Originally Posted by sleepydad
about 10K since I replaced it.
I have a 97 with 230K on it and the shaft on that trucks is still fine. The reason I replaced my OEM shaft was because when I lifted the back end 4" I would get a clunk into gear really bad. after replacing the shaft that went away. I think the slip yoke wears and when you lift the back end it makes it a bit worse. if your not going to lift your truck and the OEM shaft is solid, no reason to replace it.
@ thezentree
also went with Toms shafts... he had a different story but I think he ended up liking it?
Originally Posted by jimmyrecluse
Ive lifted 2" up front and 2.5" in the back. Mild, will pick up TW when I need to replace it
Thanks again
I bought mine trying to eliminate a driveline vibration that started after I lifted it (2.5" up front, 3" out back).
The first try, I ordered it with the wrong bolt pattern on the axle end flange. TW fixed it for free even though it was my error, I just had to pay to ship it back ($70).
The second try, the vibrations seemed worse, so I had the driveshaft checked at a local driveline shop. They said it had about .060" runout, so I sent it back to TW and they replaced it.
The third try, I still had vibrations, so I had the driveline shop check it again, and they said it had .060" runout again. I paid them to "straighten" it ($115 and a two week lead time) and the vibrations seemed worse than before it was "straightened." It turns out that the local driveline shop is the only place within several hours driving distance that can even check DS balance, so I'm stuck with a driveshaft that has so far cost me close to $800 that I don't trust to be straight. Honestly, I'm sort of leaning towards the local place having a DS balancer/straightener that is out of calibration and me paying them $115 to bend my previously straight driveshaft.
I'm now running the OEM driveshaft with a new rear U-joint, with the same vibrations as always, just
ever so slightly less bad than the "straightened" TW driveshaft. It's been starting to clunk lately though, so I might swap the TW DS back in this coming weekend if the weather holds up.
Long story short, my experience with TW has overall been good since I don't know definitively that their driveshaft
s were bent. Objectively, their prices are reasonable, build time and shipping is ridiculously fast for a custom part coming from two time zones away, and they stood behind their product when I said it was defective.
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
