10-06-2017, 09:07 PM
Seemingly never ending sinking brake pedal issue
Hey guys, love the forum and all the information in it. I have a question regarding a brake issue that I've had since I bought the car (about a month ago now).
The brake pedal sinks to the floor.
I started by replacing the following:
Front pads and rotors
Rear shoes and drums
Wheel cylinders
Brake fluid flush and bleed
Still the pedal goes to the floor.
Thinking it had to be the master cylinder, I replaced it.
Still, the pedal goes all the way to the floor. Everything was bled correctly.
The truck is equipped with abs. Is it possible that air got into the abs module somehow and it's screwing up my brakes?
Im just really confused at this point and I'm tired of throwing money at the dang brakes lol. Any help would be greatly appreciated!
10-07-2017, 01:27 AM
Have you adjusted the rear brakes? If your rear brakes are out of adjustment. The pedal will feel like poop. Behind the wheel, there is a little opening. And you need to jack up the rear. And start adjusting the brakes till you have a hard time spinning the wheel by hand.
97 3.4 JDM/5 Speed swap/eLocker Swap/ICON CDC all around/+more.....
10-07-2017, 01:48 AM
You may still have air pockets in the master cylinder and/or abs.
Did you bleed the master cylinder first before bleeding the wheel cylinders and calipers?
The laymans way of releasing air in the abs is allowing the abs motor to cycle on a rocky, dirt or wet road, then bleed the wheel cylinders and calipers. Repeat until you get a firm pedal.
Or, bring it to a shop where they can use a abs tool to cycle the abs while the truck is sitting still.
10-07-2017, 01:55 AM
I went through a similar problem. From your description of you problem, you have probably failed to bleed the brakes.
Here is what I went through on my issue.
Bench bleeding master cylinder
Not having the tool to activate your ABS while bleeding basically means it's a royal P.I.T.A.
Also try turning the turning the truck on while bleeding the brakes, make sure your chocking your tires.
1999 Toyota 4Runner Limited V6 4x4 w/elocker and 231's!
10-07-2017, 07:23 AM
Real Name: Instagram: briansd_97r
Sounds like the description of what happened to me when my callipers broke.
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giant’s robe, Upon a dwarfish treasonous thief.
10-07-2017, 10:05 AM
Real Name: John
Real Name: John
The easiest thing to do is readjust the rear brakes first before going through the brake bleeding process over and over. The last 2 times my brake pedal was down was because of this. Happened after wheeling trips in which mud got in the drum area and self adjusted and then when the mud was gone I had a mushy pedal. Was kinda of a scary 2 hour ride home.
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
10-07-2017, 12:39 PM
I too have been dealing with awful brake pedal feel for nearly 2 years now. Today I fixed one of my rear cylinders and adjusted the rear brakes until I heard the drum scraping on the shoes. I still have an awful pedal feel. New rotors, pads, rear central brake hose. Bled several times. When adjusting the shoes how much is too much? If I adjust them to the point where turning is difficult, wont they rub and wear out the shoes?
__________________________________________________ ________________________
"Island Paradise" 1996 Toyota 4Runner SR5 2WD 235 75r15
10-07-2017, 04:34 PM
Real Name: John
Real Name: John
Well, if the adjusters aren't stuck they will adjust, but when you adjust them you adjust them until the brake drum hits the shoes not until the wheel is "difficult" to turn.
10-08-2017, 01:53 AM
I adjust them to the point where I can't spin them by hand. Driving around a little will make the pads be cunt hair away from rotor. And your ebrake will engage right away.
10-08-2017, 03:57 PM
Thanks for all the replies guys. The rears were adjusted to the point where the shoe was scraping the drum. I wouldn't say they are difficult to turn, but they were definitely touching the drum.
I know these things are self adjusting, but you need the ebrake to work right? My ebrake does not work.
It looks like the arm thing that connect in the drum (both sides) are seized up. This shouldn't affect the rear braking though right?
10-08-2017, 05:40 PM
To me they both need to be operating properly to adjust the rear brakes. That bolt on the ebrake arms has a clearance adjustment.
10-09-2017, 01:32 PM
does the pedal pump up?
adjust the rear brakes until you cannot turn the drum, then back it off a few clicks.
1985 pickup : EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5 : 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited : stock. Build Thread YouTube Channel
10-09-2017, 04:24 PM
I think the part that you are saying is seized up is the bell crank - problem is very common. You can replace them - did so myself and used Dorman part #924753.
Inoperable E-brake will not cause an issue other than the obvious - can't set the E-brake and can't readjust the rear brake shoes using the E-brake. Can still adjust the rear brake shoes manually. Other than that, and assuming bell cranks aren't frozen in the "applied" position, brakes still work normally....
Buckaroo
2000 T4R SR5 V6 (Retired) & 2005 T4R Limited V6
2002 & 2017 XLE Camry
2004 Honda Accord
2017 Tundra Limited DC 5.7L TRD 4WD
2024 Honda Pioneer 700-2 Deluxe
10-09-2017, 05:24 PM
I also have the same symptoms ever since I got the truck last Feb, granted I did NOT bleed the rear breaks but did the fronts after TBU upgrade. Soft brake pedal and e-brake not operational.
00 T4R LTD V6 4WD 275K e-locker
11 RAV4 LTD V6 4WD 100K
10-09-2017, 06:01 PM
If the E-brake is not operational or you are rarely applying it (my situation), you need to periodically adjust the rear brakes manually. If the rear brake shoes move too far away from the drum as they wear, the shoes will not hit the drum until the pedal has gone down a long ways. If the distance between the shoes and the drum is too great, the brake pedal may bottom out before they fully seat. No amount of bleeding will correct this problem. That said, unless the brake pedal is bottoming out on the floorboard, the brake pedal should be firm but just have too much travel under this condition. If the brakes are "mushy" (aka soft, spongy, not firm), that is typically an issue with air in the lines. If it isn't too bad, you can pump them several times and they will momentarily firm up. That is a bleeding issue. If the pedal firms up but then slowly sinks to the floor, that is typically a master cylinder bypass (or master cylinder seal) issue which requires replacement or rebuild of the master cylinder.
Buckaroo
2004 Honda Accord
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
