04-05-2018, 09:34 PM
#16
Real Name: Scramble
Real Name: Scramble
Originally Posted by rallypoint_1
Sounds like Tim should make a vid on this!!!
On what? Kolelts hole reaming?
Originally Posted by mtbtim
You said exactly what I was thinking too. I know the application of heat to remove stubborn parts is pretty common and if it ended up causing failures we'd definitely hear about it.
Most of the time we're only trying to expand a nut to get it off a bolt or stud with mapp or propane. If we use oxy/acyl most likely we're cutting that part off & not re-using it.
____________
'99 4Runner - 2.7L 3RZ, 5 Speed, 4.56 Gears - Lifted, Locked & Loaded - 166k Original owner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
'99 Limited - E-Locker- Stock (for now) - 233k 2nd Owner http://www.toyota-4runner.org/3rd-ge...ted-build.html
04-05-2018, 09:40 PM
#17
Real Name: Bill
Real Name: Bill
Originally Posted by Scramble
On what? Kolelts hole reaming? :
Yikes!!
1998 T4R SR5 V6 2wd Evergreen Pearl OME 880 Toytec 1/4" spacer OME 906w/OME20mm(10mmx2)spacers Bilstein 5100 BFG KO2 31's Satoshi mod 1.5" BL(Fat Pats)
My 4Runner build:
http://www.toyota-4runner.org/3rd-ge...8-sr5-2wd.html
04-05-2018, 10:19 PM
#18
I’m not reaming any holes on my truck lol. At work. When you have a connection that a bull pin or barrel pin does not fix it. You next choice is a reamer.
97 3.4 JDM/5 Speed swap/eLocker Swap/ICON CDC all around/+more.....
04-05-2018, 10:28 PM
#19
Have used oxy/ace for over a decade with no problems to speak of, though I have always heard and used MAP wannabe gas on rusty O2 sensors and not oxy/ace due to the latter being able to contort the bung hole.
A gas ax is one lovely tool to own in one's arsenal though for
@ mtbtim
, the MAP kit would probably suffice for all his needs.
04-05-2018, 11:18 PM
#20
Real Name: Andy ಠ_ಠ
Real Name: Andy ಠ_ಠ
Thanks for all the responses. Sounds like to me it's fine to use some heat to remove parts as long as we aren't getting parts red hot and then rapidly cooling them (quenching) which will make the metal more brittle.
Your not getting it anywhere near hot enough to temper, anneal, normalize, Or harden it. Just think about how much heat goes into the steel when they weld it. The only reason I don’t like to heat things is because it tends to burn the paint off. You might in extreme cases put enough heat into it to case harden a very small part of it.
https://youtu.be/KFdFsfSAuyc
This is a fantastic trick, I have used it a bunch of times. On mufflers, a friend bet me $20 I could not get his 20 year old rusted exhaust bolts off. With this trick they came right off. It’s seriously like magic.
04-05-2018, 11:42 PM
#21
Real Name: Tim
Real Name: Tim
I need to try that trick out.
04-06-2018, 12:29 AM
#22
Real Name: Just call me the Grease Monkey
I think I took a metallurgy course once and from what I remember you have to heat it way up until it's pretty much red hot to change the crystalline structure of it which is what will affect strength. If you do get it that hot then it may make it weaker, but not more brittle. It would bend easier which means it would probably be less likely to catastrophically break. That's assuming the metal was hardened to begin with which I think would be unlikely.
My Snow and Sand build thread
Mark_BC's 2000 Limited Salvage Build
Determined to keep them from becoming parts trucks. Yes, even the one I just picked up as a parts truck...
04-06-2018, 08:17 AM
#23
Ditto
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
04-06-2018, 09:18 AM
#24
Have done this before a few times and I wouldn't say it's magic but definitely a tool in the box. Last time I did this I still had to use oxy-propane and a lot of it to get the nut off.
And to the original post- that was quite a bit of heating on the axle of an ATV, and that quad has seen plenty of use since with no issue.
1997 4Runner SR5 4X4 5MT elocker.
2005 Echo Hatchback 5MT.
1990 Volvo 740 Turbo sedan.
1991 Volvo 740 wagon.
2000 Mercedes E55 sedan.
04-06-2018, 09:22 AM
#25
Real Name: Robert');DROP TABLE Students;
This.
That's the wackiest shit I ever did see. I've got to change TREs on my 200k mile GMC this afternoon, I'm going to give that a try.
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
