Originally Posted by brillo_76
Can you see it moving? Its possible stiffer rubber will help with exhaust vibration. I have also seen the muffler insides come loose and rattle like crazy too.
Is the engine itself running nice and smooth?
Yes. The end of the tailpipe vibrates the most, moving back towards the engine- the muffler i can see vibrating, the two catalytic converters I have vibrate a decent amount. I have a total of 4 insulators- 1 near the end of the tailpipe, 2 on the muffler, and one on the 2nd catalytic converter. The 1st catalytic converter does not have one.
All the welds look intact and also the rubber is not cracked or look to be in bad shape.
Im currently running very smooth on my engine being 22 years old with about 298k miles. No major problems other than its a very slow pick up speed- but it's a V4. Idle around 800-825 RPM in Park, and 7-725 in gear. I do notice more vibrations inside the car when the AC is on.
Rpm's bounce/surge with AC on like others have mentioned being common in other threads I've read. When I first bought it 2 years ago with 269k miles I was running around 1700 rpms with idle surging. I have got that way under control awhile back, but have been chasing vibration for a while.
One thing has me thinking maybe it's U-joints on the drive shaft needing greased. My carfax shows the driveshaft U-joints were replaced about 140,000 miles ago- and they don't have any zerk fittings on them... Also getting a loud pop/clunk when going from reverse to drive or drive to reverse- Usually once warmed up.
Seems worth a shot but let me know if you think it could be driveshaft vibration. Thanks for any input/help.
