Old 03-30-2019, 08:48 PM #781
TonyB66's Avatar
TonyB66 TonyB66 is offline
Real Name: Tony (no surprise)
TonyB66 has a spectacular aura about TonyB66 has a spectacular aura about TonyB66 has a spectacular aura about
TonyB66's Avatar
I made some progress towards the install...
I removed those OEM bumper supports that were taking-up a couple inches of vertical space near the frame rail ends.
While I did a pretty good job of drilling-out the spot welds, a couple areas penetrated through the floor. I decided to cut some pieces of sheet metal, and pop rivet them in place, with liberal amounts of 100% silicone in between...
Both sides done and painted black. No photo at this time, but I'm sure they will be seen in a later post...
The tank brackets and holes line-up well.
I put a small bead of 100% silicone at each end of the tank to serve as a cushion of sorts.
I applied the black 100% silicone on the top side of the platform where the angles join the plate.
I went to the The Home Depot, Lowe's and Harbor Freight today to find items to fill my on-board tool bag. I got this plastic ammo can for 4 bucks.
A few will fit in this newly created storage space, but I was pleasantly surprised how it fits here.
I moved the 4Runner onto level ground, got the rear on jack stands, and removed the driver side wheel. All set for the install tomorrow...
2000 Limited, E-locker
Maintenance/Build Thread
TonyB66 is offline   Reply With QuoteReply With Quote
Old 03-31-2019, 04:50 PM #782
TonyB66's Avatar
TonyB66's Avatar
While laying under the rear of the 4Runner, looking up through the hole, I saw why the rear hatch light was not working. The bulb was not in place. I thought it had simply popped-out, but nope.
With the Tahoe trip this Sat, I'm hoping this will be an easy fix... Any input, please do share. I'll search the forum later.
Old 04-01-2019, 11:46 PM #783
TonyB66's Avatar
TonyB66's Avatar
With the past weekend our last before our trip, I had less time than I had hoped. But, I did get everything installed, filled the tank and transferred the fuel to the main tank, although not as I had hoped...
This time got the tank in place first, holding it as seen here.
After lifting the plate into place, for those 3rd bolts on each frame rail, a breaker bar worked great to secure the nut while I tightened from below.
On the passenger side, because of the exhaust, I had to use a wrench to get on the bolt head. I slid a pipe over it to get more leverage. All six bolts are very tight, blue thread locked in place.
Wanting to limit the amount of water going into the storage space, I got a 3' piece of aluminum angle and trimmed it to fit nicely onto the bumper. Here it is drying.
And installed.
Some water can still enter through those holes, and I might address that later, but not sure. A little water is not going to hurt with what I'll have down there...
Before I forget, I went to back to Harbor freight and got 5 more of those ammo cans at 4 bucks each. They are stackable, which is nice. I should be able stack two comfortably in that side storage area...
The tank valve required some cutting as the knob was hitting the top of plate. A Dremel cut-off wheel worked well.
Some blue fingernail polish on the exposed metal.
That did the trick. I might cut the other one too... Valve open.
I tried making a video of me filling the tank, but it's not worth watching, so I deleted it. Not easy to hold the phone while working the pump, at least for the first time. I will say that the floor did indeed keep the nozzle from going too deep into the tank. I got like 4.2 gallons in it with little problem. I had some paper towels ready in case I had an overflow situation. They were not needed.
When it came to move the gas into the main tank, I was able to get about 3' of hose down the fill neck. I surmise that I need to go about 1 more foot to get a syphon flow. I just couldn't get it to turn that corner. That said, I got about 3 1/2 gallons transferred just working that bulb. I know because I later decided to fill a 1 gallon gas can, and got it about half full. I will eventually rig-up that fuel pump I showed earlier. Here is the fuel hose with prime bulb drying after I cleaned it...
For all the weight-savings I had been noting along the way, I add quite a bit here. The plate, with 4+ gallon tank (empty), brackets and hardware - 72 pounds. I had previously removed spare tire support at 20 pounds, so a 52 pound increase in that spot. Increased weight down low is better than up high though. The added space for an 18" tool bag, recovery bag and spare parts is worth it, I feel.
Old 04-06-2019, 01:37 AM #784
TonyB66's Avatar
TonyB66's Avatar
Some minor updates before our Tahoe trip tomorrow...
A free Harbor Freight 5x7 foot tarp and small mover's blanket for one buck are now on the floor of the storage area.
The only time I had to wrench on my FJ40 when off-roading, I was on my back in the mud, wishing I had something like a tarp and/or blanket...
I tightened everything up really well, used the black silicone between the stitch welds, some paint and of course fingernail polish so i can easily monitor for any loosening.
I still don't have a hard cover yet, but I cut the mats as seen here.
For now, this is what I have in that 18" tool bag... The item on top is a telescoping magnet.
I don't quite have the sockets 100% figured-out. As an example, I thought there was no need for a 13mm, but if I need to remove the front skid, that comes in handy (probably 1/2"). Not wanting to break-up my existing sets, I'll buy a couple more sockets later.
Yup, I like vice grips...
Cutting, filing, brushing...
2 foot zip ties and some 1-footers, some metal, 16 gauge baling wire, fusion and duct tape...
Electrical.
Black pouch open...
In all, that stuff in that tool bag, about 24 pounds. Here it is in place. The space to the left is wide open. I'll work on a recovery gear bag when back home.
Checked all fluids, air pressure in the tires, Rain-Xd the windshield, filled both gas tanks...
Old 04-06-2019, 02:31 PM #785
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy will become famous soon enough JZiggy will become famous soon enough
JZiggy's Avatar
Nice work Tony! The compartment is cleanly hidden.
I found one of the HF boxes and it does fit nicely in the cargo area. Thanks again for the tip. It cleaned up my storage back there nicely.
"Check out that four by four, that thing is hot!" - Marty McFly
1999 4Runner 3RZ/W59/4WD
JZiggy is offline   Reply With QuoteReply With Quote
Old 04-06-2019, 11:37 PM #786
TonyB66's Avatar
TonyB66's Avatar
Thanks man. Glad you got one of those HF boxes too. They are stackable, and I think two of more would go in that storage area, if desired....
In Tahoe now. Just got groceries and about to start cooking dinner in the cabin...
What a difference that tranny cooler made. As a reminder, last year on the way to Tahoe, up 80, I hit 230F a couple times and I pulled-over to let it cool. That was with the factory cooler and OD on (I didn't know at that time about turning OD off).
This year, with the factory cooler replaced by that aftermkt one, and with OD off on the inclines, I saw 143 for a high up that same grade! 138-141 most of the time.... Was doing between 65-70 mph. I saw 165 for a high on the trip in stop/go traffic in the Bay Area up a hill. Would have been lower if I turned OD off.
What makes this even more impressive is that last year our trip was in Feb, with much cooler ambient temps. Also, last year my 4Runner didn't have aftermkt bumpers, skid plates, sliders, that rear storage plate, extra fuel, tools and supplies. I carried much more weight this year in warmer weather and saw markedly lower tranny temps. Very happy.
Old 04-13-2019, 10:55 PM #787
TonyB66's Avatar
TonyB66's Avatar
Back from Tahoe. I think we'll be doing our annual Tahoe trips in early April every year...
The 4Runner ran like a champ the whole time. When home, I transferred the extra fuel to the main tank using the hose and primer bulb. It took about 15 minutes to move those 4+ gallons. I'll have a better/faster method, but in a pinch, this manual way is not that bad at all...
I don't plan to haul tools all the time, just when we go on trips and when I begin off-roading. So, I removed the tool bag and I was happy that I was able to get that 18" bag out of the hole without needing to take-out any tools. With an ARB snatch strap coming next week, the recovery bag will be complete. That too will fit in that space with ease, along with the tool bag.
To ensure that I tightened the gas cap all the way, I marked it.
Not sure yet how I'll use the space where the factory jack was located, but i have some ideas. For those who care, just a tad under 7 pounds.
With Tahoe behind me, my wife about 80% recovered, next up are the Kings in the front and the SPC UCAs. Wheels/tires too...
Old 04-14-2019, 03:07 AM #788
BrianSD_42's Avatar
BrianSD_42 BrianSD_42 is offline
Real Name: Instagram: briansd_97r
BrianSD_42 is a jewel in the rough BrianSD_42 is a jewel in the rough BrianSD_42 is a jewel in the rough
BrianSD_42's Avatar
Glad to read the trans cooler is working out well. Any pics from Tahoe? Did you ski?
Btw regarding this rumored Kings front suspension upgrade I'm not sure which one I've been waiting for a longer amount of months: Game of Thrones season 8 or the first hand report on these 650lb Kings coils .....
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giantís robe, Upon a dwarfish treasonous thief.
BrianSD_42 is offline   Reply With QuoteReply With Quote
Old 04-14-2019, 12:23 PM #789
TonyB66's Avatar
TonyB66's Avatar
Hey Brian.
Truth be told, on the morning we were to leave for Tahoe, we almost didn't. I was emailing my wife's surgeon with questions/concerns right up to about an hour before leaving...
Suffice it to say, with her not being very mobile and not feeling well, it was a low key trip. The kids were quite happy though with sledding, snow ball fights with Daddy, snow angels and just playing in the snow. I helped them make a tunnel, which took quite a while, but very worthwhile. I'll always remember when we joined hands from from our respective holes, the excitement in their faces. We then excavated enough so each could fit through. Got some cool video and photos that my wife is compiling... Oh, I also did some ice skating with them at Northstar. Surprised I still remember how to skate, even backwards! I learned to ski at Northstar 40+ years ago. It was surreal being back there, with my own little ones. I checked and will get them skiing next year. I brought-up some DVDs, and we watched movies every night in the cabin. They had fun and the wife's health improved too.
If there is one photo I wish I would taken, it was when I was in the hot tub one early evening. I was the only one in, it was raining and turned to light snow. There was enough sunlight left to see the lake glistening through the water's steam. Could have been an awesome shot, I feel. It's in the memory banks though. I'll bring my phone to the hot tub next time!
I used the AWD for a little over an hour in total. Nothing more was needed. I remain very satisfied with the purchase of the 3rd gen.
Oh, I sold the rear trailer hitch for 75 dollars. So, the updated list of items sold:
$400 - Leather Front Seats
$50 - Factory Stereo & Amp
$75 - Cargo Privacy Cover
$50 - Skid Plates (2)
$150 - Rear Bumper
$25 - Spare Tire Crank
$200 - Front Bumper
$50 - Roof rack cross members
$50 - Front bumper carrier
$75 - Trailer hitch
That's $1,125. Curious what I can get for the wheels and tires...
Of note, I've now sold the entirety of the front and rear stock bumpers for a total of $475. Certainly helps offset the costs of the aftermarket ones.
Will start reading-up on installing the Kings and those SPC arms. I recall that that I should use the G setting on those. With my 4Runner not fitting into our low garage opening, not having a good level surface, I'll likely check with Tim to see if he can help. He was open to such earlier in the year. His experience and tools would be welcome for sure. I'm not even sure if I have the correct separator for the job. I need to re-watch one or two of his videos...
Old 04-18-2019, 12:43 AM #790
TonyB66's Avatar
TonyB66's Avatar
If I can get the utility trailer mated-up with the Savage rear bumper, I might haul the five tires and wheels to Tires Unlimited Silicon Valley this Saturday morning. I didn't exactly shop around, but $125 seems reasonable...
With those done and waiting, I'll do the front Kings and SPC UCAs. I did a fair amount of reading, and I think I have the tools needed for the knuckle. If so, I'll set the SPC UCAs at "G for max clearance, and for max caster, on the LCAs, the front cams rotated inward, and the back cams turn outward, both to the max. That's the plan, then to a shop for an alignment, where adjustments will be only on those LCAs (camber and toe refinement). Apparently Tires Unlimited Silicon Valley also does alignments.
For now, I have this for recovery gear. The yellow utility/tow strap is a Harbor Freight special that I plan to use for moving fallen trees, limbs and other such work... I learned from Roy at Savage that his bumpers take a 7/8" pin, so that's what I got.
And in this duffel, where the contents sit nice and flat. I believe the bag should fit in the lowest vertical space at the very rear of the storage area. If so, that still leaves plenty of room for other items.
Old 04-18-2019, 06:52 PM #791
BrianSD_42's Avatar
BrianSD_42's Avatar
Sorry to hear about the tough part of the Tahoe trip. I wish your wife the best and a speedy recovery.
Tahoe is an awesome place. I used to go up there every year with my parents, driving from San Jose.
The bag and storage box look like they are working out well. Maybe add a few road flares for safety?
Old 04-18-2019, 07:50 PM #792
TonyB66's Avatar
TonyB66's Avatar
Brian, thanks for the well-wishes. She's just starting to take the kids to school and pick them up, so getting better...
Great idea - flares. Will get for sure. I have space. Super happy with this mod.
I don't need my utility trailer to get the five tires and five wheels to the shop.
I got all of the labels off the tires. I've seen places spin them with tons of stickers on them...
On a related note, and I don't think I mentioned this before, but I'm a somewhat active investor. All mods have been financed by the selling of covered call options. Today, which is why I bring it up, I collected $2,800 from selling AAPL calls (215 strike, 10 May). I do such every month or so, also with SPY and QQQ positions. I allocate some of the proceeds to this build. I do the same with other projects, but failed to mention such here until now....
Old 04-20-2019, 06:31 PM #793
TonyB66's Avatar
TonyB66's Avatar
While no work was done today on the 4Runner, I was able to make it down to the tire shop. Was there 15 minutes before they opened, and first in line.
A little less than 30 minutes for all five... Got them back home and feeling motivated to get them on sooner as opposed to later. Wish there weren't so many weeds to cut.
Not true 33s of course. A bit more than 32 3/4".
Next up...
Old 04-23-2019, 12:50 AM #794
TonyB66's Avatar
TonyB66's Avatar
With much of Easter Sunday with the family, I had only a little time to get some work done. And, with a little time today, removal is now complete.
First, the flattest most level space outside the garage is on a patch of dirt on the side of the house. So, that's where I set up.
First, I took some measurements. In the rear, I put the new spare, the tool and recovery gear bags. Here's what I got.
If the Kings make for about a 2" lift out-of-the-box, that might work-out well for me...
With that noted, I got busy. I also marked exactly where I parked or positioned the tires so when I take those measurements again, I can make sure I do so in the same spot.
I continue to be a fan of jack-able jack stands. Added the floor jack simply for back-up support, applying light upward pressure only.
The factory shocks were removed with no problems, three 14 mm nuts on top and a 17 mm at the bottom. The ABS lines were disconnected at three spots on each side so as to prevent any tension on those. The UBJs popped-out with ease. Not keeping them, so I went this route.
Not having a deep enough socket the correct size to drive the UBJs, I shortened them.
Forgot, I removed retainer clip before the cutting...
I couldn't find my C press or ball joint kit. I now believe those were stolen years ago at our old house where I had those in a shed for a while as we prepared to move. I knew a couple things were taken, but just realized that those were in there too. Drat. So, I got creative...
Had to really crank-down...
While I tend to believe I could have made this work, I saw the C-clamp starting bend under the force and decided it best to back it off. Went to Harbor Freight got a kit there with pretty solid reviews and a 25% discount helped...
They popped-out with ease.
Of possible note, by disconnecting the sway bar links I was able to lower each knuckle with a floor jack to a good spot that allowed for sufficient space or clearance.
UCA removal went well too. The long bolt on the driver side required the movement of the battery hot lead bracket and the bracket for this connector under the battery box.
With those long bolts out, removal was complete.
I will do some light rust removal and cleaning next before the installation of the Kings and SPC UCAs...
Old 04-25-2019, 11:20 PM #795
TonyB66's Avatar
TonyB66's Avatar
Oil Change #2 - 195,763 Miles
With the current access to the oil filter, I decided to use this time to change the oil for the second time. I noticed that King only provided 3 bolts and 3 washers for the installation. Each coil-over needs three for the top mount, so King will have those here tomorrow... Very fast support.
My first three oil changes will see Seafoam treatment.
I put about 6 ounces in yesterday (about an ounce per quart), and let it idle for about 15 minutes. I ran it again today for about 20 minutes, and then let it drain. I like draining oil when it's hot, and now with the Fumoto valve, this is so easy to do.
I put the rest of the Seafoam in the gas tank...
I used this with a ratchet and extension to loosen the oil filter.
I'm still not that good with a clean removal. It was messier than what I had hoped. Maybe I'll improve next time. I let it drain for a few hours while I attended two meetings for my employer. I got out this much out.
UPS arrived with the oil filter, actually five of them. Toyota OEM and these came to about 5 bucks each. I saw a little better deal for 10, but that was not Amazon Prime delivery, and I wanted to do the oil change today.
About 5 1/2 quarts filled her up. I then used a power washer with some Simple Green to clean the spilled oil.
Tomorrow (Friday) I get the hardware from King and also five Gorilla wheel locks. The SPC UCAs and King coil-overs should get installed this weekend.
AssBurns 2000 Limited Build Thread AssBurns 3rd gen T4Rs 490 Yesterday 08:52 PM
GGFerrier's 2000 Limited Build Thread GGFerrier 3rd gen T4Rs 228 01-05-2017 03:39 AM
HammerTime's 2000 Limited Adventure/Build Thread HammerTime 3rd gen T4Rs 2 06-03-2016 01:31 PM
MrHentoni's 2000 Limited 4x4 Build Thread MrHentoni 3rd gen T4Rs 72 02-10-2016 01:38 PM
Ride_Red 2000 Limited Build Thread Ride_Red 3rd gen T4Rs 67 09-26-2014 12:12 AM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
