I had a HUGE WIN today..
I was buttoning the dash back up & FINALLY got the new keys to be programmed with my ECU...
I’m not going to lie, it took a couple attempts... I was waiting for the red security button to stop flashing for way longer than the time I waited when I did this to my other build...
On my other rig, the red security light stopped flashing after only 20 seconds (instructions state it could take up to 2 minutes!) but finally after ~ 60 seconds the light stopped blinking, I removed the key & finished the sequence with pressing down on the gas peddle.
I confirmed that it worked by starting the truck & then programmed the second key, & this time I was a little more patient waiting for the red light to stop blinking. STOKED!!!
But I celebrated a little too early because my attempts to program the key fobbed failed miserably!!! I actually got it into programming mode on the very first try but somehow the FOB didn’t program!!! I tried a bunch more times with no success to get it back into programming mode so sad times... I was confused because I got it into programming mode the first attempt but couldn’t get it after that... I even attempted on my
2002 which I had successfully programmed in the past & I couldn’t get it to bite either... I gave up & went inside to try it again sometime in the future. The biggest pain in the butt about this is the locks get tired & then don’t even move! The lock solenoid gets tired & then none of the locks go up or down. Fricken sucks.
