01-22-2020, 09:27 PM
#91
Originally Posted by mesooohoppy
very rad build. i think that front bumper is the closest thing ive seen to what id like in a front bumper. minimalist, high clearance, not a bazillion lbs, blends with flairs, etc. (just without the hoop)
That’s what I was going for. Maybe some day I’ll make a few more and sell them...
1999 4Runner Limited - 5VZ, 4wd, Factory E-Locker, Multi-Mode, 5-speed swap, Armored, Icons, 295s ( thread)
2001 Tacoma Xtracab - 3RZ, 4wd, 5-speed (Daily Driver)
01-23-2020, 05:16 AM
#92
Originally Posted by APhelps
You got a copy of the wiring diagram for the cruise control? (post it up)
I have a hard time imagining the resistance of the wiring is causing an issue since you'd probably talking a fraction of an ohm and I doubt the cruise control is that sensitive.
Yeah here is the wiring:
I cut the wires at the park/neutral position connector which routed to the A/T, added a connector on top of the transmission below the shift boot, ran wire behind my center dash then under my steering wheel then over to the clutch release switch. There are 3 or 4 butt connectors added on each wire, plus all that additional length, and the connector added, I figured the reason it wasn’t working was because of the high resistance. I haven’t looked into it much though, I may have a bad connection somewhere, I’ve been too lazy to crawl under my truck or take apart the dash to try to figure out my problem.
02-05-2020, 11:13 PM
#93
Just got around to this but it would seem that your wiring is right. B-Y / W-R from the Park/Neutral switch to the clutch switch is right. Seems like it would be a bad connection if there's no other differences to be found between the AT / MT (or would be my guess).
A couple of feet of wiring and connectors should be less than an ohm of resistance, can't imagine the ECU is that sensitive to a resistance change.
02-06-2020, 04:02 PM
#94
Okay it must just be a bad connection somewhere. I'll have to do some testing. Not having cruise control is fine for now, but I'm planning a trip to Yellowstone this summer so driving there without cruise control is going to be terrible.
03-20-2020, 02:52 PM
#95
Got a new rear bumper!
It was made by Nguyen Works, and if you haven't heard of them before, go check out "nguyen_works" on Instagram. These are the most low profile, minimalist, and high clearance bumpers I've ever seen. I was going to make my own but honestly the way they make theirs is nearly identical to how I would make mine so it only made sense to just order one through them.
When I made my order, my requests were: - Lines up with the limited fender flares
- Works with the eimkeith fuel tank mount (which will be added soon)
- Swing-out on the driver side (for visibility reasons, and so when I parallel park and unload things from the back to the sidewalk the swing-out is not in the way).
The swing-out hasn't been installed yet, but will be soon when I get the eimkeith bracket welded on.
03-20-2020, 04:12 PM
#96
Real Name: Evan
Real Name: Evan
That look great! I randomly came across his rear bumpers on Instagram just this last week and I like it a lot! How much did that configuration set you back? I might be interested in one in the near future after I get my front skid subframe figured out and do my shorter Taco radiator swap that’s collecting dust in the garage.
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
03-20-2020, 04:32 PM
#97
according to a comment on their IG page, its 600 bucks. which isnt bad for a minimalist rear bumper. im curious how much more their dual swinggers cost. something like this is right up my alley, thank you for this OP, i appreacite it. it looks great on your rig
99 4runner limited; imperial jade mica
IG: mesooohoppy
03-20-2020, 05:18 PM
#98
Real Name: Evan
Real Name: Evan
I remember seeing a comment that it’s around $1k with swingout but wanted to hear firsthand what he paid since he has the single swingout too just not installed. The bumper alone is $600 I’m guessing...
03-20-2020, 05:53 PM
#99
I paid $1k for everything. When I ordered (which was two months ago), I was told $900 for a bumper with swing-out and an extra $100 to work with the eimkeith fuel tank bracket.
03-20-2020, 05:56 PM
#100
I want to say dual sing-out was $1300, but I could be wrong. They are making these out of their garage right now and demand has increased so they might be charging more now.
03-20-2020, 06:16 PM
#101
That look great!
And thanks, I really appreciate it!
03-22-2020, 07:22 PM
#102
The eimkeith fuel tank bracket has been welded on, thanks to other Jake
Everything is painted, and the swing-out has been added!
Now I need a full sized spare...
04-13-2020, 08:57 PM
#103
Fixed my cruise control on Saturday.
I honestly cannot tell you what was wrong with it. I tore apart the dash and the center console and did some continuity testing on the clutch release wires. I traced the wires back to where I spliced into the wiring harness on top of the transmission, and found continuity. A little confused, I decided to do a test drive with everything still torn apart, and suddenly the cruise control works! I'm not sure if it was just a loose wire that somehow decided to connect when I tore everything apart, or user error in operating the cruise control, but it works now.
I've tried it a few times since and it works just as it should in a 5-speed.
04-13-2020, 09:02 PM
#104
During my Sea of Cortes trip last year one of the roads knocked out my alignment and caused my front tires to toe out. I didn't realize this until I had gotten back to San Diego, and found the inside edge of both of my front tires were nearly bald. Shortly after I got an alignment and swapped them to the rear.
Now with the swing-out I needed a new wheel and tire. I decided to get two new tires on the rear and move the better of my bad tires to the spare and discard the other. I picked up a new wheel from VTX, got two new tires from Discount Tire, and got everything mounted. She's starting to look complete!
04-14-2020, 01:54 PM
#105
Real Name: C8H18 Mike
How stable/noisy is it driving around with the spare up high back there, does the spare rock around and make new knocks and noises?
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto -> 2WD 4runner Journal Thread
