01-20-2020, 12:32 PM
#31
Originally Posted by eimkeith
Are the 6112 struts the same between the two? only the spring changes? or is there a stroke length difference also?
Originally Posted by 99 sr5 highlander
So the Tundra one has significantly stiffer valving, and it also has a slightly shorter compressed length.
Was this question & answer regarding the 6112 struts between the 3rd gen 4runner & 1st gen Tundra?
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
01-21-2020, 04:00 AM
#32
Real Name: Chris
Real Name: Chris
Yes, So the 1st gen Tundra has stiffer valving in the shocks then the 3rd Gen version.
01-21-2020, 09:29 AM
#33
Was the Tundra 6112 a direct fit or did you have to change the lower mounting bushing?
01-21-2020, 04:16 PM
#34
Real Name: Chris
Real Name: Chris
Tundra one is a direct fit using the stock bolt. The bottom mount is WAY beefier than the 4runner 5100.👍 Just use your stock top hat and the whole setup will bolt right in. Just have to decide what spring to run.
01-21-2020, 04:54 PM
#35
Real Name: Patrick
Real Name: Patrick
Do you use the 4Runner top hat rubber isolator as well or a Tundra top hat rubber isolator with the 4Runner top hat?
01-21-2020, 05:58 PM
#36
Real Name: Chris
Real Name: Chris
Yep, 4runner one works fine.
06-15-2020, 03:32 PM
#37
How do you like them now and what springs are you using with them trying to get something better to pair with some lc 9 wraps
11-21-2020, 12:42 PM
#38
Tundra 6112
Hey, love your posts. How are you finding 6112 now? I'm looking at tundra or 4runner set up. Will not be getting a bumper until I get a good deal but definitely would love one. Right now it will be stock for a bit. Suggestions ? Would you recommend tundra or 4runner 6112. Do you think you can still get 2 inch lift on the tundra 6112 with stock weight ?
02-25-2021, 02:54 PM
#39
Bumping this because I get tons of questions about my front suspension and unfortunately I went for the 4runner 6112s with a 650lb spring. Hindsight 2020 i shouldve went for the Tundra 6112s as I have full skids, plate bumper, winch, and could use the extra 1" of extended length over the 4runner 6112s.
'99 Millenium Silver SR5 | 5.29 Nitrogears/ARB lockers | 35s | Supercharged
Build Thread
02-25-2021, 07:05 PM
#40
i thought there was only very minimal difference in extended lengths between the two? I read somewhere that the Tundra version has an extended length of 18.35" vs the 18.27" extended length of the 4Runner version
02-25-2021, 11:05 PM
#41
There is a little bit less than 0.5" inch of shock travel which equates to 1" of wheel travel.
Build Thread
03-01-2021, 12:04 PM
#42
Real Name: Patrick
Real Name: Patrick
Tundra 6112 13.23-18.35 total-5.12
4Runner 6112 13.66-18.27 total-4.61
The difference is about an inch wheel travel from compressed to extended between the two
03-01-2021, 04:04 PM
#43
Real Name: @ NorthTahoeT4R
So really, even with stock weight on our 3rd gens, wouldn't we be better off going with tundra 6112's (600lb spring if possible) and running them at lower perches? This would give the most wheel travel and room to adjust for weight/ add stiffer springs if needed in the future
@ NorthTahoeT4R
03-03-2021, 01:07 PM
#44
not clear of what spring you can run with this setup - anyone have any links to 650lb or 700lb springs?..
1998 Desert Dune Toyota 4runner Limited 4x4 w/ factory e-locker
2000 BLACK Toyota 4runner Limited 4x4 w/ factory e-locker Build Thread
2002 Thundercloud Metalic Toyota 4runner Limited 4x4
Build Thread
03-03-2021, 05:22 PM
#45
Real Name: Patrick
Real Name: Patrick
The 4Runner 6112's come with 600 lb/in springs. Wheeler's has optional 650 lb/in or 700 lb/in springs BILSTEIN 6112 HEIGHT ADJUSTABLE FRONT SHOCK AND COIL PAIR FOR 1996-2002 4RUNNER (47-258624)
The Tundra 6112's come with 650 lb/in springs.
Any 14" spring designed for a 2.5" shock body will work as well.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
