Old 03-03-2021, 07:13 PM #46
Fiffa's Avatar
Fiffa Fiffa is offline
Fiffa will become famous soon enough Fiffa will become famous soon enough
Fiffa's Avatar
Originally Posted by infamousRNR View Post
not clear of what spring you can run with this setup - anyone have any links to 650lb or 700lb springs?..
EIBACH 14" COIL SPRING PAIR FOR 2.5" COILOVERS
WHEELER'S COIL SPRING PAIRS FOR 2.5" COILOVERS
ICON 13" X 650 LB COIL SPRING FOR 2.5" COILOVERS
Icon 14" x 700 LB Coil Spring for 2.5" Coilovers
'00 'Get Lost' Build
IG: get_lost_fiffa
Fiffa is offline   Reply With QuoteReply With Quote
Old 04-13-2021, 04:37 AM #47
SIN-Japan's Avatar
SIN-Japan SIN-Japan is offline
SIN-Japan is on a distinguished road
SIN-Japan's Avatar
Top plate question
Wheelers offers the 700lbs spring on the Tundra 6112 but they have to assemble it.
Will the Tundra top plate work for our 3gen 4runners? Or will if have to be disassembled and our plate added?
SIN-Japan is offline   Reply With QuoteReply With Quote
Old 04-13-2021, 05:18 AM #48
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
You have to use the 4Runner top plate as the Tundra top plate won't fit.
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 04-13-2021, 05:21 AM #49
SIN-Japan's Avatar
SIN-Japan's Avatar
Thanks, I’ll contact them and ask if that is possible or I’ll just add the extra items and do it myself.
Appreciate the quick reply.
BTW- I’m also running a Hilux Surf SSR-G
Old 04-15-2021, 02:26 PM #50
motorgroove motorgroove is offline
motorgroove is on a distinguished road
Originally Posted by Bad Luck View Post
Tundra 6112 13.23-18.35 total-5.12
4Runner 6112 13.66-18.27 total-4.61
The difference is about an inch wheel travel from compressed to extended between the two
Does Bilstein publish the compressed and extended lengths somewhere, or are these numbers from you directly measuring?
Thanks
motorgroove is offline   Reply With QuoteReply With Quote
Old 04-15-2021, 05:39 PM #51
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Thanks
Those numbers were gathered from a couple different offroad retail sites so I'm assuming it's information available to authorized retail sellers.
Old 03-31-2022, 02:48 PM #52
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice
Romeo1's Avatar
@wrench.n.wheel
Any updates or opinions on front suspension setup?
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
Romeo1 is offline   Reply With QuoteReply With Quote
Old 04-27-2022, 01:32 PM #53
wrench.n.wheel's Avatar
wrench.n.wheel wrench.n.wheel is offline
wrench.n.wheel will become famous soon enough wrench.n.wheel will become famous soon enough
Originally Posted by Romeo1 View Post
@wrench.n.wheel
I love the 6112s, but I plan to switch to Tundra 6112s as they are one inch longer and my SPC UCAs allow for that travel( though it will be limit strapped)
I need to get with @rickashay to buy his.
'99 Millenium Silver SR5 | 5.29 Nitrogears/ARB lockers | 35s | Supercharged
Build Thread
wrench.n.wheel is offline   Reply With QuoteReply With Quote
Old 05-01-2022, 09:51 PM #54
nfswift nfswift is offline
nfswift is on a distinguished road
I'm trying to figure out if 6112s can adjust to the same height as my old bilsteins, total lift height right now is unknown. Currently have SPC uppers, no BL, steel front bumper and winch, 891s and steel bumper/carrier out back.
In theory that's around 3" according to what 891s are rated for?
The thing is I bought it with 305s that didn't rub (1.5" wheel spacers), currently on 285s and just want to use my old wheels and tires!
Anybody know if the 6112 are a match for these ancient billys?
Tundra 6112 Bilstein On 3rd Gen. Info & Install-279158745_1395320264263976_8249289476198595568_n-jpg
nfswift is offline   Reply With QuoteReply With Quote
Old 05-01-2022, 10:53 PM #55
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
Setting on level garage floor my 6112's from bottom mounting bolt center to tophat mount measure 18.750" 2nd perch groove,
tried 3rd was higher than rear 890's. estimating 3rd perch setting had 19.250" give or take. Limited flair to hub center 22.5".
Have AOR plate bumper synthetic rope 9500 winch, 125# hanging off rear.
Old 05-02-2022, 01:41 AM #56
Are you also running 285/75/16s? I'm saving the 305 MTRs for some offroad focused trips. Clearance in the front has been perfect with the wheel spacers and OEM 16x7 trd wheels.
I measured 22.5 front and 23.5 rear to my limited flares, but I admit it didn't feel all that "precise". Very similar setup to your truck. Steel front bumper and winch/synthetic, steel rear bumper and full size on the carrier in the back with 891 coils. So it sounds like I need tundra 6112s, possibly with 600lb springs though, cheers.
Edit: too bad the tundra ones are all sold out, FML
Old 05-02-2022, 07:23 AM #57
Real Name: Mark
Real Name: Mark
Patagonia MT's 285/75 16 x 8 4.5 BS 0 offset rims. 23.5" rear height.
Old 05-02-2022, 10:27 PM #58
Real Name: Mark
Real Name: Mark
I tweaked on my Tundra 6112's for 1st time due to settling scrubbing every now n then.
Perch 3-4 to 5-6 too much preload rode worse too stiff. Back to 3-4.
3-4 perch added 3/8" tophat spacer gave me front rake shooting for level. Fix would be LC 8 wrap springs in rear.
Limit straps definitely needed jacked up front wheels at full droop would bind CV's.
Kept tophat spacer dropped to 2-3 perch I got to level enough lift no scrubbing I'm getting the better ride that
I was after from less preload along with lift I'm feeling more love for em atm.
Old 05-03-2022, 12:38 PM #59
The tundras set up properly (lower perches with spacer on top hat) seem like they could ride quite nice with the bumpers/winch setup. The 4runner 6112s on paper will just be able to clear 33s maxed out on a stock weight truck and will sacrifice your ride quality, maybe I'm wrong? Very close to pre ordering the tundra 6112s for this June.
Old 05-03-2022, 11:21 PM #60
Real Name: Mark
Real Name: Mark
Hit 200 mi on this setup today City to farm roads before and after I'm liking it more n more.
Before the ride @ 3-4 I could feel stiff suspension and 10 ply tires @ 38 psi.
Going with less preload got ride more supple road compliant like stock, all I feel now are the hard tires.
If I want more lift down the road I'll go back to 3-4 with tophat spacer know what the ride will be
and amount of lift, that worth knowing aye.
Bilstein 6112 In letzrace 5th gen T4Rs 177 04-03-2021 11:25 PM
Bilstein 5100 vs 6112 ClemsonYota 5th gen T4Rs 98 06-18-2019 06:19 PM
Bilstein 6112 vs Bilstein 5100 TotalAutomotiveLV General Discussions 1 06-02-2015 05:35 PM
Bilstein 6112 & OME 884 Pkniland 5th gen T4Rs 2 12-27-2014 07:27 PM
Tundra coil and 5100/5125 Bilstein info needed rdracer66 3rd gen T4Rs 21 10-18-2013 06:39 PM
