Old 03-02-2018, 10:48 PM #46
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
Originally Posted by JZiggy View Post
Hey sleepydad,
I've replaced the bearing in the AC clutch before but never thought to inspect the clutch material. Can worn clutch parts cause noise? My AC compressor has a funny noise at idle and not running, and I know the bearing is fresh. Maybe this is the culprit?
Can you take a look at this page on my thread where I R&R the AC clutch bearings and see if you can tell about the clutch material?
JZiggy's "Grown Up" 4Runner Build
Thanks!
If the AC is off the clutch should not be touching at all. I would take off the belt and turn it, huge pain but if your clutch is rubbing without being turned on, that is bad.
Your clutch plates look plenty well along but as long as it’s not sloppy and not rubbing when off it should not make any noise.
Mine was just sloppy and worn beyond.
Old 03-02-2018, 11:27 PM #47
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
Originally Posted by prcGTI View Post
Great updates and build on your rig, very nice. I'm jealous and itching to get started on some updates and mods myself.
Thanks man I always think I’m done doing things but then... I read the builds and get all kinds of crazy plans going.
Old 03-07-2018, 02:44 PM #48
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
leaky dipstick o-ring replacment
has been leaking around the bottom for sure maybe this will fix it, figured hey get the top and bottom. splurge!
2000 limited SleepyDad build
Old 03-07-2018, 02:48 PM #49
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
supercharger
picked up the URD crankshaft pulle, my old one had some chunks missing. looks like somebody used a prybar or dynamite to get the old one off at some point. it was not eating belts but... this one is sexy as hell.
while tearing down I notice my vac lines tended to break into multiple pieces so I picked up various sizes from 2mm-10mm and replace as I go.
pile of parts... still waiting on a couple of things so I'm stuck until next week I think.
all tore down, now if it would quit storming so the parts would arrive...
air hose rubber things were not doing so well... ah it's only money
finally got it done and fired her up
sexy sex sauce
Old 03-22-2018, 06:17 PM #50
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
ram mount A pillar
Stealing from Tacoma
I need one more spot to put a phone for my driver’s seat Tacoma guy are the best, stole it from them.
I think the cap head allen is m6x1.0 x 55 mm just got it at home depot. the stock hardware that comes with the ram mount is m8 and will not work in the toyota grab handle socket.
cut a small aluminum spacer.
screw it into the stock nut and we got a ram mount.
it's not exactly in the spot I would have liked but.... it's good enough and it's not really in the way. I might try grabbing a shorter bolt but for now I like it. 40mm length might work better?
Old 03-22-2018, 06:26 PM #51
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
this works pretty well... was able to get my broken scuff plate secured back down with all the screws. for now this will work but I'm thinking of trying rivnuts as a better long term solution.
the scuff plates in my truck have been removed one too many times.
you can get nylon inserts at NAPPA
I cut the existing little finger tabs things that spread out off my sill plates. no going back now.
they fit pretty good with the stock tapping screws
put one in each of the holes where the little spread fingers from the scuff plates once lived
screw them downtown!
Old 03-22-2018, 06:44 PM #52
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
Last two @sleepydad posts = GOOD TECH
Thanks man!
JZiggy is offline   Reply With QuoteReply With Quote
Old 03-22-2018, 07:33 PM #53
FG4runner's Avatar
FG4runner FG4runner is offline
FG4runner is on a distinguished road
FG4runner's Avatar
Awesome idea. I need to do something like this too because the only thing holding down my driver side scuff plate is my Weathertech mat..
FG4runner is offline   Reply With QuoteReply With Quote
Old 03-23-2018, 09:09 AM #54
nchacon1984's Avatar
nchacon1984 nchacon1984 is offline
Real Name: Nelson
nchacon1984 is on a distinguished road
Real Name: Nelson
Originally Posted by sleepydad View Post
coming soon, with youtube vid
Curious to why you had to replace this and also looking forward to a video how to install a new one. My windows stopped working and is causing a parasitic drain, the shop that I took it to said I would have to replace mine in order to get them to work.
nchacon1984 is offline   Reply With QuoteReply With Quote
Old 03-23-2018, 10:19 AM #55
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sorry I did not shoot a vid, was alone and shooting up under the dash is impossible without a helper. I will edit that post and remove that.
but...
so my power locks stopped working with the keyfob or button I think. I could unlock everything but not lock, there are mini relays inside the drivers side block that burn out eventually. if Toyota had just done standard auto relays you could just replace the relay but because they are inside the block assembly you have to replace the entire thing.
I was while doing it so... it's not hard but it's a pain getting all the wire connections off. pretty sure all the connections were unique so you can't screw it up. as long as you take your time it's really something anybody can do. Took me 30 mins, if you take everything apart and get it so you can flip the block assembly around and get at the connections it's much easier.
also a little pick tool or mini screw driver to get at some the connection clips off helps. I hate up under the dash more than any other repairs.
This was a really common problem with Toyota block assemblies I know a bunch of different models had similar block assemblies and they all had these strange little failures. if you do a search I know some people have taken the block assemblies apart and replaced parts of it but it requires solder, diodes, resistor I'm not that ambitious.
Part No.: 82730-35260
BLOCK ASSY, DRIVERS
it's not cheap $230-$250 you might be able to find it cheaper someplace else?
Old 03-23-2018, 12:25 PM #56
Real Name: Nelson
Real Name: Nelson
but...
BLOCK ASSY, DRIVERS
thanks for the reply. seems like we both have the same problem but mine is draining my battery as well. The shop said to replace the whole unit so I went ahead and purchased a new one. Hopefully that fixes the issue.
Old 03-30-2018, 07:28 PM #57
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
Transfer Case gaskets and shift bushing
while doing dynamat I discovered some jackwagon just decided to cut the transfer case boot
instead of removing the 8 bolts... and unhooking the shift linkage... lets just cut the boot. what kind of sick human being does that?
so... off for some parts. I know the transfer case shift seat bushing pretty much disintegrates at some point and I'm pretty sure the only way to get a 100% working part here is to get the marlin crawler shift seat in blue. the transmission R150F has a transfer case top mount for the blue seat.
also going to need
Toyota Part No.: 36108-35060
DEFLECTOR SUB-ASSY, BREATHER OIL
and
Toyota Part No.: 36345-35050
GASKET, TRANSFER CONTROL SHIFT LEVER RETAINER
also needed
Toyota Part No.: 33555-35160
BOOT, SHIFT LEVER
Toyota Part No.: 36331-35010
BOOT, TRANSFER SHIFT LEVER
installing them is super easy... just take out the little steel inserts and pop out the rubber groumit parts and squeeeeeze... then re-insert the steel inserts.
Old 04-08-2018, 01:21 PM #58
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
Stong arm lift gate gas lift strut with aftermarket bushing
Thanks to other T4R members this was easy and it worked out great. I went with the heavy-duty version and my back hatch stays up with authority now.
Old 04-12-2018, 01:58 PM #59
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
TRD CatBack Exhaust System (PTR06-89990-14)
I looked for quite a while... could never really find a non double cat back so...
I had an exhaust shop cut off the TRD flange on the muffler, ouch.
then we added a longer single pipe with a new O2 bung where the old was was... and hooked it up.
and added a bung up on top of the cat for a wide band coming soon....
Old 04-13-2018, 12:39 AM #60
Road Bull's Avatar
Road Bull Road Bull is offline
Real Name: Ryder
Road Bull is a jewel in the rough Road Bull is a jewel in the rough Road Bull is a jewel in the rough Road Bull is a jewel in the rough
Road Bull's Avatar
Real Name: Ryder
Man... The changes that you are making are impressive. How do the rear disk brakes feel? Great work.
2002 SR-5 in Millennium Silver.
Timeline>> http://www.toyota-4runner.org/3rd-ge...-timeline.html DEAD
2002 SR5 Changeling Build https://www.toyota-4runner.org/3rd-g...ing-build.html
Road Bull is offline   Reply With QuoteReply With Quote
AssBurns 2000 Limited Build Thread AssBurns 3rd gen T4Rs 509 06-23-2021 11:45 PM
Blizz86's 2000 Limited Build blizz86 3rd gen T4Rs 71 11-28-2020 08:21 PM
aykalper's 2000 Limited build aykalper 3rd gen T4Rs 31 04-23-2019 07:03 PM
Airmapper's Build: 2000 Limited Airmapper 3rd gen T4Rs 27 01-08-2019 05:18 PM
Ride_Red 2000 Limited Build Thread Ride_Red 3rd gen T4Rs 67 09-26-2014 12:12 AM
