08-22-2017, 03:18 PM
#16
Originally Posted by JayRolla
There is always ways around that kind of stuff. But you are right. SUcks for you guys out there.
My e85 talon passes emissions with flying colors. HAHA.
But its a talon. Nice for commute but not offroad. .
Edit: after (re)seach talon will def rally like mad
Sent from my SM-G930P using Tapatalk
08-22-2017, 04:11 PM
#17
My talon tears up the offroad. It was designed for rally.
08-23-2017, 07:11 PM
#18
Nice write up! Why do you think they would fit better on the 01-02?
Bandit Runner, 2021 TRD Off Road Premium
Build Thread: https://www.toyota-4runner.org/5th-g...ild-2-0-a.html
08-23-2017, 09:28 PM
#19
Real Name: Jerod
Real Name: Jerod
The transmission dipstick is short and more off to the side so it might clear the headers with little work, and there's no transmission kick-down cable on the other side. So it eliminates 2 of the 3 problem areas we encountered.
08-23-2017, 09:40 PM
#20
You didn't wrap the headers if you were worried about heat? The stuff works.
Like BrianSD_42 I had a pair of Downey headers but sold them to a former member. I think their fitment wasn't much of a problem. Damn Great Recession took Downey to its grave.
08-24-2017, 09:42 AM
#21
Real Name: Mark
Real Name: Mark
I dont mod N/A vehicles for power because of that. Only boost. No reason to spend more money to make the same power a cheap turbo or nitrous kit can get you.
But with his setup for that money he could have gone turbo with full EMS by now.
No doubt FI gets you there with fewer bucks. Talking Runners I like the constant boost from idle to wot with a SC more than Turbo based on usage.
The NA mods for me were class governed in autocross, you did what you could to eek out a pony or three. put me in a seat behind twin turbos w/200 shot on a stroked SB/BB thats sweet!! on the strip/street.
96RedRunner limited 4x4 5VZ auto not stock 374k miles totaled 2018.
2001 limited 4x4 5VZ auto work in progress.
2011 Audi S5 Prestige 4.2 V8 6 spd MT.
08-24-2017, 09:51 AM
#22
Real Name: Mark
Real Name: Mark
Yes in deed they will! They were somewhat the lead in Rally for the times.
09-21-2017, 01:44 PM
#23
Real Name: Jerod
Real Name: Jerod
I have a bad baseline for this summer, since CA changed their gas blend and my MPG's have gone to pieces, along with any other older vehicle.
Pre-header MPG: 14.9
Post-header MPG: 15.47
I'm not sold on these readings though, because prior to the summer blend I was getting 16.7-17.0 MPG's. When winter blend hits I'll post up the numbers again.
04-04-2018, 12:29 AM
#24
Real Name: Scramble
Real Name: Scramble
How are your MPG's now?
____________
'99 4Runner - 2.7L 3RZ, 5 Speed, 4.56 Gears - Lifted, Locked & Loaded - 166k Original owner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
'99 Limited - E-Locker- Stock (for now) - 233k 2nd Owner http://www.toyota-4runner.org/3rd-ge...ted-build.html
04-04-2018, 12:57 AM
#25
Real Name: Jerod
Real Name: Jerod
My O2 sensor fouled a few months back and I didn't realize it, was getting a constant 14.5 MPG over the winter. I started tracking it again so hopefully the numbers go back up.
Super(charged) Fun (Toyota 4Runner) | Fuelly
07-17-2018, 01:48 PM
#26
Real Name: Alexander Straughn
I just purchased a set of DT Headers for my 2018 4R OFP and am trying to make sure I understand everything I need to do to SAFELY install them with no long term problems. I got the long tube headers from Doug Thorley, and per their instructions bought a URD O2 Simulator. I planned on bringing those pieces of hardware to a professional performance shop to install. I got specific instructions from the Sales Manager from Doug Thorley but I am trying to get a good gauge to know if there is anything I missed. If I install the headers, with an O2 SIM is that all I need for it to be safely installed for the long run? I had heard from a local shop (which contradicts Doug Thorley directions) that an O2 sim isn't sufficient for the long term and I need to get it tuned. Does anyone have some thoughts on all of this and give some advice as to how I should proceed?
11-02-2018, 09:56 AM
#27
This is the wrong thread, wrong year, wrong spot to post
06-15-2019, 10:22 PM
#28
I purchased the Doug Thorley Headers, Part #: THY-507-C .....
I noticed that you ordered the non-smog version, and are also located in CA... can you please explain? Why is there a smog version, and why did you not use it? I do see that both are CARB legal, so I'm confused.
Planning my move to a S/C and would love to know before ordering parts. I have an '02 Auto, if that matters.
02 4WD SR5 - (F) King CO w/Icon UCA, (R) King 2.5 w/ RR & Adj w/ OME 890, AOR front bumper, JTA custom sliders, Outgear roof rack, E-locker, Sequoia 5 stars, Duratrac's, Tundra 231 brakes, SS brake lines, custom sleeping platform/drawer system, fully wired Blue Sea Systems fuse block with Ripcord plate mod
06-16-2019, 01:36 AM
#29
Real Name: Jerod
Real Name: Jerod
The difference is the EGR valve port which is only on a few older 4Runners. I don't have an EGR valve ('02 don't have them either) so you'll want the non-EGR valve version.
Since you have two cats, yours might actually be bolt-on and no welding required. They are still an absolute pain to install though!
06-16-2019, 02:52 AM
#30
Ok got it. The website I was looking at them on did not clearly explain the Smog/EGR valve option, but now it makes sense. Thanks!
