Old 02-18-2018, 08:52 PM #1
dhphamqc dhphamqc is offline
dhphamqc is on a distinguished road
5 speed swap wiring issue
Okay, I got a 97 4runner 3.4 4x4 auto. I did the 5 speed swap and repinned my ecu to a 97 manual ecu. I jumped the park/neutral wire. When I did that, engine would crank and turn over but would not start. Repinned it back to auto ecu. Engine will start and turn on but die after 2 seconds. Showing these codes, aside from the shift codes. Any idea to look?
error_code_screen_1
error_code_screen_2
dhphamqc is offline   Reply With QuoteReply With Quote
Old 02-18-2018, 08:55 PM #2
Also need to add. When I was putting my start back on. Forgot I had power and touched metal somewhere and got a spark. Could that have possibly fried a wire?
Old 02-18-2018, 10:04 PM #3
St Runner's Avatar
St Runner St Runner is offline
St Runner will become famous soon enough
St Runner's Avatar
I would check the maf sensor connections first as both the codes and the way it starts both point in that direction. Also check the STA (B-W) and malfunction indicator lamp (V) as both of those wires, like the starting circuit run differently from the auto to manual. I used the engine wiring harness from the manual 4runner mostly because it would cut down on the amount of wiring mistake I could make
1997 SR5 4x4
R150f swap E-locked 4.30 gears
Tundra 231 brakes LC 80 rims 285/75/16
2001 SR5 4x4
St Runner is offline   Reply With QuoteReply With Quote
Old 02-19-2018, 03:33 AM #4
Paperjam's Avatar
Paperjam Paperjam is offline
Real Name: Alex
Paperjam is on a distinguished road
Paperjam's Avatar
Real Name: Alex
Considering you shorted something and you now have MAF and TPS codes I would check all of your fuses. You might have killed the reference voltages to both, which explains the start stall and no start. Transmission codes are there because all of the solenoids are gone.
I also agree that the re-pin route is messy, Also went the full manual harness and PCM route, Its plug and play and you wont have a CEL or hacked harness.
1998 T4R, 2.7 4wd/5spd swap build thread
Paperjam is offline   Reply With QuoteReply With Quote
Old 02-19-2018, 11:22 AM #5
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
Above is all good advice. Also check the engine ground by diagnostic plug (aka sensor ground) as a loose bolt there can do this.
My Backyard Frame Swap
99 LTD 5 Speed Swap PNWRunner 3rd gen T4Rs 53 12-14-2021 02:16 AM
5 speed swap, wiring question kolelt 3rd gen T4Rs 18 01-20-2018 01:18 PM
5 speed swap? WenatcheeSkier 3rd gen T4Rs 14 06-21-2017 04:17 PM
5 speed swap ? 808T4R 3rd gen T4Rs 1 06-08-2016 02:18 AM
'90 automatic to 5 speed swap wiring question Tim Wilson Classic T4Rs 0 10-03-2014 09:11 AM
