09-18-2017, 05:10 AM
Real Name: Tony
Real Name: Tony
Need Cylinder Head Suggestions
Need suggestions as to where you guys purchased remanufactured head(s). Doing head gaskets and found cyl # 3 to be cracked, which I've heard was pretty common. My friend also pointed out the obvious cracked valve! So ya, let me know where you guys have purchased heads and if you were satisfied with the shop. I live in Hawaii, so shipping will play a factor.
2002 4Runner Sport 4WD Sunfire Red- (Comfort goodies) Yakima Rack, Wet Okoles, Weathertechs, Scangauge2, Hayden Trans Cooler, Trail Edition Wheels
2006 4Runner Sport V8 4WD, Salsa Red (sold)
2004 Tacoma TRD Double Cab 4x4 (sold)
09-18-2017, 11:21 AM
Real Name: 3 Bears
Real Name: 3 Bears
I did not know that these cracks are common.
Anyway, the is a shop in Portland Oregon who does heads, He rebuilt a cracked BMW head I had, but not cheap, 4 cylinder $600 3 years ago
but used was impossible to find and new out of the question unless your warren buffett
09-18-2017, 01:29 PM
There is an aftermarket company that makes new heads. IIRC, it is around $600 for a complete set, ready to install.
I don't remember the name of the company, but check ebay and you should find them
1997 SR5, Lavender Steel, 5spd, stock
1999 SR5, Millennium Silver, 5spd, mostly stock - for now.
1997 SR5, Evergreen Pearl, 5spd, stock
09-18-2017, 09:42 PM
Real Name: Tony
Real Name: Tony
I shouldn't say common, but from what I've read in other posts, the cracks were usually right at cylinder 3, for whatever reason.
But yes, hoping to not spend $600/head. I dropped the heads at a shop today for assessment, and the shop actually mentioned the possibility of repairing, then rebuilding the cracked head, but we shall see.
09-19-2017, 01:21 AM
The head on my 3rz had similar cracks in about 10 places. I had a shop repair and completely rebuild it for 500$. I would imagine a 3 cylinder head with one crack would be cheaper.
Sent from my Z958 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" ( Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - ( Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
09-19-2017, 04:26 AM
Real Name: Tony
Real Name: Tony
I initially thought that once the head was cracked, it was done, but I guess not. I'm really hoping that they can repair and rebuild the current heads. Their quote for rebuilding both heads was $800, which I'm hoping ends up being the case.
09-19-2017, 12:12 PM
Real Name: 3 Bears
Real Name: 3 Bears
In the olden days heads were not rebuildable esp if a crack in a valve seat,
but technology has improved over the years
09-19-2017, 12:36 PM
Real Name: C8H18 Mike
Originally Posted by LittleCaesar
$800 a pair ready to bolt on isn't bad, but the shipping and core return to/from HI could be cost-prohibitive
When looking at rebuilt heads, always inquire if ALL exhaust valve seats have been replaced with hardened seats and if all valves have been replaced or if it is a mix and match rebuild. Most head cracks usually involve exhaust valves, and center cylinder failures are common due to higher heat in that area. I would also make sure all fixed cracks are magnifluxed and the heads come with a complete replacement guarantee.
In my experience with other engines, starting with used head cores for head rebuilds usually always creates smaller chamber volumes as the heads need to be surfaced flat, so a thicker gasket is required, otherwise you will increase the final compression ratio. Make sure either the gaskets are supplied by the builder or they tell you exactly which thickness gasket is to be used so you don't end up detonating yourself it death.
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto -> 2WD 4runner Journal Thread
09-20-2017, 01:12 PM
Real Name: Tony
Real Name: Tony
Some solid advice there- much appreciated!
The machine shop called and confirmed that the cracked head failed the pressure test (crack went downward towards the valve guide) and into a coolant passage, hence my coolant loss. Makes sense now, especially after removing the old HG and not noticing any obvious weak/damaged areas.
So as of right now, the shop is looking into rebuilding the good head that did pass, then rebuilding a core that they have on the side for the failed head. The core isn’t brand new, but will be fully rebuilt like the other side. And for only $100 extra, i figure it’s a good deal! We’ll see once all is completed and hope to have the heads back by the weekend.
09-20-2017, 02:08 PM
∆∆∆∆ that's the best outcome right there. Good for you.
Sent from my Nexus 5X using Tapatalk
