Old 08-23-2017, 01:41 PM #16
ajordan1975's Avatar
ajordan1975 ajordan1975 is offline
ajordan1975 is on a distinguished road
Originally Posted by mtbtim View Post
How do you bend metal brake line without crimping the line if you need to do some major bending? I reckon there must be some type of special tool to accomplish this. Hopefully the amount of bending you need to do is minimal and you won't have any issues with crimping the line.
i use my hand, and any thing round (jack handle, beer can, etc).
it's really easy, just have to go slow.
98 Limited, DD with Sway Away coilovers, Camburg uniball uppers, OME 891's w/ Bilstein 5100's in back, 285 BFG, KO2, Factory elocker. custom sliders
97 LX450 is the fun toy
ajordan1975 is offline   Reply With QuoteReply With Quote
Old 08-23-2017, 02:36 PM #17
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Easy to do by hand with aluminium, SS not so much, but the beer bottle neck is probably close to the correct radius for the front brake hardline bends
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 08-24-2017, 01:46 AM #18
stever1000 stever1000 is offline
stever1000 is on a distinguished road
Ok, it worked really well. Here is the bender in action:
Finished product:
No kinks, and went very smoothly. The OEM line was easy to copy, and after getting near the same on each bend it fit perfectly first try
stever1000 is offline   Reply With QuoteReply With Quote
Old 10-15-2019, 02:40 PM #19
schwipt schwipt is offline
schwipt is on a distinguished road
Just to add to this thread:
I was also having trouble getting my stainless steel lines (from wheelers) to thread into the hard lines. I came across this post and noticed that I also had no threads along the bottom portion of the bolt.
So, I purchased new OEM hard lines (pre and post flexible line). Even on the new hard lines the only full threaded nut is at the caliper. All others sides still have the non threaded part.
I then noticed on my SS lines that the ends were different lengths. The slightly longer end I could get about a half turn by hand, and the slightly shorter end I could only get about 1/16 a turn by hand. The second you take a wrench to it and put any force on it, it pops out.
I can get about 2 full hand turns using the OEM flexible line, and they are easy as can be to install.
TLDR: The only hard line that is fully threaded should be the one going into the caliper. All others have a portion of no threads to start.
If you are having trouble getting SS lines on, check the depth of the threads vs the OEM flexible line - My SS lines did not have deep enough threads to get a proper connection.
I may take some pictures later
schwipt is offline   Reply With QuoteReply With Quote
Old 10-15-2019, 04:11 PM #20
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I always use OEM brake lines as they are not that expensive in the USA. I mostly paint the new brakes lines with rust-oleum. However, I have used the little copper nickel lines from Napa {shortest ones they had for Japanese vehicles 3/16 }as I was changing brakes and the piston pushed out too far damaging the caliper. So being I needed to get this back in the road fast. I couldn't wait for the OEM lines. Both Front calipers where changed on Tetanus 1 with re-mfg calipers. As the originals with 250K and 21 years needed to be replaced anyways. {Salt had them pretty oxidized} The Braking did improve when the new calipers went on along with Rotors and New Pads.
Front Brake Line-tetanus_1_driver_side-jpg
Old 10-15-2019, 06:48 PM #21
APhelps APhelps is offline
APhelps has a spectacular aura about APhelps has a spectacular aura about
The quality of Wheeler's is highly suspect at this point in regards to their brake lines.
APhelps is offline   Reply With QuoteReply With Quote
Old 10-16-2019, 10:10 AM #22
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Sure seems like a lot of folks are having issues with these stainless kits and flex hoses. Such a shame as they should work the same as OEM and you shouldn't have to make lines unless you want to. I don't blame anyone for going to stainless as it can't rot out. But man, when you get kits they should fit without any issues if they are for your rigs. Bogus. :[
front brake hard line OEM part number or equivalent DK327 3rd gen T4Rs 22 04-29-2019 09:55 PM
FS: Galfer USA Brake Line Assembly tool with SS Line tacticalone For Sale: Non-T4R Items 4 09-09-2015 01:27 PM
e brake line too short? landcruiser e brake? D Farms 3rd gen T4Rs 0 05-25-2015 12:19 AM
HELP NEEDED: Front Brake Hard Line? BamaDrewski 3rd gen T4Rs 3 05-05-2015 10:21 PM
HELP, brake line doubleA 3rd gen T4Rs 12 05-27-2012 07:38 AM
