08-11-2018, 03:26 PM
#136
Originally Posted by rkntoy
One more item off the Dusy prep list.
Sent from my SM-G930R4 using Tapatalk
Guess I know who's carrying my ice cream. lol
I just got 1 more shock to go and it's test time.
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. --Albert Einstein
08-12-2018, 11:13 PM
#137
Thanks
@ AssBurns
! Love the articulation. I may bring the wrenches to shorten the lower arms a bit to center the wheel when stuffed.
1999 Base model 4x4 3RZ 5 speed - added e-locker, front Aussie, dual cases with 4.7 front, manual hubs, Tundra/OME 861 springs, Shaved firewall (thanks Tyler James Inc), AssBurns rear links (run as 3 link),Limited interior w/ Mazda3 Grand Touring seats, Savage front and rear bumpers w/ winch, sliders, Thorley header w/ Magnaflow exhaust, SPC UCAs, 37s with 5.29 gears, roof rack and storage box, sport hood, BL and more. Linky
08-13-2018, 10:21 AM
#138
Real Name: Steven
Real Name: Steven
Lookin good! Not sure if you adjusted them from where I had them but I think I had them set for around 1/2” or so shorter than stock links for that very reason. Also shortening the lowers helps with pinion angle as well. Time to go beat those things up!
08-13-2018, 11:25 AM
#139
Not what I wanted to be doing today. Need to pack for Dusy...
08-13-2018, 11:48 AM
#140
Real Name: Steven
Real Name: Steven
So what’s the plan to get that out?
08-13-2018, 12:59 PM
#141
What the hell did you do?!
08-13-2018, 01:04 PM
#142
I did - made them a little longer. Now I will make them a little shorter.
08-13-2018, 01:06 PM
#143
Was playing around on one of the rock piles behind the house "testing" the rear suspension...picked too aggressive of a line backing up with my steering all the way to the driver stop.
Now I get to fix and then mad dash packing will ensue.
08-13-2018, 01:07 PM
#144
Steal my welder and slide hammer back from work and weld a bolt on to it. Going to be a little tight.
08-13-2018, 10:42 PM
#145
It is out. Ended up using aluminum can to shield the needle bearings.
08-13-2018, 11:06 PM
#146
It's kinda funny how where all fixing shit at the last minute. This trips gonna be a dusy. lol
I've gotten most shit packed up but I know I'm forgetting something. Any chance your bringing bailing wire? I've got plenty of zip ties and duct tape to go around but have no idea where my roll of bailing wire is.
08-13-2018, 11:08 PM
#147
That an OEM CV?
Thought: you could center drill out the inner shafts with a 1/16” hole. If it ever failed you could sneak a tool through it or tap it and put a bolt in.
08-13-2018, 11:09 PM
#148
Real Name: Throws like a girl
Curiosity...is that cv oe or aftermarket?
Also, good fix!
EDIT: Dang it Mr. JZiggy!
'96 4Runner SR5, assorted baubles and doodads. Stuff happened to it. Stuff is still happening to it. Okay, now the stuff is just getting ridiculous.
'99 4Runner SR5 Highlander, manual w/locker. Stuff is starting to happen to this one too...too much stuff! Too much stuff!!
http://www.yotatech.com/f200/habaner...thread-201751/
Originally Posted by PWD4R
I know this is a weird ass question but do you shave your legs or something?
08-13-2018, 11:44 PM
#149
Pretty sure Steve only runs OEM.
OMG, you broke it in your own backyard! That's too good 🤣
08-14-2018, 10:08 AM
#150
Sure thing. I need ice for my margaritas.
