01-26-2018, 11:05 AM
#16
Originally Posted by Acorn22
Thought I'd throw it out there that I get 19-21mpg with 265/75s and a 4 inch lift out here in temps below 15 almost everyday, that is a daily 30 mile drive at 60mph. Keeping the oils and ignition parts fresh definitely help out as well as keeping the tires at the correct PSI
That’s great and all but why such small tires for a 4” lift?
'06 4Runner SR5 V8 2WD -- Flowmaster 50 Delta Series w/ resonator delete | 265/70R17 Toyo Open Country A/T | Pro Comp Series 5044 | Black headlights
'98 Jeep Cherokee Classic -- Fender armor | 35x12.5x15 Pro Comp MT2 | 4.5" RE short arm lift | Locked | Swingout Plate Rear Bumper | Shackle Relocation Kit
01-26-2018, 02:00 PM
#17
Real Name: Brian
Real Name: Brian
Who doesn't like 21 mpg? I get the same tread pattern as a bigger tire but it's about 15 pounds lighter, and I have 0 rubbing with max articulation, which is a lot for LX coils. Yeah they may not fill out the wheel wells as much, but I'll trade the looks of that for the mpgs and suspension articulation.
Maybe I can post a Pic later
1998 4x4 Limited 3.4 Sunfire Red Pearl
Front: Eibach 600lb 3" lift coils over Tacoma 5100's
Rear: Lexus LX450 coils w/ FJ80 shocks
Firestone Destination AT 265/75's
01-26-2018, 02:04 PM
#18
I believe it's possible. I got 23.1 mpg last spring in a rented '01 Taco ext. cab V6/AT travelling from Grand Junction CO to Moab UT. I used the cruise at times, and was travelling between 65 and 75mph. Speed limit in UT is 80mph, but I felt bad pushing that poor Taco up those grades at that speed.
When I filled up right before getting back to our rental house in Moab I was quite impressed when I did the calculations.
Also, weather conditions can help. Perhaps there was a tailwind, and maybe the OP drafts behind semis. Or maybe he was in some dense traffic. One time I was coming back from CT on 95 in my 97 Grand Cherokee 4 liter, and I was getting about 24mpg at 70. I think it was because I was in some dense, but quickly moving traffic. I think all the other cars helped with the aero.
Anyway, even for you guys getting 17-20mpg, it's not any worse than what the new ones are getting.
01-26-2018, 02:18 PM
#19
Real Name: Leon
Real Name: Leon
Originally Posted by amalik
Check out my post a few lines above. Identical to you, I have 97 limited 4x4.
I saw that, thanks. Not sure I'd be convinced by a 20 mile drive, but it's obviously better than mine. In fact, everyone's appears to be better than mine.
To be clear, my truck is not neglected in the least, every single fluid has less than 1000 miles on it, as do plugs and wires.
Speed does indeed make a difference, though even at 67 I'm looking at 18 mpg. Here are screenshots at various speeds, I had the cruise on and drove at least 10 miles at each speed on level ground. And I did confirm the accuracy, as I filled the tank after 200 miles and was within 0.2 mpg of the gauge reading.
I am beginning to wonder about the MAF, that's the only thing I can think of.
Sent from my SM-G900P using Tapatalk
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
01-26-2018, 02:20 PM
#21
Real Name: Leon
Real Name: Leon
Amalik, your coolant is at 211, mine's at 188. Could that be part of my issue?
01-26-2018, 02:22 PM
#22
Real Name: Leon
Real Name: Leon
Oh, I'm guessing you were stopped, so that's probably soakback temp.
01-26-2018, 02:35 PM
#23
My thermostat is really old, from God knows when, it needs to probably be replaced and is likely not at the right jiggle valve position. And yes, I was stopped.
01-26-2018, 08:28 PM
#24
Real Name: Leon
Real Name: Leon
I'm completely confused, or else my truck is bipolar. I just got 25.3 mpg over the last 40 miles of combined freeway and stop and go traffic, how is that possible???
To review my trip over the past few days (and why I think my truck is bipolar):
- First 100 miles = 15.3 mpg (mostly 70 mph), which obviously I wasn't happy with (this was measured by miles driven / gal to fill, realizing that there's always some error in when the pump stops).
- Next 225 miles = 17.5 mpg (about half freeway at 70 mph, half back roads with stop lights, about 60 mph)
- Next 160 miles = 17.5 mpg (all at 75 mph, cruise set).
This is when I read this thread and decided to use Torque Pro to pay closer attention (until then I thought this was normal for our trucks).
- Next 160 miles = 16 mpg according to Torque Pro (at 77 mph, no idea why it dropped from 17.5 two days earlier). I also confirmed the Torque Pro reading by calculating miles driven/gal to fill - same result.
Then I drove at different speeds for about 10 miles at a time, with the cruise set, to see how it affects mpg:
- 68 mph = 18.3 mpg
- 73 mph = 16.6 mpg
- 76 mph = 16.9 mpg.
A bit odd that 76 mph gave better mpg than 73 mph, but I may be splitting hairs.
Next is where it gets interesting. I made a stop of an hour, then headed home. I was in traffic, going about 60, and noticed that Torque Pro was reading about 24 mpg. That sort of made sense, I figured slower speed = better mpg. Then traffic sped up, and at 65 mph I was still showing 24 mpg. We sped up to 75, same reading.
By the time I got home, I put on 40 miles of about 1/3 60-65 mph, 1/3 70-75 mph, and 1/3 stop and go traffic.
And this averaged out to the 25.3 mpg you saw above. How is that possible? How can combined freeway and stop and go traffic be better than freeway only?
01-26-2018, 09:15 PM
#25
The one thing no one talks about is elevation. It plays a HUGE impact on mileage. When I was living in Grand Lake,CO at 9k and driving to hike peaks I almost always got over 20mpg. My power was shit and it felt like a turd but mileage was good.
Now im below sea level and I get 17-18mpg driving 65mpg. I thought something happened until I drove to utah and mileage jumped back up.
The more air oxygen the more fuel used to achieve the proper mixture.... The less oxygen( higher elevation) the less fuel used.
And everyone know those inflated numbers 24mpg+ are either not real or you worked really hard to get those and it was prob flat or down hill.
01-27-2018, 12:24 AM
#26
Well I'm happy where this thread has gone for the most part. If it helps I've been driving in Texas on some decently flat roads with 33 psi in the tires. Truck rides straight and true after the alignment. My toe in was .33 on the old tires before the alignment : ( now it is. 03 on each side
Sent from my A0001 using Tapatalk
01-27-2018, 12:56 AM
#27
Real Name: Leon
Real Name: Leon
So no one wants to take a crack at my crazy results?
01-27-2018, 10:16 AM
#28
Yes, they are crazy.
1989 FJ62 5.3 Chevy, FZJ80 Axles, 4.88's with ARB.
2000 2wd runner, 4 cylinders, yes it IS slow.
1999 4WD SR5 Desert Dune 3.4 351K and counting.
2000 4WD sport 3.4 Elocker <--My son's but I still end up paying.
2001 2WD SR5 3.4 <-- My daughter's...see preceding line.
01-27-2018, 10:27 AM
#29
Real Name: Leon
Real Name: Leon
The part that's not crazy is that the mpg readings were confirmed with gallons needed to fill.
So aside from planning to clean the MAF today, I'm scratching my head as to what could cause the same vehicle to go from 16-17 at highway speeds to 25 mpg combined highway/city in the same day? The only difference I could think of was that the air temp went from around 50F to around 80F.
I also have the distinct impression (confirmed by the mpg readings) that the change occurs from trip to trip, and is consistent on a given trip. i.e. the mpg is either good or bad for the duration of each trip.
Can something be "sticking" if you will, so that on some drives it causes the mpg to be higher than on others? I'm thinking back to carburetor equipped cars, but can't really think of any equivalent on fuel injection.
01-27-2018, 03:09 PM
#30
When it isn't 20 degrees outside I will regularly get 23mpg on my rural 2 lane 32 miles each way to work. None of its is flat. I'm going up a hill or down a hill or dodging a horse and buggy or stopping at one of the 15 red lights on my way to work. But highway at 70mph is 19-21mpg.
