09-29-2021, 08:15 AM
#46
Highest miles you've seen?
i saw one recently with 408k, think i've seen one before with mid 500 but i can't be certain
mine just hit 269k the other week
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
10-05-2021, 10:23 PM
#47
The real question, What would be the secret to hit those epic milestones?
10-06-2021, 12:29 AM
#48
It's a local 99. Stellar Blue Pearl 3.4 5 speed. Was around 560k earlier this spring. Should be seeing it within the next few weeks. Guessing it'll be 570k or so now.
Update: Came in last week, sitting right at 570K and still in amazing condition.
'97 3RZ 5 Speed "FrankenRunner" ( Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - ( Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
10-06-2021, 01:37 AM
#49
I’ll give you the “real” answer here. Most of these guys won’t tell you they did anything special, and they’d be telling the truth.
The #1 and overarching reason why you see so many Toyotas (and Lexus) with ungodly amounts of miles and staying on the road 20+ years is primarily that the manufacturer didn’t take any chances going long with their maintenance intervals. There’s no lifetime transmission fluids. There’s no 15,000-mile oil changes. So even if the typical consumer goes thousands of miles over their 5k oil change, it’s still not as bad as going 15,000 each and every time.
#2 Toyota kept the Germans out of their vehicles. In a time when ZF transmissions are finding their way into Italian (Alfa Romeo, FIAT), Japanese (Honda/Acura), and domestic vehicles (Ford, Chevrolet, Mopar) the warranty work on these brands’ transmissions has skyrocketed. I would trust an old Torqueflite 42RE before I’d trust a ZF 6HP.
#3 In order for a vehicle to reach 500k miles, (most of) it still has to be in one piece. Rustproofing or living in milder climates helps. I hear about northern states and snow (and salt) more frequently, but I’m curious if salt air is still a concern for rust in modern vehicles near the coast.
11-04-2021, 10:46 PM
#50
Great advice, I think rust proofing and the same driver is also important. I think a car gets used to the same style of driving as long as it's not abuse.
I am thinking about buying a 22 4runner as a daily driver. I have about 7 years and a little less than 200,000 miles to drive for my commute before I retire, then it will see only summer use and about 12,000 miles per year. I know they aren't great on gas but buying a $10,000 commuter car with twice the mpg really is only a break even proposition once insurance is considered. An extra $200/month in gas vs driving a great reliable vehicle like the 4runner.
11-04-2021, 11:25 PM
#51
I used to have to commute 100 to 115 miles a day from my old job. Then I drove another 300 -400 and 500 a few times while I was on shift usually. Was about 28-30k commute miles per year depending on how many extra shifts I picked up.
My reference point was a 1 ton diesel pick up that got 19 miles per gallon, and an old Subaru 2001 Forrester that got 25 to 26.
In my experience gas was always $.30-$.60 cheaper than diesel. When gas was around the three dollar mark, The per mile running cost of that Subaru was exactly half of that diesel pick up. We’re talking all the way down to the cost of tires. Literally every single penny accounted for.
That $3000 Subaru made me more money than anything ever. Best part was I sold it for 2700 several years later.
The take-home notes from my experience and others I know who commute are buying a new car to commute in is folly. You’re going to grind it into the ground. The amount of depreciation you take on it just kills anything that gets high Mileage quickly. You burn an insane amount of money to drive a body on frame vehicle as a commuter. The truck was going to cost $80 a month in tires alone. Those were for all-terrain tires that lasted 40- 50,000 miles….
I have now a company Rig and fuel card which is worth a pile of money, especially with four dollar fuel. But if I ever did have to go back to commuting, I would either get a used crosstrek, Impreza, a newer 2.0T WRX, a RAV4 hybrid, or a Prius AWD hybrid…..
I drove my truck the first six months and realized what insanity I was engaging in and bought a cheap commuter instead. Best financial move I ever made outside of not having hardly any debt and socking away money into a 401(k).
I would say destroy a beater or two The next seven years, and save the money for a new 4runner when you retire.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
11-05-2021, 12:58 PM
#52
Real Name: John
Real Name: John
2000 Limited
218K miles
Still smooth as butter! I hope to keep it until 300K+. Might just put a new engine in and keep truckin!
11-05-2021, 04:16 PM
#53
I am buying something to drive on my days off, either a 4Runner or a 22 Tundra. So the difference is the days on the road for work which will be 10 days per month for 7 years. The extra cost in fuel between the car I drive now and a 4runner for instance is approximately $140/month more for the runner. Just to insure what I drive now to commute in is $100/month so it get close quickly except for depreciation which won't matter if I keep the runner long into retirement. The extra mileage that my commute would put on the 4Runner would be about 110,000 miles. So I enter retirement with a 7 year old 4Runner with about 160,000 miles vs 50,000 miles if I ran my commuter car to work and kept the 4Runner for days off.
Then there is the depreciation on the car I have now. It's worth about $12,000 now and will be worth about $4000 if I keep commuting in it for 7 years. If the gas mileage breaks even after insurance, lic plate and inspection over the 7 years then I compare the $8000 loss on the commuter car to what 110,000 miles depreciates a 4Runner over 7 years. I'm guessing about $10,000, so I come out about $2000 to the good over 7 years driving 2 vehicles. Now if I can find a $3500 civic or corolla that would last 110,000 miles and save half on insurance the savings are greater.
Hopefully a 4Runner wit 160,000 miles in 7 years, mainly all highway or country roads would still last another 200,000 miles through retirement.
I'm hesitant to trust the new twin turbo Tundra though for that type of use even though it gets better mpg.
I'm in Canada so that was a lot of mileage conversion lol. My commute is on a 2 lane road going about 65 mph so no Cannonball Run type interstate commute. I welcome all suggestions. But I am drawn to the 22 4Runner for it's naturally aspirated simplicity and would love to try to make one last 25-30 years.
11-17-2021, 01:59 AM
#54
I have a 1997 4Runner 4wd and it’s at 345k and still running like an Energizer Bunny…keeps on running. We recently did a 500 mile off road trip to Death Valley and no problems off roading and traveling back to OC.
06-29-2022, 10:19 AM
#55
My 2002 SR5 Sport
400k
original motor and transmission
06-29-2022, 01:28 PM
#56
I'd like to answer how many others did lol
SEEN, 385k on a 97 Limited 4x4 out here in So Cal
my 96 SR5 4x4 is currently around 321k
08-24-2022, 01:38 AM
#58
I have a 2001 4Runner with 430k miles on it (original engine). Still driving it.
08-25-2022, 10:22 AM
#59
Real Name: Jon
Real Name: Jon
No head gasket change or leaking yet? That's great news as head gasket can sometimes go between 400k and 500k. Which is actually normal wear and tear. I forget how many revisions of head gaskets this engine has. It's due to the cast block and aluminum heads. Lots of movement there as they metals heat up at different rates.
08-26-2022, 09:50 AM
#60
That's insane. I really hope to get my rig to 400K. I'm at 317K right now and daily drive it. What major maintenance repairs have you done so far?
Sent from my SM-S908U using Tapatalk
