Originally Posted by motorchris
okay
The Chinese booster is still working good.
It came with a new check valve everything looks
Identical to the stock Toyota booster.
I did adjust out the nipple on the booster.
I still have some lag in the system but it is much
Much better... Thanks for info in the nipple I think that
Helped also.. The Chinese booster is okay two months later. While I do prefer oem parts a new booster from Toyota is 1000 bucks ...
Best Regards
Motor Chris
Glad to hear it. Once you've replaced the booster a couple times, it gets pretty easy. I can probably do it in under 20 minutes now.
Glad that the Chinese one worked. I got a Chinese eBay special for $60 that was bad out of the box. Better than my dead OEM one, but not by much. Still not driveable and I needed my truck back so I just bit the bullet and got a remanned one from Advance Auto.
FYI, they have pretty good coupons floating around regularly. 30% off, $40 off orders $100 or more, etc.
