the parking brake, therefore out of adjustment?...
Thanks for your input..
Aloha
most likely out of adjustment. but that really has nothing to do with not using the park brake. the self adjuster works with any movement of the shoes. when it works.
check the star wheel, make sure it turns freely. its super common for them to seize up.
get them adjusted up properly, and you should be good to go.
1985 pickup
: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5
: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited
: stock.
Build Thread YouTube Channel
