Originally Posted by TheDurk
On 5-speed manuals, the speedo/ODO take the signal from the rear ABS. Should have thrown a P0500, too.
I found this thread while searching the internet for a fix for my non working Speedo/ODO code p0500 problem. I've read through it as well as a few others, and am still at a loss, I appreciate any help I could get resolving it.
I purchased a 1998 sr5 4x4 MANUAL transmission in Feb for my son. Bought it from the original owner, completely stock. Speedo and (analogue) ODO only seem to work when they want to. I've gotten a check engine light, no ABS warning light on the dash. (ABS light does light up when key is in the on position, so I know it works). Cruise control works when the speedo does, haven't tested it when the speedo is frozen.
Cheap non ABS scanner gives the p0500 code.
Seems the speedo/ODO will work when the truck has been sitting in the sun on a warm day here in AZ, but not on chilly mornings. (could be totally unrelated I have no idea)
A buddy told me I should bang on the dash above the speedo while driving when the speedo is froze to help diagnose if it's the combo meter. When I did, the speedo needle jumped from the impacts, but continued to not work during that trip. I banged hard enough to dislodge the 30amp door lock/power window fuse.
I haven't inspected the ABS wires since the ABS light isn't on, nor have I 'jumped' the diagnostic port under the hood to check for any flashing ABS light codes. I am looking for some suggestions as what to look at to help diagnose the issue.
Thanks a ton!!
