Didnt make as much progress as i would have liked but i got somewhere at least...
• got the under headlight panels remounted, its weird i had to drill new holes as the original mounting is over an inch off... maybe i wasnt as close as i thought on my core support rebuild but it matches side to side and drilling a new hole was easy enough
• pulled the grille off and prepped/painted it but think i might get a spare and build something different eventually
• dont have pics but replaced all of the door speakers with new fosgates, didnt get new tweeters but realize now that i should.
• cleaned the hell out of all the dash pieces and redid the clock with one less layer of film so it shows up a little brighter now but still has a good red tone
• all of the dash is now red LED which looks awesome compared to the pale green.(dont mind the airbag and ABS, i have the airbag off currently and the ABS was grabbing randomly so i pulled the fuse until i have the time to diagnose)
• the ignition ring wasnt showing up as much as i'd have liked so i sanded the inside edge a little to disperse the light around the corner better. worked a little.
• While i was at it i went ahead and pulled the cluster apart and realized the PO had scratched the cover pretty good, so i polished it out and got it looking great again.
• Was well on my way to gettting these mounted when i realized i was out of argon and cannot find the metal pieces i kept to make some brackets so mounting them is for another day
