09-19-2017, 11:51 AM
#46
Real Name: 3 Bears
Real Name: 3 Bears
I have the 10 ply ko'2s at 36psi. They will feel every bump in the road, only thing I don't like about them. I was warned I would feel everything but I went with them anyway because I don't like flats on back gravel roads.. They were not designed to be a freeway tire to run all day at 70mph and be smooth
09-19-2017, 07:14 PM
#47
Real Name: Robert');DROP TABLE Students;
It's the tires. Round four of balancing today made it a lot better, but still not great. Hopefully round five tomorrow will get it knocked out.
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
09-19-2017, 08:33 PM
#48
I'm not impressed, BFGoodrich.
I knew it. Like I said before 95% of vibrations come from the tires.
BFG is made by Michelin
They are good tires
Like I said before
You got a bad batch. Witch happens. Not a big deal. You just gotta man up and demand them replaced
I've got the same tires and have installed them many many times a lot of members here have the same tires.
I wouldn't hesitate to get another set or recommend another set.
2012 TRD Tacoma wheels
Grey wire mod
Toytec ultimate lift w/super flex rear coils
1.25 spidertrax coming soon
09-20-2017, 12:09 AM
#49
I've had great luck with BFG's on my Jeep and Diesel truck.
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
09-20-2017, 11:59 AM
#50
Real Name: Jerod
Real Name: Jerod
Tires are warrantied, you should be able to get a refund.
Michelin are good tires though, normally.
09-20-2017, 12:14 PM
#51
I had a lifted 2013 TTFJ running 285 70 BFG KM Muds and they balanced perfectly the first time and wore evenly so you must have gotten a bad one.
I saw it mentioned only once through this thread but it's a good idea to try to put a full set of stock rims and tires on the truck and drive it and see what the result is. I read that you had trouble locating a donor set to test with. Maybe a junkyard?
09-22-2017, 06:22 PM
#52
I had all 4 tires replaced this afternoon. Vibrations are still there.
I don't really know what else to do.
09-22-2017, 06:26 PM
#53
I can't really add anything to help with your vibration hunt besides the fact that I was also an unlucky customer with out of round KO2s. Earlier this year I went through a nightmare of getting BFG to warranty my tires. After about 2 months Michelin/BFG gave me a brand new set of KO2s.
Good luck
09-22-2017, 06:35 PM
#54
Good luck
I'm not sure the first set was actually all that bad, just not perfect. They agreed to replace mine without an argument, so I'm back in BFG's camp.
09-22-2017, 10:05 PM
#55
That really sucks. What else to do but find a known good set to try on?
I'm in a similar situation and in the spring I hope to borrow my buddies summer set up from his tacoma for an afternoon. Mine have been balanced several times too.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
09-22-2017, 10:37 PM
#56
Did you ever remove the front driveline ?
Grey wire mod
09-23-2017, 07:53 AM
#57
Originally Posted by SpidermanGeek
Lol. I keep my tire PSI at 40.
And now I just slapped on a set of Load Range E tires and my vibrations are gone (and I still need to have them balanced). These tires/wheels came inflated to 58-60psi in them, but I equalized them all around 55psi.
I'll see what my tire guy says about the PSI when I get the balancing done next Friday, but from what I've read, a load range E should run at no less than 45psi. Seems like that's about the minimum average for 10ply sidewalls.
1997 4Runner Limited V6 Auto 4x4 w/E-Locker - 184K Miles
OME 881/890 Springs, Tokico TrekMaster GU3535/GE3536 Shocks, 1" Front Diff. Drop, Front Frame Mounted D-Rings
All-Pro 1.25" Hubcentric Wheel Spacers, 265/75R16 ETS Trail Master M/T, B&M 70268 Cooler (bypassed)
2010 Matrix XRS 2.4L 5-Speed - 130K Miles
09-23-2017, 08:13 AM
#58
Not yet, going to do that this morning.
09-23-2017, 10:54 AM
#59
Removing the front driveshaft has no effect on the vibrations.
09-23-2017, 11:22 AM
#60
Sorry for the disjointed posts, been posting as I go.
I noticed that the steering rack is leaking more than it was, and there's shiny metal next to the passenger side steering rack bushing, which tells me the bushings need to be replaced.
Could this cause a vibration like that? Sorry for the huge pic, I'm posting from my phone and can't resize.
