I recently purchased a Stage 1 Big 3 kit from BamaToy1997 on the Taco forum. 4Running Daily pointed me in his direction. Received the kit today, couldn't be happier. The quality is great, and he included an install sheet should I have any questions. I purchased a kit for the sake of convenience. I needed to get the mod done, but I do not have the time to sit down and make it. Now the search is on for a battery! Alternator to come soon enough, I don't see the need just yet since mine is still working just fine. If anyone out there wants to do the Big 3 upgrade but doesn't have the time or technical prowess to get it done, I would definitely recommend getting ahold of this guy to get it done. I think 4Running Daily has a post about the kit. I attached a few pictures as well. Theres a small red 8 gauge wire hidden under a 2 gauge from the positive terminal, but its there.
The kit was $140. Well worth the cost in my opinion. I waited about 3 weeks, a timeline given to me before I made the purchase. Im sure some prefer to spend less and do it on their own, but I knew I wouldn't get it done that way. Hopefully I'll be able to get it on the truck sometime in the next week or so, definitely before the snow starts to fall.
2002 SR5 Sport Edition --> A work in progress.
I'd love to see complete pics (of the whole kit) and peek at the installation instructions
Heres a picture of the whole thing, positive and negative, as well as a PDF of the install instructions. Hope this helps! With the closeup pictures I originally had posted, as well as the whole view, it should give you a pretty good idea of the product.
New terminals, positive terminal has a digital volt gauge built in, and all cables required to complete the Big 3 upgrade. Assembled and ready to go in. Quality stuff used, and the build quality itself is great. Along with the install sheet, all I have to do is put it in. This is the most basic kit, and they go up from here. High-output alternator can be added, dual battery setup, even a solar charging system. Since I only wish to do the cables, terminals, and a battery, I went with stage 1.
Reason: Additional Info
I bought 2 kits during the group buy he had. Honestly if you don’t have the time then this is the kit to get. I have no complaints and it’s all quality stuff. I’d much rather replace all of the wires with this kit than add wires like others have done. It’s got all you need from starter to alternator to fuse box. And engine ground to chassis ground to battery.
__________________ 2001 Sport Edition 4WD, IJM, Auto, DD 1999 SR5 4WD, Millennium Silver Metallic, 5 speed, E-locker, Trail Rig 1998 SR5 4WD Custom bodywork from hitting a median. Beater truck. 1999 Limited 4WD No longer a vehicle. Now it's in parts and stored away.
Completely agree. Pulling all the old stuff out and putting this in will be great. I was thoroughly impressed when it arrived today. Did you do an alternator or battery as well?
Yeah I put a cs144 alternator in and an Exide 24 series AGM battery. I don’t have a lot of aux stuff just one 10” light bar and a cb radio, maybe a winch down the road. So it’s more than enough. In my other truck(01) I kept everything stock except for this kit. I might take my stock alternator to a local rebuilder and see if they can do what Quality Power does and up the rated amps while keeping the stock case.
Awesome, thank you!
The instructions mention both 2 GA and 4 GA cables - the cables in your pics look to be the same gauge. Is that just an optical illusion?
Also, are you going to reuse the plastic wire loom from the factory or replace with new when you install?
. 1999 Toyota 4Runner SR5 Sport 4WD, V6 5-Speed e-Locker-> 4WD 4runner Journal Thread 1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread 1959 Chevy 3100 1/2 Ton Pickup EVERYTHING done 'cept paint and body
All of the wiring is 2 GA except for the 8 GA wire that runs to the fuse box. I think that at some point the kit may have changed a little. This is also for a stage 2 kit that has the alternator, maybe that changes things as well, I'm not sure. Either way, the instructions are the same minus the alternator. Ive seen a little variation as the kits have progressed.
I think I'm going to replace the plastic as well. Being an 2002, that plastic is almost 16 years old and has seen 276k miles. I feel as though reusing the old plastic is just asking for a headache. The plan is to wrap it again and run everything tight.
Yeah, thats kind of where I'm at at this point. The factory wiring looks tired and corroded. The alternator is fine for now, so I plan on just doing this kit and a new battery for the time being. Im not running anything that needs power at the moment, and for now only plan on doing a light bar once I get a rack on top. If/when I decide to add a winch, ill more than likely do that alternator as well. We'll see how things go.
I'm running this kit and have been for about two years now and it's worked great. One thing to keep in mind though, I have had to replace the battery terminal clamps as have a few other members. The allen head bolts that tighten the clamps to the actual terminals have been known to strip out. Besides that, awesome kit and good luck with install.
2002 Stellar Blue Pearl - Build Here
Instagram: mattyjako
What do you recommend doing, just riding it out until that happens? Also, did you do the install, and how did that go?
