Skibber
- did you ever resolve the issue? I'm having the same exact symptoms.
The TRAC issue (TRAC engages when accelerating from a full stop, but only while in 4wd) has been going on for about a year. I've cleaned the ABS sensors, done a VSC calibration... no dice. But I have the Andy Mod 2.0, so that's functioned well as a work around and I've learned to live with it.
On the way out of town this past weekend, throttle cut twice on hard turns from a stop, just as you described earlier. It hasn't repeated since.
On a possibly related note, my 4WD started acting up this weekend as well, it seemed reluctant to engage, also the dash indicator wasn't showing the actual state (indicating 2wd when it was in 4wd) and once it threw itself into 4wd with locked center diff while I was driving around 30 mph. I spent the rest of the weekend in unlocked 4WD (multimode) - I needed it to get up my friend's driveway and since the system was acting up, I thought it best to engage / disengage as little as possible. Drove home 6 hrs with no issues. Used the Andy Mod button each time I started the car to avoid the TRAC issue. Not sure if the use of the Andy Mod temporarily resolved the cut throttle issue over the past few days. I just put it back in 2WD today, no issues so far (but I've only done about 30 minutes of driving).
One more random thing - in 4-Lo (unlocked), I'm getting the TRAC shuddering hesitation *even after TRAC has been deactivated via the Andy Mod*. That's never happened before.
I did a visual check on the vacuum hoses and couldn't find anything amiss. Didn't have time to look into it more. Usually I'd do more trouble shooting before posting, but I'm about to head out on a week long road trip.
