03-03-2018, 02:07 PM
Power Antenna NOT going down
I've read that the power antenna's not going up, but mine is stuck in the Up position. Any thoughts or missed threads on this?
03-03-2018, 02:15 PM
Common issue. The spline portion most likely has broken. Or the mast itself has bent enough to jam. Either one is an easy fix or swap to a fixed antennae.
2001 4Runner 4WD Sport Package, Millennium silver, 110,000 miles, 2nd gen TRD Supercharger, Toytec BOSS coilovers, 890 OME rear springs, Bilstein 5125 rear shocks, custom Baldlands front bumper, PIAA 520 driving lights and fogs, 4x Innovation Sliders (welded on!), 18" Magnaflow muffler, JDM corners, 65" Thule bars, 20% tint, 16x8 FJ80 wheels on 265/75-16 Duratracs, Husky mats w/ cargo, rear diff breather mod, 3M clear bra, remote start, Pioneer AVIC-8200NEX
03-03-2018, 02:21 PM
Yes, usually this.
O.P., Do you hear / feel anything running? If so, yes, above^^^
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
03-03-2018, 02:25 PM
If you need a used motor/antenna, lemme know. I swapped over to a taco whip. PM me.
2001 Imperial Jade Gold Letter Sport Package - Original Owner
03-03-2018, 06:15 PM
I'm going to try to push it down and see if comes back up. If not I'll let you know! thanks
03-03-2018, 07:42 PM
I just pulled my motor. I rarely listen to the radio, as I listen to Pandora or my music library 99.9% of the time. I can just manually pull it up and push it down if need be. Like mentioned above though, the nylon gear on the antenna itself probably gave up the ghost on you. Very common problem.
2000 4Runner Limited 4x4, 3" OME lift, 2nd Gen TRD supercharger. 282,000 miles - SOLD
2010 Jeep SRT8, 7.2 Arrington 440 stroker, 550 whp! - FOR SALE
2007 Jeep Wrangler Sahara...too much to list!!
2015 Ford F-250 Platinum Powerstroke 4X4
03-03-2018, 08:03 PM
if it really is the motor and not the shaft then replacement is not that difficult except Toyota did not build the motor with a disconnect for the antenna wire to the radio. You have to thread it all the way over instead of just plugging in the exisitg wire. And I gave up on getting it back in the exact location - they ran the wire and then added ductwork so I took the easy way and ran it under the carpet near the toeboards.
05-26-2023, 01:33 AM
power antenna
I just joined but I can't post new thread. So can I jump on this post. On my 1996 4runnner I can hear the motor but the antenna won't move. What can I do?
thanks
jerryst
05-26-2023, 09:36 AM
thanks
jerryst
good chance it's tweaked slightly or something is caught inside it causing it to not move. Unfortunately this is a common problem with motorized antennas, you might be best off going with the taco whip mod.
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
05-26-2023, 12:53 PM
thanks
jerryst
Are you trying to use the antenna, or just sick of hearing it?
You can always just snip the wire and/or add a toggle to keep the mast down.
(I think it's the black wire w/red stripe)
If you have the diversity antenna in the rear glass, that
should receive enough signal for most purposes.
Build Etc...
If it ain't broke, fix it 'til it is.
05-26-2023, 02:20 PM
Real Name: N/A
Real Name: N/A
thanks
jerryst
Unscrew the silver ring at the base of the antenna, then turn the radio on, as the motor is operating to extend the antenna pull up on the antenna until it is completely out of the motor (this is the antenna mast). As you do this be sure to note which way the teeth on the mast face (either forward or backwards).
Get a replacement mast from Toyota (not too expensive should be $20), and do the process in reverse (except now you should turn the radio off so the motor is retracting the mast). Replacing the mast will often fix the problem.
There are other solutions like the tacowhip mod, unplugging the motor, or replacing the motor, but all are more involved and require removing the splash guard in the wheel well. If the mast doesn't fix it then you can consider those options.
1998 4runner 2.7 manual
05-26-2023, 03:44 PM
Remove it. Get this, or plug the hole. I don't know anyone who listens to radio anymore but if you do you're in the minority. Power Antenna Conversion Kit - Fits: 1996-2002 Toyota 4 Runner | eBay
99 4wd limited w/ E/locker
3" RC lift-loaded struts. Sonoran Drop diff and adjustable rear Panhard.
JBA Offroad UCA's, Pro comp Raven 16x8 wheels wrapped in 265/75/16 Gladiator Mt ,APOC INDUSTRIES Rear Trailing arms.
RETIRED USCG Aviation Mechanic/Hc130h Flight Engineer/HH65-A Flight Mech.
SEMPER PARATUS
05-26-2023, 04:31 PM
Real Name: Jon
Real Name: Jon
I have to remember this as I took the entire assembly out the last 2 times...
