04-05-2018, 05:24 PM
Cooling system flush, ridding of nasty green stuff
I’m planning to remove the green coolant from my engine and replace with Toyota coolant. Can I get some advice for flushing the old coolant all out so I can add new.
Thanks
04-05-2018, 05:39 PM
Real Name: Tim
Real Name: Tim
04-05-2018, 06:02 PM
Real Name: Jerod
Real Name: Jerod
I suggest filling it back in after the flush with Pink Long-Life fluid if you can, has a 50k mile change interval versus 30k with the red. They started making it after 3rd gens were out of production I believe, but it completely backwards compatible.
Both provide the same heating and coolant properties though.
04-05-2018, 06:17 PM
Backwards comparable with the over the counter green stuff?
04-05-2018, 06:43 PM
Real Name: Jerod
Real Name: Jerod
No, I meant with the Toyota engine and aluminum radiator & hoses. Neither red nor pink is compatible with green, or yellow, or orange coolants. Or blue Nissan coolant.
On a side note, why are there so many coolant colors? I'd like to have a long talk with car engineers on why their motor is so special that it gets it's own color coolant.
04-05-2018, 07:08 PM
The Pink coolant has a reduced drain interval if it has been mixed with other coolant types. The Red stuff is probably really what you want to use, though they are compatible (though not the same!).
I have always just done a drain and fill with distilled water, run for at least one full heat/cool cycle (or even a full week of driving, assuming it isn't below freezing) then fill up with Toyota Red. Since there will be some water left in the system, you want to mix it more than 50/50 to get the ratio back up - or run slightly lower than a 50/50 mix if you are ok with that.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
04-05-2018, 09:41 PM
Real Name: Instagram: briansd_97r
Is there something wrong with the green stuff in your 4Runner that makes it nasty? Such as chunks of crud or something?
Because a sh$t-ton of people run green without issue in their Toyotas. There are countless debates on the issue and debating it further is completely a waste of time but if you want to know more go read them.
With that said, so is their something special about the green in your particular 4Runner?
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giant’s robe, Upon a dwarfish treasonous thief.
04-05-2018, 10:00 PM
No nothing wrong, could stick with it, radiator was replaced by PO and that’s they used. Cold Level in expansion tank is low so figured maybe just switch it out.
Are the expansion tanks supposed to be full? I only ask as in the Audi’s I’ve owned in the past, the expansion tank is always full. But they are so difficult to bleed air from the system they have to be filled.
Thanks guys
04-05-2018, 11:11 PM
Real Name: Leon
Real Name: Leon
And Toyota specifically states that if you put the 50K Super Long Life Coolant (pink) into a car originally designed for only the 30K Long Life Coolant (red), you have to go by the car, not the coolant. So you can't/shouldn't extend the drain interval beyond 30K even if you do switch coolants.
From Toyota:
A new pink colored LLC is being phased into production for all 2002 Japan Built Toyota models. The color change does not affect the maintenance procedures or intervals established for the red coolant. The new pink coolant is 100% compatible with the current red coolant and red coolant can be used to replace, top off, or mix in with the pink coolant with no adverse effects.
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
04-05-2018, 11:21 PM
There's honestly nothing wrong with green if you change it.
04-06-2018, 02:21 AM
I'm assuming its aluminum safe green stuff
04-06-2018, 07:13 AM
Real Name: John
Real Name: John
All coolant is aluminium safe. Green stuff you just have to flush more often
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
04-06-2018, 07:44 AM
I won't get into the coolant color/type debate. Just know that each is formulated for compatability with the materials used in the block, head, and cooling system. And many are not compatable with each other. So if you're changing from one to another, be sure to flush completely.
Here's my shop trick for power flushing. A cheap brass garden hose nozzle fits heater hoses perfectly. Drain and capture all the coolant. Remove the heater return line and insert the garden hose nozzle into it -- use the hose clamp from the return line to secure the nozzle. Then turn the garden hose on full to back flush. Just let the discharge run out on the ground. It's so diluted at that point that that you don't need to capture it. Once the discharge is running clean, turn off the garden hose, remove the nozzel, and fit a funnel in its place. Run some distilled water through to flush out the tap water, then fill the system with your coolant of choice.
04-06-2018, 11:18 AM
Real Name: Tim
Real Name: Tim
That's what I understand as well. I've never had issues with the green coolant. I renew my coolant every 30k.
Now, did Toyota create their own coolant because they felt it was necessary for the health of their engines or did they see this as an opportunity to make money off all their Toyota customers by telling them they need to use Toyota coolant only. With all the Toyotas on the road, I would imagine they make a healthy profit alone just by selling their coolant to a majority of their customers.
04-06-2018, 11:35 AM
Real Name: Jerod
Real Name: Jerod
That's my grief with the green. It goes all rusty colored real fast if you don't change it quick enough. The only Toyotas I've owned with bad radiators had the green stuff in them previously and they were all scaled and corroded. Coincidence? Maybe, maybe not.
