Old 09-28-2021, 12:51 PM #226
phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of
Originally Posted by papabeach View Post
I actually thought things shifted nicer after replacing with GL5 but perhaps that’s because the other stuff was dirty, though it was still somewhat clear. Time will tell…
If the shifting is good with the GL5 in there, just keep it. It will be *slightly* better for the gears and bearings. If you have any synchro issues, go back to the GL4 fluid.
Subarus and my Alltrac have to use a GL5 fluid in the manual transmissions - they share fluid between hypoid angle drives/differentials and the synchros... So it is done all the time. (I just use regular Valvoline 75w90 GL5 in those, changed often)
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 10-22-2021, 08:48 AM #227
papabeach's Avatar
papabeach papabeach is offline
papabeach has a spectacular aura about papabeach has a spectacular aura about
papabeach's Avatar
Last minute Tune Ups for camping season!
The Front Runner RTT quick release mounts paid off! 10 min install with the help of a friend this year. No adjustment needed. Simply incredible! Getting things aired out, batteries charged/replaced and getting excited. Fixed my drivers headlight housing where the pivot ball had popped out of its 20 year old plastic holder. Simply removed lamp/housing from vehicle, popped plastic clip out, placed over pivot ball and clipped back into housing. We will see how long this lasts. I also spent waaaay too much time trying to figure out why my third brake light wasn’t working. Found one cracked wire along the way in the infamous rear hatch area. Low and behold…I am an idiot. It is a third brake light not tail light! Once I tossed a dumbbell on the brake pedal I magically had current and simply needed a new bulb which I had laying around. Really felt dumb with this one…but I did find the one cracked wire and repaired it so it wasn’t all for nothing. 1st trip is next weekend!
Papabeach's Mod Thread-46c9f07e-86c0-46cf-bd87-7c131711532a-jpeg  Papabeach's Mod Thread-d867304f-b687-4a84-a7f9-ea1ca03bcf7a-jpeg  Papabeach's Mod Thread-db1caa08-1e22-4447-9c83-0cf802a376fb-jpg
1999 4Runner SR5, 5spd, 4x4 “Highlander”
Supercharged, Lifted, Dual cased, Dual Locked, Geared, Armored and more...
Papabeach Mod Thread
SOLD 1997 Land Cruiser FZJ80
1979 FJ40L-KC (build in progress)
papabeach is offline   Reply With QuoteReply With Quote
Old 10-22-2021, 02:10 PM #228
busmup808's Avatar
busmup808 busmup808 is offline
busmup808 has a spectacular aura about busmup808 has a spectacular aura about
busmup808's Avatar
Bra your truck is clean. Really like what you have done to your truck. Basically I’m in the process of what you already done with the truck. I’m just waiting patiently for my truck to come back to me and I can start putting all my parts on so I can enjoy it. Because I didn’t have my truck for a month, I will probably just enjoy it for maybe 2 weeks, then get dirty and start installing. Good job and thank you for your documentation, that’s why I am subbed to your build.
Busmup808 all day, all night!
busmup808 is offline   Reply With QuoteReply With Quote
Old 11-02-2021, 04:41 PM #229
papabeach's Avatar
papabeach's Avatar
Big upgrade in shade coming!
Papabeach's Mod Thread-78c8ec5e-098e-41a9-937b-8b3be5f86061-jpeg
Old 11-02-2021, 08:02 PM #230
busmup808's Avatar
busmup808's Avatar
Oh 270. I was looking into a different brand and the mounting of the awning would have to be high and I wouldn’t be able to install the L side of the tent because the awning would be blocking the hole for the poles.
Old 11-03-2021, 05:05 PM #231
papabeach's Avatar
papabeach's Avatar
Bush Company 270XT Max awning install on a custom Front Runner roof rack. Pretty excited I can access my table under the rack and still open the hatch! Shade for days!!!
Papabeach's Mod Thread-32afe3ff-2b93-4ce7-8782-1dffe7ebe469-jpeg  Papabeach's Mod Thread-f9e8db10-1cd3-4bf2-8431-756c124c035f-jpeg  Papabeach's Mod Thread-5745f23c-0eb3-4be4-9c17-537bc456fe1b-jpeg  Papabeach's Mod Thread-29af6e1a-a475-4554-b8e1-6d5622a3ed4a-jpeg
Old 11-03-2021, 06:34 PM #232
busmup808's Avatar
busmup808's Avatar
Did you source this locally or from South Africa?
Old 11-04-2021, 01:24 PM #233
papabeach's Avatar
papabeach's Avatar
I ordered here: Midguard Adventure - Everything you need for the perfect adventure
Old 11-22-2021, 10:30 AM #234
busmup808's Avatar
busmup808's Avatar
Much Mahaloz brother! Papabeach's Mod Thread
Old 11-24-2021, 11:58 PM #235
papabeach's Avatar
papabeach's Avatar
Loving the new awning! Gray to Black!!!! Woohoo. Thumbs up for a new Partner Steel Stove and freshly seasoned griddle.
Papabeach's Mod Thread-72478d5a-b6db-4f29-9b14-d36bc82d1a0e-jpg  Papabeach's Mod Thread-1cb6aafc-f1bb-448d-852a-e01acdc6e39b-jpg  Papabeach's Mod Thread-54a06823-a170-422d-b4ea-d75c8839a8b0-jpg  Papabeach's Mod Thread-f384a73e-06b7-4393-bc51-9541300c1efe-jpeg
Old 11-25-2021, 11:06 AM #236
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot is a glorious beacon of light Devbot is a glorious beacon of light Devbot is a glorious beacon of light Devbot is a glorious beacon of light Devbot is a glorious beacon of light Devbot is a glorious beacon of light
Devbot's Avatar
Real Name: Devan
That's a big ass tent!!
Y2K Highlander Millennium Silver 3.4L auto @ 295k and climbing
Tundra TRD Lift in Front / LC Lift in Rear / JBA UCAs / CVJ 9168R Axles / Diff Drop / PCK / Extended Bump Stops; Brake Lines; Sway Bar Links; Rear Diff Breather / True North Fab. Hybrid Bumper / Smittybilt XRC Gen 3 Comp. / Northstar 880CCA AGM / Drivelines NW Rear Shaft / Lil Skip Gas Skid / BudBuilt Front Skid
Old 11-25-2021, 11:55 AM #237
papabeach's Avatar
papabeach's Avatar
The wifey and I like to sleep in comfort! The kids sleep in a ground tent :-)
Old 11-25-2021, 04:30 PM #238
ThisisHuman ThisisHuman is offline
ThisisHuman is on a distinguished road
Whoa
Wowza!
This build is in tents.
get it?
Nice work.
I'm Jealous.
ThisisHuman is offline   Reply With QuoteReply With Quote
DHPham's 1997 4runner Build Thread (also 4wd swap thread) dhphamqc 3rd gen T4Rs 15 03-02-2019 03:08 PM
Bamatoy's not so clever build thread title...thread Bamatoy 4th Gen T4Rs 7 06-27-2017 03:33 PM
wyanrard's 2003 SR5 V6 build thread/picture thread wyanrard 4th Gen T4Rs 56 02-04-2017 01:03 PM
This thread is a build thread. TacticalSR5 3rd gen T4Rs 24 12-30-2011 05:35 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
