Old 05-12-2021, 10:21 AM #31
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
Time to count revolutions to confirm your gear ratio. You should be able to confirm if this way.
Also, @JDM_4Runner please don't throw other forum members under the bus until you know what's actually going on. Maybe not even after, in fact. We have a great community here that is technical, helpful, and generous. Let's keep the BS for Facebook. I'll get off my soapbox now
JZiggy is offline   Reply With QuoteReply With Quote
Old 05-12-2021, 12:31 PM #32
Originally Posted by Skulking View Post
It seems you may have missed the post below from 2017 letting you know why re-gearing wouldn't fix your speedometer.
What's confusing me is why the RPMs are so high. That's more like a 4.3 gear with stock size tires at 75mph. It should be ~2300 with the 4.1 gears and ~2200 if tire size is bumped up from stock to "metric 32's" (265/75-16 or 265/70-17).
But to reconfirm - the speedo reading is only related to tire size. Gearing has no effect on the speedo for almost all 3rd gen 4Runners.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 05-13-2021, 01:09 AM #33
JDM_4Runner JDM_4Runner is offline
JDM_4Runner is on a distinguished road
Well I understand the Speedo/ABS relation, however, ignoring the speedo for a minute and referring to the GPS speed I'm getting the same value as before swapping over the third member. That tells me the tires are spinning the 4Runner faster forward, with my original 3rd member and the one I swapped in giving the same result.
OK, so I'm going to just count the teeth of my original 3rd member to find out once and for all what it actually is, and going with the logic that the 3rd member I swapped in is identical. I'll report back once I've counted!
Eric - JDM 4Runner
2001 SR5 2WD Automatic V6
JDM_4Runner is offline   Reply With QuoteReply With Quote
Old 05-13-2021, 01:13 AM #34
JZiggy, I hear ya dude. Definitely appreciate everyones feedback and help. I'll follow up once I've counted the teeth on my 3rd member.
Eric - JDM 4Runner
Old 05-13-2021, 01:24 AM #35
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
You say you understand the Speedo/ ABS relation, but I don't think you do. If you did you would understand why regearing didn't change how far off your speedometer is.
Skulking is offline   Reply With QuoteReply With Quote
Old 05-13-2021, 12:27 PM #36
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Changing the gear ratio does not affect your speedometer because the wheel speed sensors are after the differentials. The tachometer will change with gear ratio changes, but the speedometer doesn't care what gear ratio you are using. The speedometer to actual speed travelled will be affected by tire size changes. If your speedometer is reading slower than your actual speed then you have larger tires than what the ABS module is calibrated for.
EDIT: The above information applies to 3rd Gen's with ABS. Non-ABS equipped 4Runner's use a speed sensor in the transmission (2wd) or transfer case (4wd) for the speedometer.
"Change Body Settings" link no worky! 4xt4r 4th Gen T4Rs 2 10-04-2016 09:26 PM
WTB: Tacoma / Sequioa 16" "Star" Wheel x1 SnoViking For Sale: Suspension/Wheels/Tires 0 06-30-2014 11:02 AM
"new" 4Runner owner here doing plug and wire change... Lord Taco 3rd gen T4Rs 18 10-04-2010 09:27 PM
Zero point didnt work how to turn off "VSC TRAC" & "VSC OFF" & "ABS" lights sciff5 4th Gen T4Rs 6 09-27-2010 12:10 AM
"I'm sorry, the filter we didn't actually change has magically been crushed"- bonedoctor Maintenance/Detailing 19 08-27-2006 12:53 PM
