Originally Posted by Silver Supra
Guys,
I am going to replace my LBJ, inner and outer tie rods and thought it may be a good time to replace my control arm bushings while I am at it.
It doesn't look like they all are available from Toyota anymore so I was curious if there are any aftermarket options that are recommended?
Thanks!
These are the ones my company makes, they're a bit of a job to install, but worth it in my opinion. Just lube them up liberally when installing and you'll never have squeaks. The free floating, firmer polyurethane bushings maintain alignment far better than the bonded rubber OE bushings that twist and tear. Rubber deflects, arms can move around, polyurethane is stiff and keeps everything straight.
Front Control Arm Bushings for Toyota 4Runner 1996-02
http://www.energysuspensionparts.com...ion/8.3132.pdf
If you're not getting polyurethane, or at least OEM quality rubber, forget about it! Most aftermarket bushings use cheap quality rubber that won't last.
PS, got your PM, working up a reply!
