Old 10-27-2017, 11:29 AM #16
TorqueOfTheDevil's Avatar
TorqueOfTheDevil TorqueOfTheDevil is offline
Real Name: Charlie
TorqueOfTheDevil is on a distinguished road
Real Name: Charlie
Looks neat..
I DIY'd my kit (Twin batteries on parallel) with three earths from each battery (frame, body, motor) I always have massive issues with earth points... scrape off more paint and risk corrosion, or keep as much as possible at the risk of increased resistance?
The voltmeter is interesting... and pics of it installed? I assume there is a switch for it? - or is it on 24/7?
'96 Hilux Surf SSR-X Limited "The HiLex"
--VVTi 1UZ-FE--
-->Build Thread Here<--
TorqueOfTheDevil is offline   Reply With QuoteReply With Quote
Old 10-27-2017, 11:44 AM #17
I_bRAD I_bRAD is offline
I_bRAD is on a distinguished road
Originally Posted by 68whiskey View Post
Which part of it? The bigger wires say #2 welding cable, 600V. The smaller 8GA just says 8 gauge power cable.
Are there any CSA or UL markings on it?
1997 4Runner SR5 4X4 5MT elocker.
2005 Echo Hatchback 5MT.
1990 Volvo 740 Turbo sedan.
1991 Volvo 740 wagon.
2000 Mercedes E55 sedan.
I_bRAD is offline   Reply With QuoteReply With Quote
Old 10-27-2017, 12:07 PM #18
MattJakobs's Avatar
MattJakobs MattJakobs is offline
Real Name: Matthew
MattJakobs has a spectacular aura about MattJakobs has a spectacular aura about MattJakobs has a spectacular aura about
MattJakobs's Avatar
Real Name: Matthew
What do you recommend doing, just riding it out until that happens? Also, did you do the install, and how did that go?
The install isn't bad at all. Just make sure you have nothing going on if worst comes to worst cause you're car won't start mid install haha.
Running the new wires is the easy part. Pulling and removing the old wires is a little tedious though. I actually left the factory wiring in for some time because it's such a tedious job and I hate wiring.
As long as you don't plan on disconnecting your battery a lot, you should be good with the clamps provided. After doing the wiring, I replaced my starter, added an auxiliary fuse box, and several more accessories so my terminal clamps were being connected and disconnected quite a few times.
After several times of my 4Runner not starting and having to move the clamp around, I decided to go with these because they're pretty much dummy proof.
I just used generic battery clamps from West Marine. Also got tin plated copper lugs since they fasten differently to my new clamps. Pictures of what I used Here. I kept all the wiring in the kit when I did this as well cause it is really nice wiring, I just added the new lugs to clean everything up and make good connection.
2002 Stellar Blue Pearl - Build Here
Instagram: mattyjako
MattJakobs is offline   Reply With QuoteReply With Quote
Old 10-27-2017, 12:20 PM #19
68whiskey's Avatar
68whiskey 68whiskey is offline
68whiskey is on a distinguished road
68whiskey's Avatar
Not that I can see. Its TEMCo wiring. Heres the link:
https://temcoindustrial.com/temco-wc...-5-ft-red.html
2002 SR5 Sport Edition --> A work in progress.
68whiskey is offline   Reply With QuoteReply With Quote
Old 10-27-2017, 12:24 PM #20
68whiskey's Avatar
68whiskey's Avatar
Originally Posted by TorqueOfTheDevil View Post
Looks neat..
Haven't done the install yet. Hopefully within the next week or so. Voltmeter is constant from what I understand. I suppose its interesting to see what you're running in real-time.
Old 10-27-2017, 12:29 PM #21
Real Name: Charlie
Real Name: Charlie
Yes... but leaving it sitting for a couple of weeks with constant drain is never great!
Then again it might consume less than an alarm.
--VVTi 1UZ-FE--
Old 10-27-2017, 01:03 PM #22
Scramble's Avatar
Scramble Scramble is offline
Real Name: Scramble
Scramble has a spectacular aura about Scramble has a spectacular aura about
Scramble's Avatar
Real Name: Scramble
I bought that kit, great quality even though I haven't installed it yet. I already installed a 160amp alt from Quality Power & the factory wire hasn't caught fire yet. ;-)
____________
'99 4Runner - 2.7L 3RZ, 5 Speed, 4.56 Gears - Lifted, Locked & Loaded - 166k Original owner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
'99 Limited - E-Locker- Stock (for now) - 233k 2nd Owner http://www.toyota-4runner.org/3rd-ge...ted-build.html
Scramble is offline   Reply With QuoteReply With Quote
Old 10-27-2017, 01:23 PM #23
Bijan's Avatar
Bijan Bijan is offline
Bijan is on a distinguished road
Bijan's Avatar
Does the guy who sells the kits post on here?
2002 SR5 // Lifted // Armored // Blown // OPN DFFS
BUILD
Bijan is offline   Reply With QuoteReply With Quote
Old 10-27-2017, 01:25 PM #24
68whiskey's Avatar
68whiskey's Avatar
May not be the best thing, but if it drained the battery after a couple of weeks I feel like there are bigger issues. Im looking at batteries now, definitely need to upgrade.
Old 10-27-2017, 02:08 PM #25
68whiskey's Avatar
68whiskey's Avatar
Taco forum.
https://www.tacomaworld.com/threads/...pgrade.311091/
Old 10-27-2017, 04:46 PM #26
MN4runnerman's Avatar
MN4runnerman MN4runnerman is offline
Real Name: Samuel
MN4runnerman will become famous soon enough
Real Name: Samuel
He’s also on this forum. Bumper2bumperauto
2001 Sport Edition 4WD, IJM, Auto, DD
1999 SR5 4WD, Millennium Silver Metallic, 5 speed, E-locker, Trail Rig
1998 SR5 4WD Custom bodywork from hitting a median. Beater truck.
1999 Limited 4WD No longer a vehicle. Now it's in parts and stored away.
MN4runnerman is offline   Reply With QuoteReply With Quote
Old 10-27-2017, 04:53 PM #27
Scramble's Avatar
Real Name: Scramble
Scramble's Avatar
Real Name: Scramble
Thumbs up
@Bumper2Bumper Auto
____________
Old 10-27-2017, 06:00 PM #28
68whiskey's Avatar
68whiskey's Avatar
I had no idea. I was referred right to the Taco forum. Good to know.
Old 10-27-2017, 06:40 PM #29
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
I read a post somewhere about running the volt meter in the connector off a switched hot. To me, it's useless under the hood anyway but it does look cool.
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 10-27-2017, 06:51 PM #30
Scramble's Avatar
Real Name: Scramble
Scramble's Avatar
Real Name: Scramble
He frequents that board more often.
____________
