Originally Posted by Nate_GB
The stock air box pulls air from inside the passenger fender wheel opening which is a rather dusty place depending on the conditions you drive in. The OP was sure to note that his results were when NOT FOLLOWING another truck through dusty conditions. If following another truck, I'm sure the filter with the deck plate mod would have been as bad, or worse that the stock intake setup air filter.
Yes, the vast majority of my dirty travels is leading a group, or solo, so almost never following. I don't believe the filter would be dirtier when following someone with the deckplate removed vs. the stock intake. Both options would be super dirty. BTW, the dirty filter in the supplied picture was cleaned several times during the week by beating it on the ground (you can see the deformed plastic where it was damaged from beating it on rough asphalt), while the clean filter pictured was not cleaned. A snorkel is the next step, primarily to pick up clean air, more so than to not ingest water.
