02-28-2018, 03:47 PM
grinding noise coming from rear passenger wheel
Hey folks,
My 98 has developed a weird noise. I got some Blizzaks put on, as I've been doing a lot of mountain pass driving. Tires are great, btw. Around the time I put them on, not sure if it's related or not, I started getting a weird noise seemingly from the front end. It's a borderline grinding noise, in a cycle that seems to perfectly match the rate of tire spin. Applying the brakes does not affect it, RPM's do not affect it. Only the speed of the vehicle itself. At first I thought it was tire noise, but it seems like that would be constant, and this sound is a cyclical pulsing noise that gets faster with faster vehicle speed. I took off the wheels and checked the brakes and pads, all appears well. If I spin the wheels while they are on the vehicle but off of the ground, I can't feel any grinding vibration through the wheel, other than normal brake pad noise. If I give the wheel a spin, it will spin about one rotation or so and then stop on it's own.
In what I hope is not a related problem, I also get a very noticeable constant vibration in 4x4 above 50 mph. 2wd, no prob. 4 hi, constant vibration above 50.
any ideas? Hoping I dont have a toasted transfer case or something. Wheel bearings maybe?
edit: it's actually the rear passenger.
02-28-2018, 05:25 PM
Real Name: Alex
Real Name: Alex
Just gonna throw out some ideas,
You mentioned taking off the wheels, I would ensure that the shield on the back of the rotor is not touching the rotor, happened to me a couple time and took me a little bit to figure it out.
I would also try some maintenance type stuff to narrow down the culprits.
Change front diff fluid, inspect cv axles, grease all zerk fittings, check for any issue in front drive shaft.
I learned early on to eliminate the simple stuff before tearing apart bigger stuff like the transfer case.
Hope this helps a little
03-01-2018, 12:18 PM
ok thanks. that's a start.
03-01-2018, 03:59 PM
There's a lot of good information in my thread below, at least in regards to what to check. I still haven't resolved my issue, having her towed to the dealership on Friday for further diagnostics.
What the CLUNK is going on with my 2000 4x4 SR5?
03-02-2018, 12:52 AM
good info, thanks. mine isn't a tick or a clunk, though. it's almost like a washing machine or dryer basket noise. it does unfortunately seem to be getting louder.
03-07-2018, 09:56 PM
well, I lifted up all 4 corners and spun the wheels, checked the brakes on each, looked for rubbing, etc. inspected the pads, etc. and it's none of that.
Had my fiancee drive it and I sat in the back with the seat down so I could hear it better, as I wasn't so sure it was coming from the front. Well, it's not. it's very clearly coming from the rear, and it sounds like it's coming from the passenger side. I inspected the drum brake and hub and nothing is rubbing, but something is definitely not right.
03-07-2018, 10:22 PM
I'm gonna go with wheel bearing, did you test for play in the wheel with the vehicle lifted off of the ground?
03-07-2018, 10:26 PM
that was my thought, too, but I don't know how to test for it. I didnt check for play, just for spin. I'll do that tomorrow.
03-08-2018, 12:34 AM
Grab the tire and try pulling it in and out. Also try pushing at the 12 oclock position while pulling at the 6 oclock position. See if there is any play.
If there is a small amount of play, that is fine. If you get significant movement, the bearing is shot.
Wouldn't hurt to check your rear diff fluid. You could drain it and put some fresh oil in it if it hasn't been changed in awhile anyway. Look at the bottom of oil catch pan and see if its clean or if it has metal in it.
I'd also check for play in your Ujoints.
Unfortunately, there is no way around trying to locate funny noises other than to keep checking stuff...
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
03-08-2018, 01:27 AM
Real Name: Just call me the Grease Monkey
Or strap yourself underneath it while your friend drives it down the road
My Snow and Sand build thread
Mark_BC's 2000 Limited Salvage Build
Determined to keep them from becoming parts trucks. Yes, even the one I just picked up as a parts truck...
03-08-2018, 10:45 AM
lol. I'll try that next ;)
03-08-2018, 10:55 AM
Try rolling down a hill in neutral and see if you are getting the noise. Before you do that, jack up each rear corner and hold the tire at 3 o'clock and 9 o'clock and shake it in and out as was suggested. Also try a 12 o'clock and 6 o'clock position.
03-08-2018, 11:21 AM
Check the drum/hub for oil, that would show if a seal is bad.
03-08-2018, 11:51 AM
official vendor
official vendor
No need to check the bearing. When the bearing starts to go the seals will start leaking as well. If you have oil leaking from the end of the axle tubes, and running down dust shield for the brake you found your problem.
03-09-2018, 11:19 AM
Picking my rig up from Toyota today, my odd noise ended up being a rear wheel bearing, and my seals didn't leak. I also had no noise when turning the wheel by hand on jack stands nor did I have any play in the wheel up/down or side/side.
Sent from my SM-G900V using Tapatalk
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
