Old 01-21-2018, 12:47 AM #1
tkc74 tkc74 is offline
tkc74 is on a distinguished road
96' Constant Rotational Metal Squealing After Turning (Passenger Wheel)
Oi,
Was driving on the freeway when I noticed that whenever I would make a slight turn a constant rotational (proportional to my velocity) metal squealing sound would appear from the front passenger wheel. This sound would temporarily go away once the wheel was centred and usually after I applied the brakes slightly but would return after turning again.
This sound continued and was much worse while on my way home and I have not driven since...
My initial thoughts are CV, possibly some metal shaving have gotten into the boot?
  • 1996
  • 4WD
  • V6
  • 300,000 km (~185,000 miles)
tkc74 is offline   Reply With QuoteReply With Quote
Old 01-21-2018, 12:52 AM #2
thecole1098's Avatar
thecole1098 thecole1098 is offline
thecole1098 is on a distinguished road
Brake dust shield hitting the rotor?
'06 4Runner SR5 V8 2WD -- Flowmaster 50 Delta Series w/ resonator delete | 265/70R17 Toyo Open Country A/T | Pro Comp Series 5044 | Black headlights
'98 Jeep Cherokee Classic -- Fender armor | 35x12.5x15 Pro Comp MT2 | 4.5" RE short arm lift | Locked | Swingout Plate Rear Bumper | Shackle Relocation Kit
thecole1098 is offline   Reply With QuoteReply With Quote
Old 01-21-2018, 01:04 AM #3
4yogger's Avatar
4yogger 4yogger is offline
4yogger is on a distinguished road
4yogger's Avatar
Check your wheel bearing. This happened to one of my other vehicles, you described by situation exactly. Luckily for you, the 4Runner only requires a bearing and not an entire hub assembly!
'99 Limited, Locker, SS1.2, 285's, KM6HOD
4yogger is offline   Reply With QuoteReply With Quote
Old 01-22-2018, 01:36 AM #4
Thanks for the replies, took a look under the truck and couldn't see anything out of the ordinary. I will have to take the wheel off when I have time and post back with what I find!
Cheers!
Old 01-22-2018, 10:10 AM #5
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Most likely the dust shield as thecole1098 said.
No need to remove a wheel, just reach underneath and pull it towards the center of the vehicle a bit, may need to do so in more than one place around the shield to achieve a similar buffer between it and the brake rotors. Luck.
Old 01-22-2018, 01:08 PM #6
It could also be the ware indicator on the brake pad rubbing the rotor telling you is time to change your brakes.
Old 01-22-2018, 01:29 PM #7
Horsethief Horsethief is offline
Horsethief will become famous soon enough Horsethief will become famous soon enough
This happened to my old Jeep years ago. I was doing front end work and inadvertently bent the dust shield. After driving I heard the noise and figured that's what it must have been. Popped the wheel off and sure enough that was it. I just pried it back with a screwdriver.
Someone said wheel bearings.... in my past experience w/numerous other vehicles, wheel bearings have made more of a growling sound that can actually be felt a bit too.
Horsethief is offline   Reply With QuoteReply With Quote
Old 02-15-2018, 04:50 PM #8
Thanks a bunch! It was the brake dust sheild! I was changing the brakes and rotors while finding the problem, gave the sheild a few good whacks and now it's pretty smooth.
1996 4runner , brake , noise , squeal , turning
Front tires squealing under acceleration and turning... Anyone else experience this? dkyleb 4th Gen T4Rs 10 09-11-2016 12:03 PM
Metal on metal rattle under steering wheel cv470 5th gen T4Rs 2 05-18-2015 06:14 AM
Metallic, rotational clicking, right front wheel, brakes? l Runabout36 4th Gen T4Rs 5 03-27-2013 11:05 AM
WTB '08 T4R Front Bumper, Passenger Sideview Mirror, Passenger Rear Wheel Trim brianhoberg For Sale: T4R Items 0 02-28-2012 12:23 AM
Squealing/squeaking when turning on full lock... wombie 4th Gen T4Rs 3 09-27-2009 11:03 AM
