Originally posted by TAMPABOY
Good news...the problem is solved Thanks Rock Slide, I unplugged the DLR plug by the battery....problem is gone....DLR was making the HID's to flicker...dont know why, but they are working fine now....now I need to adjust the head lights, I noticed the passanger side one is a bit higher than the driver side one.....any suggestions on how to adjust them......
thanks again!!!
Glad to hear that solved your problem
There are 2 places to make adjustments on each headlight. Standing in front of your vehicle on the passenger side, one adjustment is located at the top right of the headlight. This adjustment moves the light up and down. Open your hood, and look at the top right of the passenger side headlight. Look specifically at the large piece of black plastic which mounts your headlight to the sheet metal frame. There will be a small hole at the top of this piece of plastic. Inside it contains a plastic disc with teeth that you can rotate with a flat head screwdriver. This will move the light up and down. (I don't have any pictures of this adjustment. Let me know if you can't find it and I'll snap a pic of it.)
The other adjustment is located at the bottom left of the headlight. To access it, open your hood, and look at the back of the headlight from inside the engine bay. You should find a large plastic nut screwed onto a metal rod. You can make your side to side adjustments here.
Once you know where to make adjustments, follow this website for proper headlight aiming:
Click Me
2002 4Runner Sport 4WD
Headlight Adjustment
"Live life w/o Limits. Your imagination is not limited by time or distance, by logic or by scarcity. You can fill your imagination with whatever you choose."
