10-15-2020, 12:46 PM
#197
Originally Posted by brillo_76
The only issue with the filler relocation is the quality of the parts.
Very true. I spent nearly $200 in parts to do the one on my Camry (needed due to motor swap). Quality billet take-off plate, large AN fittings (-10 or -12AN), aeroquip push-lock hose, etc.
Even then, the hoses started to weep a bit after 10 years, and I'm in the middle of rebuilding that relocation (new hoses, changed routing a bit).
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
10-15-2020, 02:04 PM
#198
I would also seal with a quality anaerobic npt thread sealant for hydraulic lines. (Permatex 262?). also' AN fittings with graded lines would go a long way.
edit braided not grated.
10-15-2020, 07:31 PM
#199
Real Name: C8H18 Mike
Braided lines and AN fittings are overkill for a low pressure system like oil, but thread sealant is a must.
I may also RTV the block off plate to the block. Since it's not my DD anymore I have the luxury of letting the RTV fully cure.
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto -> 2WD 4runner Journal Thread
10-15-2020, 10:38 PM
#200
Real Name: Throws like a girl
That jogged a memory of a bracket I saw in a thread somewhere years ago- something like Toyota #15609-75030. Number's probably wrong but the one I saw didn't fit a 4Runner far as I know.
'96 4Runner SR5, assorted baubles and doodads. Stuff happened to it. Stuff is still happening to it. Okay, now the stuff is just getting ridiculous.
'99 4Runner SR5 Highlander, manual w/locker. Stuff is starting to happen to this one too...too much stuff! Too much stuff!!
http://www.yotatech.com/f200/habaner...thread-201751/
Originally Posted by PWD4R
I know this is a weird ass question but do you shave your legs or something?
10-15-2020, 10:43 PM
#201
Originally Posted by habanero
That jogged a memory of a bracket I saw in a thread somewhere years ago- something like Toyota #15609-75030. Number's probably wrong and it doesn't fit a 4Runner far as I know.
Oil filter subassembly bracket
10-25-2020, 09:26 AM
#202
304,142
Biennial smog test. Passed no problem.
01-08-2022, 11:57 AM
#204
Installed them with 2.5" long, 3/8 bolts and heavy washers. The holes in the rubber bumpers line right up with the holes in the ARB bumper.
10-15-2022, 12:50 PM
#205
Smog test passed with flying colors at 311,720 miles
12-27-2022, 11:30 AM
#206
Originally Posted by octanejunkie
In all honesty, I haven't seen a P0420 code since I replaced my throttle position sensor
Sent from my Pixel XL using Tapatalk
Mike, I know this post is years old and I haven't read much throughout the thread, but do you think this was just coincidence? I can't imagine the 420 code having anything to do with the TPS, right? It's just a cat code. I'm curious to hear your thoughts on this.
Sent from my SM-T220 using Tapatalk
12-27-2022, 09:28 PM
#207
Unless the TPS was a responsible for a vacuum leak that ran me lean I don't see logically how the two could be related...
02-06-2023, 09:31 AM
#208
Driving her to keep her spry and this happened
04-08-2023, 09:16 PM
#210
This saga has come to an end, I sold the 2WD yesterday. She is going on to become a tow vehicle for a food truck trailer.
Vaya con dios, mija
