02-11-2018, 09:38 PM
#16
Real Name: Chris
Real Name: Chris
Originally Posted by 96_StellarBP
Appreciate you doing this write up man, definently thinking to going this route in the near future.
Sent from my SM-N950U using Tapatalk
Yeah, there was definitely a lack of information on these things. I think you'll like them. They work pretty well for extra weight.
02-11-2018, 09:48 PM
#17
Thank you for the write-up. I'm debating between the bilstein 6112s and tundra 5100s w/ tundra coils. Though I'm leaning towards the 6112s there is something appealing about keeping as many toyota parts on the truck as possible.
02-20-2018, 05:17 PM
#18
Real Name: Chris
Real Name: Chris
So after driving the truck some more, I think the spring rate is a little higher than I would like. For someone who does high speed off roading frequently, or prefers a firm ride with enhanced handling, I think the 650 lb coil would be perfect. I however, drive around town and highway a lot, so I think a lighter spring may suit my needs better.
I talked briefly with a Bilstein Tech, as was to be expected, he couldn't give me recommendations on this setup due to liability and the fact that they haven't tested it (no one has). He did however confirm that the 1st gen Tundra 6112 uses a 650 lb spring, and the 3rd gen 4runner uses a 550 lb spring. A little more research showed that the 2nd gen Tundra Trd Pro uses a 600 lb spring.
Now, I'm not sure why they chose the 650 lb spring for the 1st gen Tundra that weighs less than the 2nd gen Tundra.
So with all of this information, I think I have decided to swap to a 16 x 3" 600 lb coil. We'll see how that goes.
03-30-2018, 11:20 AM
#19
Real Name: Max
Real Name: Max
So did you find the 600 lb. springs ?
If so what did you buy .
Max
03-30-2018, 11:05 PM
#20
Real Name: Chris
Real Name: Chris
Max
Good question! Yes I did, I bought them from Filthy Motorsports. They are King 16" x 600 lb. When I installed the new coils I pulled the top plate spacers and kept them on the 3rd and 4th perch. It settled to about 2.5" lift, and the ride is fantastic! It is soft and compliant but very controlled.
06-15-2018, 11:48 AM
#21
is it possible to run stockish ride height with the tundra 6112? my stock front shocks are destroyed and am gonna replace them with a shock that I can adjust later when I’m ready for a full lift.
06-17-2018, 03:01 PM
#22
Real Name: Lon
Real Name: Lon
Yes Ron, if you look at the pics 99 posted on the first page you can see the grooves or perch's on the 6112's. There are 8 of them and depending on what one you choose to place the lower spring mt on it raises or lowers the ride height. Second to the bottom or bottom grove should provide you with stock height.
All men dream: but not equally. Those who dream by night in the dusty recesses of their minds wake in the day to find that it was vanity: but the dreamers of the day are dangerous men, for they may act their dreams with open eyes, to make it possible.
T. E. Lawrence
08-12-2018, 07:56 PM
#23
Official Vendor
Official Vendor
Are the 6112 struts the same between the two? only the spring changes? or is there a stroke length difference also?
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
08-12-2018, 10:26 PM
#24
I'm doing a ton of research for my lift that I plan to do this winter, so this is very good info. One question that may possibly be dumb... Why did you install it at different notches for driver and passenger side?
08-13-2018, 12:53 AM
#25
Real Name: Chris
Real Name: Chris
So the Tundra one has significantly stiffer valving, and it also has a slightly shorter compressed length.
08-13-2018, 12:54 AM
#26
Real Name: Chris
Real Name: Chris
This was to make up for the extra weight on the drivers side with the fuel tank.
08-13-2018, 08:17 AM
#27
Official Vendor
Official Vendor
thanks, I'm having trouble finding comparison data between the two.
keith
eimkeith.com
08-14-2018, 05:07 AM
#28
Your post pushed me toward 6112’s but 4runner setup just wanna say thanks and also I thought the spring rate on the 4runner setup was at 600lb? Wheelers Offroad lists them as 600lb springs? https://wheelersoffroad.com/i-306325...tegory:1388356
00' Toyota 4runner Limited 4x4-Adventure/Camping Rig
17' Toyota Camry XSE- DD
98' Toyota Corolla- SOLD
87' Toyota Tercel- SOLD
08-26-2018, 04:21 PM
#29
It would be awesome if we could get the tundra shock with 600 lb springs. From that description on wheelers website it seems like that might be an option. I haven't done any calling around just yet, but I think that might be my next front end setup since I'm needing a bit stiffer valving and a bit more spring rate than my current setup. Especially when I finally add a winch to my setup.
If ya always do what ya always done, Ya always gonna get what ya always got.
01-05-2019, 08:50 PM
#30
@ 99 sr5 highlander
Since you replaced your springs with King springs maybe you would know; Would the Bilstein springs fit on a 2.5" coilover like King, Icon, etc?
