01-02-2018, 11:41 AM
Real Name: C8H18 Mike
Driver side lean
I've done a fair bit of searching, and I know there are side-specific coils and trim packers that can be added to the driver side, but beside the obvious issue (more weight on the driver's side over a long period of time) what else can contribute to this "issue" - like can a stock panhard bar on a lifted truck cause or exacerbate driver side lean?
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto -> 2WD 4runner Journal Thread
01-02-2018, 01:13 PM
you ?
97 3.4 JDM/5 Speed swap/eLocker Swap/ICON CDC all around/+more.....
01-02-2018, 01:22 PM
Originally Posted by kolelt
you ?
That is the typical why, my question is what else can/will contribute to it when you move the truck from it's stock configuration.
I have a lean that became noticeable after installing Tundra billies, and I've switched them between sides to no effect; still leans to driver side.
I've disconnected my sway bar and inspected/measured body mounts and body to frame gap - the issue is suspension-related.
I added a 1/4" top plate spacer to the front driver shock/spring and it still leans
I am about to order an OME 10mm trim packer for the rear spring and I have a panhard correction kit ready to weld on
The only thing I've not tried yet is to disconnect the panhard bar itself and see if the lean lessens or goes away
So yes, ME is the answer because I am fat-ish and I've not done everything - but it is in my nature to start new threads to ask, so here I am
01-02-2018, 01:41 PM
you ?
Originally Posted by octanejunkie
Was gonna ask if it happened after the holidays
Bwa-hah-hah-ppy new year!
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
01-02-2018, 01:50 PM
I would say transfer case but given the lack of CV axles for the OP.
I'd start with new rear springs at least and go from there.
01-02-2018, 01:53 PM
Real Name: Mark
Real Name: Mark
Happy New Year Mike,
The rear suspension plays a bigger role in lean than the front. I believe
you will solve the issue with spacer you have coming. I don't recall what all you've done on your rig, did you recently lift it? if so new or used rear springs?
Could you have springs reversed? November think it was, a member had same
issue with new lift, everything correct up front as far as DS/PS springs. Shop
that installed lift had rear springs reversed, they swapped them problem solved.
01-02-2018, 02:02 PM
Real Name: Mark
Real Name: Mark
Front Diff adds some weight to DS also I believe.
01-02-2018, 02:38 PM
Real Name: Instagram: briansd_97r
How much lean are we talking here? A picture with a tape measure (fender to ground, center wheel) is worth 1,000 words.
With the truck empty and no one sitting in it the passenger side really shouldn't sit more than 1/2 to 3/4 inch higher at most. The pan-handle bar shouldn't be an issue because it is usually installed with the truck flat no tension on the bar (while sitting flat).
I've got King's and at the same setting the passenger sit's a bit higher but not a lot. 1/2 inch difference really isn't much of a big deal at all, at least IMO.
--> The OEM Tundra front shocks w/ coils have a different spring for driver vs passenger. This is to offset natural drivers side lean. Do your Billstien springs have different part # for driver vs passenger?
--> Yes the sway bar should have no effect on lean unless something is seriously off. While the truck is flat the sway bar should have close to no tension in at all.
--> I'd remove that top plate spacer. It only reduces the ride quality.
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giant’s robe, Upon a dwarfish treasonous thief.
01-02-2018, 02:43 PM
Real Name: Daniel
Real Name: Daniel
When you say more weight, obviously the driver is included in that, but don't forget the gas tank. That's a couple hundred pounds just in the gas (not including the tank itself) that's more or less situated over the rear driver side coil.
I'd say rear coils too. My cheap Moog coils were noticeably longer for the driver's side to compensate. Maybe higher quality coils have different spring ratios instead of lengths, but I'm not sure.
I'd be interested to see how things even out in a Hilux Surf. Gas tank still in the same place (I'd assume), but the driver on the other side.
01-02-2018, 02:44 PM
Are your tundra bilsteins adjustable? You could bump up your driver’s side coil up a notch. That’s basically what I did on my coilovers. I have 1/2” more thread showing on my drivers side shock body compared to the passengers side to level out the front.
I don’t have any trim packers in the rear and it sits anywhere from mostly level to a 1/2” off depending on how much gas I have in the tank or how I have my cargo gear distributed. The occasional 1/2” difference in the rear driver/passenger’s side height isn’t visually noticeable but is there if I measure it.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
01-02-2018, 03:02 PM
Driver side lean
I mean, not likely. If you're lifted 2" or more, you need the PCK anyway, so just weld those bítches on there and see for yourself!
How far off are you talking? What front springs are you running? I bet if you didn't measure it, you wouldn't have ever noticed. Now you're just making yourself [more]crazy!
Mine sits perfectly level with the side-specific '99 tall front springs, and side-specific Superflex rear springs.
01-02-2018, 05:19 PM
I’m running a OME spacer(s) in the back to fix this. still have a small driver side lean.
01-02-2018, 07:21 PM
Real Name: 3 Bears
Real Name: 3 Bears
not much help, but I do know when I ordered the highlander the springs (talls) for my truck , they ordered and came specific for left and right sides
Its been over a year now, and I am a big guy...215....and have no noticeable lean..
01-02-2018, 08:25 PM
I have no transfer case, or front diff, as was also mentioned. I've got OME 890 rear springs (not side-specific) that have about 100K on them, IIRC
01-02-2018, 08:33 PM
The after adding the top plate spacer the driver side sans driver, is only 1/2-3/4" LOWER than the passenger side.
I have not installed the kit yet to get my panhard bar back to level, FWIW
I am running used OEM springs, not Bilstein springs, that I thought were 99 talls, but the color marks don't match. They appear to be thick, 10-wrap coils (maybe 9.5 wrap) and have different color markings on each. One is Blue-Blue and the other Blue-Orange. I've tried them either side, no change in the lean. Maybe it's time to just buy new coils.
Agreed. The thought was if the sway bar was bad it could affect stance, but disconnecting it had no effect, so we can rule that out.
So far it has had no discernible effect, visual or otherwise, but it did raise the front end fender to ground measurement by about a 1/2"
Looking from the rear, the lean is more pronounced from a distance.
