Old 08-22-2017, 05:50 PM #1
FourRunning FourRunning is offline
FourRunning is on a distinguished road
2001 4Runner brake upgrade to Tundra
Been lurking, but don't post but now could use some help. Have a 2001 4R SR5 that came original with 15" front brakes. Tired of the warpeage and constant brake attention. I have a set of 17" J Cruiser factory wheels on it. Been scrounging around the board on the Tundra upgrade and it looks like that's what I might do. I'm guessing the 17" wheels shouldn't pose a problem, tho I do see on an OFF-ROAD article they have you shave down the back of the wheel.
Gen 3 Toyota 4Runner Tundra Brake Swap: Off-Road.com
Anyone see a problem with doing this swap using the 17" wheels? I'm assuming the stock brake lines will connect just fine. I'm going to order parts for a 2006 Tundra, which is the end of the 1st Gen line. Any good parts lists? What not to order or what didn't work?
Thanks in advance for help. Will get some pictures of my Runner and avatar set up. It's an untouched stock 4Runner in very good shape except the brakes and wobbly sponge suspension (next project).
FourRunning is offline   Reply With QuoteReply With Quote
Old 08-22-2017, 06:04 PM #2
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
You'll just have to try out the new hardware on the 17" wheels you have. The trimming required you mentioned is only for the 16" wheel and then only the ones in the picture to the article you attached, not all wheels. Otherwise should be pretty straight forward. Luck.
Old 08-22-2017, 07:59 PM #3
hang10's Avatar
hang10 hang10 is offline
hang10 is an unknown quantity at this point
hang10's Avatar
Warpage ?
1997 4runner 300k. SOLD
2000 4Runner SR5 SOLD
1999 4Runner LTD Current
hang10 is offline   Reply With QuoteReply With Quote
Old 08-22-2017, 08:35 PM #4
Since you have a 15" wheel truck, you'll want to upgrade the rear wheel cylinders at the same time. The smaller wheel trucks have smaller front discs and calipers, and smaller diameter rear wheel cylinders (the drums and shoes are the same though). That will keep the brake bias closer to original.
And the brake discs aren't warping... the pad material is getting unevenly deposited on the rotors. Good pads, correct bedding and careful driving can reduce or eliminate it. (my 15" wheel brakes don't have any pulsation, even with 265/70-17 tires - they are just woefully underpowered!)
Either way, the Tundra brake upgrade should help.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 08-22-2017, 09:16 PM #5
tarsun tarsun is offline
tarsun is on a distinguished road
I had to cut the dust shield a little when i did mine and sanded the face of the caliper a little rather than the back side of the rims....
tarsun is offline   Reply With QuoteReply With Quote
Old 08-22-2017, 09:24 PM #6
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Well, I reckon this is another opportunity to share a video. Happy TBUing.
brake , swap , tundra
FS: New Tundra Brake Upgrade for 3rd Gen 4Runner South Jersey danpba152 For Sale: T4R Items 14 02-25-2016 10:07 PM
2001 4Runner Limited / Tundra brake compatibility garrettqwan 3rd gen T4Rs 0 09-14-2014 05:32 PM
Tundra brake upgrade on my '96 4runner needs mounting hardware? happysmp 3rd gen T4Rs 15 03-23-2014 12:05 PM
2001 S13WE Tundra Brake Calipers (Loaded) - 4runner upgrade! andrew spivey For Sale: Non-T4R Items 1 01-26-2012 11:22 PM
