Old 09-05-2017, 02:55 AM #1
3rdgen_4runner 3rdgen_4runner is offline
3rdgen_4runner is on a distinguished road
Fuel leak stops. Now have a blue liquid on outside of fuel filter. Hard start getting
So I've been having a few issues with my truck. So I started tinkering and tweakin on it. Not knowing what the hell I'm doing but getting stuff done. I won't go into each different thing I've done but I'll tell you that the issues that I began with are only getting worse.
I've had a hard start since I got it. I've researched and did some troubleshooting and decided what to do. Spark plugs changed but still hard start persist. I didn't change my wires because I was told that they really shouldn't be changed unless plugs are burnt at the connection. Idk. So I skipped the wires and went to the fuel filter after having a reader diagnose that fuel system 1 in CLOSED LOOP and fuel system 2 is NA I believe. So basically I read it was lean. Idk if it was necessary for the fuel filter or if I should've changed the O2 sensor or if the fuel pressure regulator has gone bad.
It's getting harder to start my engine and I do a lot of stop and go driving and even the freeway is slow moving stop and go. But when I get the chance to drive faster than 30-40 mph I do no more than 65 mph and I use cruise control mostly. Any advice on that connected to the sputtering I get while driving?
Another issue at start up is a short loud squeal from a belt. It immediately goes away once I tap the gas pedal. The belt feels tight and it only happens at start up. Hot or cold
The fuel filter isn't leaking gas anymore. But it is leaking something blue. And I wouldn't say it's actually a leak more like I see a blue droplet of some substance. Any ideas? I have a picture below
Fuel leak stops. Now have a blue liquid on outside of fuel filter. Hard start getting-20170904_234235-jpg
3rdgen_4runner is offline   Reply With QuoteReply With Quote
Old 09-05-2017, 08:30 AM #2
SpidermanGeek's Avatar
SpidermanGeek SpidermanGeek is offline
SpidermanGeek is on a distinguished road
did you use any Loctite on the threads when installing the new filter?
1997 4Runner Limited V6 Auto 4x4 w/E-Locker - 184K Miles
OME 881/890 Springs, Tokico TrekMaster GU3535/GE3536 Shocks, 1" Front Diff. Drop, Front Frame Mounted D-Rings
All-Pro 1.25" Hubcentric Wheel Spacers, 265/75R16 ETS Trail Master M/T, B&M 70268 Cooler (bypassed)
2010 Matrix XRS 2.4L 5-Speed - 130K Miles
SpidermanGeek is offline   Reply With QuoteReply With Quote
Old 09-05-2017, 10:23 AM #3
JRZEE2000TR4LTD's Avatar
JRZEE2000TR4LTD JRZEE2000TR4LTD is offline
Real Name: John
JRZEE2000TR4LTD will become famous soon enough JRZEE2000TR4LTD will become famous soon enough
Real Name: John
Fuel filter is still leaking. Unless your truck runs on Honda OEM coolant.
As far as your starting problem, that could be the Idle Air Control (IAC) valve.
You need to figure which belt is loose. It's probably the ALT belt as it is the longest. I forget of the top of my head what the deflection is but I know the has to be pretty tight.
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
JRZEE2000TR4LTD is offline   Reply With QuoteReply With Quote
Long-ish starts cold, too-quick starts warm. mckennar 3rd gen T4Rs 4 10-18-2016 12:20 PM
OME Lift Complete: Truck is "shuddering" and feels weak denvermaxd 3rd gen T4Rs 20 06-19-2015 07:41 AM
Strange Cranking, but truck always starts. 89FourRunner Classic T4Rs 1 06-24-2013 03:22 AM
1992 4runner 3.0 cranks forever, finnaly starts, then starts fine timcarl450 Classic T4Rs 2 03-26-2013 12:56 AM
