Old 03-04-2018, 05:17 PM #1
HappyHooligan's Avatar
HappyHooligan HappyHooligan is offline
HappyHooligan is on a distinguished road
DAE Denim's 2000 Sport
So after looking for 5 months I finally found her. A 2000 SR5 Sport 4x4. 144K on the clock and no So Cal rust!
Here she is at the DMV in the Rain.
So far, just removed the wood grain veneer that was put on when they bought her new and painted the hub caps.
_________________
2000 Sport
2882/5100 906/5100
HappyHooligan is offline   Reply With QuoteReply With Quote
Old 03-05-2018, 02:58 PM #2
So the DMW doesn't do registrations on the weekend so I spent the weekend on the wheels, removing the wood trim and removing the running boards. Here's a pic back at the DMV on Monday Morning. I like it a lot better without the boards on it. I might do a small nerf or skid plate though. What do you think?
_________________
2000 Sport
2882/5100 906/5100
Old 03-05-2018, 07:30 PM #3
ConQueso's Avatar
ConQueso ConQueso is offline
Real Name: Jake
ConQueso is on a distinguished road
ConQueso's Avatar
Real Name: Jake
Clean. I also picked up a 2000 SR5 5-Spd Highlander. what process did you make to clean the center caps. I have the peel as well.
DAE Denim's 2000 Sport-mvimg_20180224_133807-jpg
ConQueso is offline   Reply With QuoteReply With Quote
Old 03-05-2018, 07:33 PM #4
really easy. just take them off, and clean them first with a de-greaser, then soap and water. I primed them with two coats and then put 3 coats of aluminum rustoleum paint. I was going to sand but figured it's not a show truck and I'll probably have to repaint in a few years anyway. Easy job.
_________________
2000 Sport
2882/5100 906/5100
Old 03-05-2018, 10:24 PM #5
ConQueso's Avatar
Real Name: Jake
ConQueso's Avatar
Real Name: Jake
Right on.
Yeah same thoughts on the show truck. Within my first week of ownership i climbed the finger of a mountain. no biggie
Old 03-06-2018, 09:35 AM #6
IBallEngineer's Avatar
IBallEngineer IBallEngineer is offline
IBallEngineer will become famous soon enough IBallEngineer will become famous soon enough
Well sanding has a purpose. Paint sticks to the surface not just because it's clean, but through either a chemical or mechanical bond. The fine scratches put in by the sandpaper give the paint something to bite on to. Like Spiderman climbing a skyscraper. Some paints have an etching device built in which helps form a chemical bond. Generally sanding is a better way to go, not just to smooth the surface, but for long lasting adhesion.
1989 FJ62 5.3 Chevy, FZJ80 Axles, 4.88's with ARB.
2000 2wd runner, 4 cylinders, yes it IS slow.
1999 4WD SR5 Desert Dune 3.4 351K and counting.
2000 4WD sport 3.4 Elocker <--My son's but I still end up paying.
2001 2WD SR5 3.4 <-- My daughter's...see preceding line.
IBallEngineer is offline   Reply With QuoteReply With Quote
Old 03-11-2018, 02:50 AM #7
Sometimes they seek each other out. Had to go for a drive in the rain tonight.
_________________
2000 Sport
2882/5100 906/5100
Old 03-17-2018, 03:58 PM #8
So after 2 days at the shop she now has a fresh timing belt, new radiator, valve cover gasket and plugs!
also put on front mud flaps. Kind of hard to see in the light.
_________________
2000 Sport
2882/5100 906/5100
Old 03-21-2018, 03:22 PM #9
amalik amalik is offline
amalik is on a distinguished road
Sanding paint confuses me. I thought it's for removing paint before re-painting, I think that's the scenario you're stating to OP here?
But then I've heard new cars often need wet sanding because of factory spray jobs that had defects. That part I don't understand.
amalik is offline   Reply With QuoteReply With Quote
Old 03-21-2018, 04:05 PM #10
Hepar's Avatar
Hepar Hepar is offline
Hepar is a jewel in the rough Hepar is a jewel in the rough Hepar is a jewel in the rough Hepar is a jewel in the rough
Hepar's Avatar
Paint when applied is not very even across the surface even if it looks it or feels like it. So, even if it's a brand new car, a good wet sand can really bring out the full potential of the paint job. Yes, you're removing a bit of paint, but just enough to get it down to a smooth surface.
Think of it like sanding down rough wood.
2001 4Runner 4WD Sport Package, Millennium silver, 110,000 miles, 2nd gen TRD Supercharger, Toytec BOSS coilovers, 890 OME rear springs, Bilstein 5125 rear shocks, custom Baldlands front bumper, PIAA 520 driving lights and fogs, 4x Innovation Sliders (welded on!), 18" Magnaflow muffler, JDM corners, 65" Thule bars, 20% tint, 16x8 FJ80 wheels on 265/75-16 Duratracs, Husky mats w/ cargo, rear diff breather mod, 3M clear bra, remote start, Pioneer AVIC-8200NEX
Hepar is offline   Reply With QuoteReply With Quote
Old 03-21-2018, 09:50 PM #11
Horsethief Horsethief is offline
Horsethief will become famous soon enough Horsethief will become famous soon enough
Congrats, looks like a great find!
I like the look so far, it definitely looks much better w/out the running boards.
Horsethief is offline   Reply With QuoteReply With Quote
Old 03-21-2018, 11:36 PM #12
What you need to understand is that sanding new car paint involves using very fine sandpaper, 1000-3000 grit, and then buffed to shine. This only removes minor imperfections in paint, it won't always save a poor paint job. Almost every high quality paint job gets "color sanded" then buffed.
Old 03-22-2018, 12:33 AM #13
RomanSchnobrich's Avatar
RomanSchnobrich RomanSchnobrich is offline
Real Name: Roman Schnobrich
RomanSchnobrich will become famous soon enough
That thing looks as clean as they come! My Minnesotan rig and I are super jealous. Stoked to see where you go with the build-- is it a daily driver?
RomanSchnobrich is offline   Reply With QuoteReply With Quote
Old 03-22-2018, 12:42 AM #14
Thanks! I searched forever for it. It's a daily driver, actually replacing the role previously played by the bronco behind it. I'm not going to go crazy on it, but it's going to be more a "rig" than a "truck" I love what everyone is doing with theirs and I want to take many of the mods and custom things others do and apply it to mine. I really love these 3rd gens! I also love early broncos too.
_________________
2000 Sport
2882/5100 906/5100
Old 03-26-2018, 02:01 PM #15
Today it got it's alignment. Much better. Not too much off but enough to notice. Western Tire Burbank.
IMG 7254
IMG 7253
_________________
2000 Sport
2882/5100 906/5100
42s 2000 Sport build 42s on u 3rd gen T4Rs 268 11-15-2017 06:35 PM
My 2000 sport. ski4runner 3rd gen T4Rs 39 04-05-2016 04:45 PM
should i trade my 2000 sr5 sport for a 03-06 v8 sport? BillIam 4th Gen T4Rs 7 07-05-2013 11:39 PM
New to Me 2000 Sport highcountry 3rd gen T4Rs 8 05-25-2012 12:42 AM
New T4R Owner 2000 SR5 Sport myT4RisGREEN New Members 2 09-11-2010 06:24 AM
