Old 01-24-2018, 05:55 AM #1
kolelt kolelt is offline
kolelt will become famous soon enough kolelt will become famous soon enough
Condensation inside windshield
Is it normal to have condensation inside the car. Like inside on the windshield? It rained yesterday all day and I have condensation on the windshield but from the interior. I feel like this isn’t normal. And I feel like it’s been happening lately.
97 3.4 JDM/5 Speed swap/eLocker Swap/ICON CDC all around/+more.....
kolelt is offline   Reply With QuoteReply With Quote
Old 01-24-2018, 10:02 AM #2
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Are we talking moisture vapor or drops of water clinging to inside of windshield?
Mine builds up moisture vapor on interior windshield and front windows when changes in the weather occur, like going from a humid/warmish previous day to a drier/cooler front the next, running the a/c in dash mode for a minute or two usually removes it. Yet perhaps your's is a bit more than that?
Old 01-24-2018, 10:43 AM #3
Mine looks to be just condensation/ moisture. I came
Back from work late. Glanced at it. And was like hmmm wtf. I have a photo of it. I’ll upload it later today.
Old 01-24-2018, 11:02 AM #4
RAD4Runner's Avatar
RAD4Runner RAD4Runner is offline
RAD4Runner has a spectacular aura about RAD4Runner has a spectacular aura about
RAD4Runner's Avatar
I hope it's not coolant leak fro the heater core.
Moisture in the air inside condensing on cold glass is normal.
IF excessive that means something causes the air inside the truck to have more moisture content than ambient air.
If you haven't been sleeping inside the truck, or cooking near the opening where steam is blown into the truck, it may be a leak or crack in heater core. Have you been losing coolant?
You're in Jersey so it may be tough to try driving with the heater on minimum (No coolant flow into the heater core).
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
RAD4Runner is offline   Reply With QuoteReply With Quote
Old 01-24-2018, 01:10 PM #5
No, no coolant leaks at all. And I always check my coolant just incase. Heat also works flawlessly. Carpet is dry. However the truck has been sitting for 3 weeks. And the weather in jersey has been cold and warm. It’s been weird weather. I’ve only noticed the condensation inside the truck on the windshield when it’s been sitting and has rained on.
Old 01-24-2018, 03:35 PM #6
RAD4Runner's Avatar
RAD4Runner's Avatar
Originally Posted by kolelt View Post
... It’s been weird weather. I’ve only noticed the condensation inside the truck on the windshield when it’s been sitting and has rained on.
I see. If no leaks from outside, most likely it's just trapped moist air from warmer, humid days condensing when it gets colder outside, Or just ambient humidity condensing on cold glass like normal.
We were just on the moist and cold northern coast of California this weekend, camping in the truck. While we have the windows cracked open, there was still co much condensation, the AC-heat was not enough to vaporize it. The glass was actually dripping wet inside.
Old 02-08-2018, 11:03 PM #7
Just got home. Truck has been sitting for 3 days. Inside the truck. There is like frozen vapor on the windshield. But from the inside. Wtf ! It’s been cold today in NJ. Below 32. Basically frost on the windshield but from inside.
Old 02-09-2018, 01:11 PM #8
Does this mean. I have water accumulating somewhere ? I’ll double check my floor but it seems dry. I’m really lost. Maybe I should try and blast the defroster on fresh air. Should I blast it with Heat or cold air ?
Old 02-09-2018, 01:30 PM #9
Scramble's Avatar
Scramble Scramble is offline
Real Name: Scramble
Scramble has a spectacular aura about Scramble has a spectacular aura about
Scramble's Avatar
Real Name: Scramble
This has never happened to me but it sounds like moisture inside the truck. Could be a small drip somewhere where the rug isn't soaked.
____________
'99 4Runner - 2.7L 3RZ, 5 Speed, 4.56 Gears - Lifted, Locked & Loaded - 166k Original owner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
'99 Limited - E-Locker- Stock (for now) - 233k 2nd Owner http://www.toyota-4runner.org/3rd-ge...ted-build.html
Scramble is offline   Reply With QuoteReply With Quote
Old 02-09-2018, 01:38 PM #10
sportscarfan's Avatar
sportscarfan sportscarfan is offline
sportscarfan will become famous soon enough
Could be that you have a leaky windshield. Glass installers don't care if they scratch up the paint under the seal removing old glass. Water gets in and rusts behind the seal, pretty soon you have a leak. This is the case with my 4runner....discovered a couple years after I bought it. My low-buck fix is a big black vinyl band-aid across the top of the windshield that has now been in place about 3-1/2 years.
'97 SR5 V6 4x4 | 5-speed | e-locker | 33's
sportscarfan is offline   Reply With QuoteReply With Quote
Old 02-09-2018, 02:37 PM #11
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
I also get condensation on the inside of my window. It only happens in winter and it's just because the floor mats get so wet from snow and slush. It also doesn't help that I have my ice fishing gear in the back that brings in a bunch of snow/slush/ice every time I go fishing.
What I've noticed that helps is to leave a couple windows slightly cracked. This allows the moist air to escape the cabin and not build up on the window.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 02-09-2018, 04:24 PM #12
I never had this issue before. I owned the truck for 4 years. It doesn’t look wet or anything around the windshield.
This is pissing me of badly. I’ll try and check really good under the carpets. Although it did rain Wednesday badly. Then Thursday it for really cold. And hats when I noticed the frost on the inside. And not the outside.
Old 02-09-2018, 10:57 PM #13
Nate_GB's Avatar
Nate_GB Nate_GB is offline
Nate_GB is on a distinguished road
Nate_GB's Avatar
Run the truck for a while with the "a/c" button on (hot or cold air doesn't matter but the a/c button needs to be lit up. Then make sure you also have the truck set to "recirculate." This will run the internal truck air through the a/c system and therefore through the receiver/dehydrator and will dry out the air in the truck.
I'm of the opinion that it's just a weather problem and not a problem with the truck.
Nate_GB is offline   Reply With QuoteReply With Quote
Old 02-09-2018, 11:27 PM #14
Thank you. I’ll try. The weather here has been stupid. Warm. Than extremely cold.
Old 02-09-2018, 11:29 PM #15
thecole1098's Avatar
thecole1098 thecole1098 is offline
thecole1098 is on a distinguished road
I notice that mine does this as well when the temperature/humidity changes in a short amount of time like you have been experiencing. I wouldn't worry about it too much.
'06 4Runner SR5 V8 2WD -- Flowmaster 50 Delta Series w/ resonator delete | 265/70R17 Toyo Open Country A/T | Pro Comp Series 5044 | Black headlights
'98 Jeep Cherokee Classic -- Fender armor | 35x12.5x15 Pro Comp MT2 | 4.5" RE short arm lift | Locked | Swingout Plate Rear Bumper | Shackle Relocation Kit
thecole1098 is offline   Reply With QuoteReply With Quote
Water leaking on inside of windshield KayStrait Maintenance/Detailing 0 07-14-2014 02:12 PM
Moisture on inside of windshield etc. when cold/rainy cstorms 5th gen T4Rs 7 01-01-2014 09:27 PM
Black Dots on Windshield -- On or Inside Glass? rjfowler 5th gen T4Rs 4 07-04-2010 02:44 PM
Ice on inside of windshield Q-V 4th Gen T4Rs 7 02-10-2006 08:42 PM
best way to clean the inside of the windshield TexasA&M Maintenance/Detailing 16 12-07-2005 08:22 AM
