09-30-2017, 09:04 PM
3rd gen 4runner PCV Valve Replacement
2000 SR5
01-29-2019, 11:57 AM
How did it actually come out? I can spin mine easily but can’t actually pull the thing out. Did u pull it from the grommet or just pull till it came out? Mine just won’t budge and I know it needs to be changed sooner or later
01-29-2019, 12:31 PM
Mine was like that. Don't try to grab the top with pliers or something or attempt to pry the upper lip as you will probably break it. I pulled mine after 15 years by working on a still warm (not hot) engine, and using a seal pick with a 90° tip that let me pull up on the bottom edge. I worked it around pulling a little bit harder each time as I worked around the bottom edge. When it finally popped, it went 10 feet in the air but stayed in one piece. I did spray some PB blaster around the edge before I started.
I used a pick like the second from the top:
I didn't use the point, I put the elbow against the bottom inside edge.
My Backyard Frame Swap
01-29-2019, 01:26 PM
A rocking motion will help too. A panel puller like this might help/work too:
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
01-29-2019, 01:37 PM
Real Name: Jerod
Real Name: Jerod
Metal shavings? Dun dun duuunnn...
Might want to change your oil soon in case some of them dropped onto the heads & camshafts.
05-11-2020, 02:26 PM
Real Name: Morley P
Real Name: Morley P
Resurrecting an old thread, but I like following up on the specific threads that help me the most.
Thanks for the post, this job is very easy.
12204-62010 - PCV Valve
90480-18001 - PCV Grommet
12261-62041 PCV Hose
My PCV hose was cracked so I replaced it as well.
Things I wish I would have known before starting:
if you search Ebay using the hose number, you will find kits that include all 3 parts for less $$$. I bought all 3 parts separately and wasted $10 bucks.
Also, I am about to replace my vacuum line following THIS THREAD... if you plan on doing that, then skip ordering the hose all together.
Don't be afraid of doing this job, I had several pieces of the old grommet get pushed down into the housing, but I was able to fish them out pretty easily with picks and pliers.... No big deal.
- I sprayed the old valve/grommet with WD-40 two days before removing it. (I also removed while the engine was warm)
- The valve popped right out. I fished out the crumbling grommet right behind it.
- Push the new grommet in first, use a tiny bit of oil if needed
- Pop the new valve into place
- connect the hose
- DONE
07-09-2020, 01:11 AM
Thanks to all who participate on this forum! Replaced the PCV valve on my ’98. The old valve took some effort, a lot of rocking back and forth and wiggling. Pliers did the trick. Was nervous about the grommet but took it slow and worked it until it came really loose. It did break in two, but big enough to grab once I pried most of it out. Panel remover tool worked great for this.
I did warm it up by driving around the block a couple of times and used a lot of WD-40 to make removal a bit slicker. Installing the new parts was much easier, used WD-40 there also.
Parts list for '98 4 cylinder, ordered from Toyota Parts Deal, no issues there.
12204-75010 - PCV Valve
90480-18001 - Grommet
12261-75030 - Ventilation Hose
90467-14001 - Ventilation Hose Clips x2
Old valve and new valve plus old grommet in two pieces:
New PCV valve installed:
PCV valve close up:
Complete:
Tools:
07-09-2020, 11:41 AM
Is there a consensus on how often to replace the PCV valve? It’s not listed in the OEM maintenance schedule and the schedule goes up to 120k miles. I replaced mine at 150k, but I’m just wondering if it needs some more often.
2000 Limited. Lifted....finally!
www.OverlandNV.com
07-09-2020, 12:11 PM
As long as it rattles it’s good just remove and spray it out with brake cleaner every once and a while.
07-09-2020, 01:05 PM
Real Name: 3 Bears
Real Name: 3 Bears
agree with above...ive cleaned them often on many cars, esp if a car has ring or valve issues with increased blow by..they are not something tricky or complicated.
but would not hurt to replace every spark plug change or every timing belt, not like they are tons of money. I replaced mine at 145k and at 190k. 145 had just bought it and no record of replacement, doing all filters etc, . 190 was new timing belt , plugs, wires, v/c gaskets
07-09-2020, 02:58 PM
I’ll also say on my S Series Saturn I got rid of the PCV valve and replaced it with a fixed orifice type and it helped it in its oil usage.
07-16-2020, 10:21 AM
I just did this job yesterday after buying the 3 parts all together on ebay. Thanks for that recommendation!
I didn't have to take off anything in order to reach the PCV Valve. Just popped it out, fished out the crumbly gasket, and replaced all 3 pieces. Pretty easy job that can prevent loads of more expensive jobs.
10-15-2020, 12:28 PM
Just wanted to say thank you for the write up. Changed my PCV valve with minor problems mostly due to user malfunction. I put my airbox behind me when i was yanking the PCV valve and when it came out i stepped on my air intake box and cracked it. haha.
PCV valve came out. Broke the grommet. Put in new grommet. Cleared out junk inside engine as much as I could. Waiting on the new hose from Ebay. Doesn't feel any different but I feel more at ease. Thank you!
02-06-2021, 12:00 AM
Looking to hit the dealer tomorrow to pick up the parts. Other than cracks in the hose itself how can you tell the hose is needing replacement? Is the factory hose a hard rigid plastic or is it more pliable like the upper radiator hose?
Sold 2015 Canadian TE Magnetic Grey-Toytec BOSS, 285 70 17 Duratracs, Blue Sea fuse block, Gobi Stealth, Morimoto LED fogs, FN Pro(x) Wheels
Sold 1996 4runner Limited Natural White w/ Silver Cloud trim. 265 75 16
2013 Limited Blizzard Pear 3rd rowl - 2.5" Elka 2.0 Coils 650# Springs/0-2" Elka REAR /Dobinson C59-325 Rear Coils/Greenlane Diff Drop/ SPC UCA's
02-06-2021, 12:17 AM
Real Name: Devan
Real Name: Devan
Going to the stealership for a PCV valve+grommet and some vacuum line?... would love to know how much they're charging
