Old 12-11-2017, 04:19 PM #1
Dezerts10 Dezerts10 is offline
Dezerts10 is on a distinguished road
Camburg long travel, toytec and King install on my 1996
Been working on getting my Camburg long travel kit, king shocks and toytec springs installed over the last few weekends.
I probably have 10 hours into disassembly and assembly so far. It’s not 100% done just yet.
Had to modify the front king coil over spacer to fit so thats why no front shocks just yet.
No bumpstops or limit straps installed either they will be done in early January
Had a few hiccups along the way but can’t say enough thanks to a couple of my best friends jonny at richer racing for the king hook up and Scott at Camburg for the suspension deal.
New Years will be the maiden voyage to the local dezert for the weekend.
Dezerts10 is offline   Reply With QuoteReply With Quote
Old 12-11-2017, 04:31 PM #2
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Your suspension components put a smile on my face.
Are you going with a secondary bypass shock in the front? While expensive, I hear its amazing.
Old 12-11-2017, 04:36 PM #3
I will eventually, can’t afford it currently, plus I’d have to fabricate a shock hoop so maybe next summer once the dezert season is over here in Southern California I’ll see if I can afford to do all that.
I do have hydraulic bumps stops for all 4 corners too
Old 12-11-2017, 05:23 PM #4
turbo8's Avatar
turbo8 turbo8 is offline
turbo8 will become famous soon enough turbo8 will become famous soon enough
turbo8's Avatar
Do your reservoirs, on the rear shocks, look like they will hit the axle when the suspension is compressed?
97 4runner 3.4l, 5spd, 4wd trd s\c, urd 7th injector, tc upper arms, Fox 2.5" extended travel coil overs, Icon 2.5" piggy back rear shocks, ome 2" lift rear springs, fj cruiser wheels,custom front skid, Modified trail gear rock sliders, tundra brakes, 275/70r/17 bfg AT ko2, true track, Corbeau sport seats, trs h1 hid retrofit.
2011 BMW 135I 6spd
2009 Lexus LX570
turbo8 is offline   Reply With QuoteReply With Quote
Old 12-11-2017, 05:32 PM #5
Originally Posted by turbo8 View Post
Do your reservoir on the rear shocks look like it will hit the axle when the suspension is compressed?
I jacked it up with the wheels off the ground and I’m more concerned about the clearance between the upper reservoir fitting and frame rail.
Old 12-11-2017, 05:54 PM #6
NWFL4Runner NWFL4Runner is offline
NWFL4Runner is on a distinguished road
Nice! What coils weight did you end up going with?
NWFL4Runner is offline   Reply With QuoteReply With Quote
Old 12-11-2017, 05:56 PM #7
I got the super flex coils. I’ll have a bumper; drawers and a spare tire in the back at some point:
Old 12-11-2017, 06:33 PM #8
Nice. Up front I'm running 700lb 18", and it's a back breaker. Have 600lb ready to swap in as soon as I get some time.
Old 12-11-2017, 06:39 PM #9
oh you mean for the front coil overs? im not sure I want to say its a single rate 600lbs spring but haven't looked at them really closely. I ordered what ever shock Camburg told me to get. ill reply when I get home and check.
Old 12-11-2017, 07:13 PM #10
kolelt kolelt is offline
kolelt will become famous soon enough kolelt will become famous soon enough
TOTAL CHAOS FABRICATION
97 3.4 JDM/5 Speed swap/eLocker Swap/ICON CDC all around/+more.....
kolelt is offline   Reply With QuoteReply With Quote
Old 12-11-2017, 08:40 PM #11
Nate_GB's Avatar
Nate_GB Nate_GB is offline
Nate_GB is on a distinguished road
Nate_GB's Avatar
I have mine rotated so that the reservoir is facing out towards the tire and forward a bit. That way the fitting tucks away nicely and the reservoir won't get crushed by the axle tube on compression.
Truck looks good. What glass are you running?
Nate_GB is offline   Reply With QuoteReply With Quote
Old 12-11-2017, 09:17 PM #12
theesotericone's Avatar
theesotericone theesotericone is offline
theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice
Very nice set-up. Looking forward to the trip report about the performance. With those components I'm sure you'll be happy.
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. --Albert Einstein
theesotericone is offline   Reply With QuoteReply With Quote
Old 12-11-2017, 11:10 PM #13
I currently have Mcneil fenders. I’ll cycle everything s few more times before I take it out to check and move stuff if needed. Thanks for the tip
Old 12-11-2017, 11:12 PM #14
Originally Posted by kolelt View Post
Not sure if the TC hoop would work.
Old 12-12-2017, 12:19 AM #15
Need to compare the LCAs. Probably would
King Suspension Rear Long Travel VA4Runner09 4th Gen T4Rs 34 10-10-2017 12:40 AM
Dirt King Long Travel System, 14" Travel - +3.5" Wider - Under 2700 Delivered!! TotalAutomotiveLV Total Automotive Performance 13 07-04-2017 02:32 PM
Disappointed In Rear ToyTec "Long Travel" 5100's Tyler James Inc 3rd gen T4Rs 19 11-17-2016 05:48 PM
ToyTec Rear Long Travel LCAs Gerdo 3rd gen T4Rs 17 01-30-2016 10:20 PM
camburg long travel kit for 95-04 taco/96-02 4runner, burbank, ca. $3000 bricebones For Sale: Suspension/Wheels/Tires 14 04-30-2015 04:54 PM
