Old 11-20-2017, 12:49 PM #1
Majindan's Avatar
Majindan Majindan is offline
Real Name: Dan
Majindan is on a distinguished road
Majindan's Avatar
Real Name: Dan
Exact battery cable lengths for OME replacement with OEM battery oriented posts.
I've been through too many "The Big 3" threads and still not clear on the exact lengths needed for both the positive and negative cabling lengths and what size lug eyes for each end of them.
Looking at replacing positives from batt post, and the negatives from batt post. That's it. I can't find a local place I can buy them by the inch off a spool so I'm searching Amazon etc but need the lengths and lug sizes.
2016 Trail Premium Nautical Blue; 1.75" Bilstein 5100 w/Corn Fed spacer set; 275/70/17 Cooper AT3; CaliRaised ditch lights w/low profile bracket kit; ARB rear diff breather; TRD air intake
Majindan is offline   Reply With QuoteReply With Quote
Old 11-20-2017, 02:33 PM #2
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Buy 10' of each, and if you are doing a big 3, then there are 3 gauges of wire used
2GA for POS and NEG mains
4GA for alt to fuse box
8GA for NEG to fender well
If you just want to freshen up the wiring, and aren't going to run extra load, you can go 4GA across the board (omitting 2GA) since that is about stock gauge
Either way, reuse the POS BAT to fusebox cable since it's a bear to R&R
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 11-20-2017, 02:46 PM #3
Majindan's Avatar
Real Name: Dan
Majindan's Avatar
Real Name: Dan
Is the alt to fuse box hard to remove on the fuse box end? Thanks for the help, this wiring is going towards fixing my emissions problems in my other long drawn out thread lol.
Old 11-20-2017, 02:57 PM #4
No, the alt to fuse box is easy, it's the big bolt on the top on the inboard side. The battery to fuse box is not easy to remove, LOL, which is why the commercial Big 3 kits recommend leaving that one in place.
HELP! Battery Cable not long enough for new battery TerraCrawler General Discussions 11 08-02-2017 10:24 PM
Battery Cable Harness Help T4Rfirefighter 3rd gen T4Rs 3 03-07-2015 08:21 PM
Starting/Battery Cable Issues walkerwl Maintenance/Detailing 1 11-11-2014 03:16 PM
Need Help! I'm STUPID! Battery Cable in 2004 V6 dpross16 4th Gen T4Rs 7 08-11-2014 10:18 PM
+ Battery Cable Replacement Here2There 3rd gen T4Rs 12 12-19-2010 03:08 PM
