03-09-2018, 11:55 AM
Limited flares on to SR5 fender?
I need a passenger fender for my black 97 limited. I've found a good black fender with an SR5 flare. Will my flare bolt right up to this fender? Most fenders I see are base with no Holes.
Sent from my Pixel 2 XL using Tapatalk
03-09-2018, 12:00 PM
No. The limiteds have the wider flares as well as the lower body cladding. The flares taper a bit where the cladding meets up with them.
2001 4Runner 4WD Sport Package, Millennium silver, 110,000 miles, 2nd gen TRD Supercharger, Toytec BOSS coilovers, 890 OME rear springs, Bilstein 5125 rear shocks, custom Baldlands front bumper, PIAA 520 driving lights and fogs, 4x Innovation Sliders (welded on!), 18" Magnaflow muffler, JDM corners, 65" Thule bars, 20% tint, 16x8 FJ80 wheels on 265/75-16 Duratracs, Husky mats w/ cargo, rear diff breather mod, 3M clear bra, remote start, Pioneer AVIC-8200NEX
03-09-2018, 12:35 PM
Real Name: Evan
Real Name: Evan
I think what he’s asking is if he buys the fender with the SR5 “skinny” flare, can he remove the SR5 flare and install his limited flare. Basically, is the fender itself capable of mounting the limited flare or if there are missing holes in the sheet metal that the limited flare needs to utilize to mount, etc. I personally haven’t looked at a limited flare in person so I am not sure.
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
03-09-2018, 12:54 PM
You are right. I definitely read that the wrong way.
03-09-2018, 01:06 PM
You'll need to make holes to accommodate the limited flares. Or, you can remove the tabs/clips on your limited flare and mount/glue it with clear silicone to the fender. The bottom side 10 mm bolts will bolt right on regardless of SR5 skinny flares or wide limited flares. I've used clear silicone to mount fender flares on a Hilux pickup and it is holding really well.
03-09-2018, 01:20 PM
Thank you, that's exactly what I wanted to know. Looks like I'll just have to spray a new fender.
03-09-2018, 01:47 PM
Depends.
What year SR5?
If it's a '00- or newer- SR5, the fender already has holes for the Limited flares...
03-09-2018, 02:52 PM
Originally Posted by Tyler James Inc
Depends.
What year SR5?
Not sure, it's this one:
03-09-2018, 03:02 PM
Those black flares have no holes up on the outside of the fender. They bolt on only inside the fender well.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
03-09-2018, 03:51 PM
Real Name: Just call me the Grease Monkey
The front Limited flares will bolt on a normal fender without holes drilled in the side. They bolt on underneath in the existing holes for the SR5 flares. You might need some double sided tape to keep the upper edge snug.
My Snow and Sand build thread
Mark_BC's 2000 Limited Salvage Build
Determined to keep them from becoming parts trucks. Yes, even the one I just picked up as a parts truck...
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
