Old 08-03-2018, 11:44 AM #46
Joelzy's Avatar
Joelzy Joelzy is offline
Joelzy will become famous soon enough Joelzy will become famous soon enough
MY GARAGE
Joelzy's Avatar
MY GARAGE
Originally Posted by Lamer View Post
my hero, this looks so clean
Thanks, not as clean as i’d have liked but the hot tank only did so much for the aluminum and i wasn’t into scrubbing it a whole lot more with all the work left to be done.
Update: always something... got the oil pump on and realized my pickup tube was missing. Really frustrating considering i dont remember taking it off at all. So im chalking it up to “maybe the PO stole it for the swap explaining why neither oilpan was sealed”
So i’ll be pulling the sludge motor out and taking that back as well as the oil cooler which just has a blockoff plate currently and the new motor mounts.
The warehouse forgot to include the front seal, idler and roller pulleys when they pulled my order so i’ll be waiting on those as well.
Grand total is closer to 1650 now
96 SR5 4WD 5SPD Elocker "the Barnacle"
–02 bmw 540i6
–19 Highlander SE
Joelzy is offline   Reply With QuoteReply With Quote
Old 08-05-2018, 08:55 PM #47
Joelzy's Avatar
MY GARAGE
Joelzy's Avatar
MY GARAGE
Joelzy's 5VZ rebuild
This weekend was dumb.
Went to a PickNPull for headlight buckets, a better timing cover and potentially a driver front seat. No seat to be found but got the rest and went ahead and pulled an oil pickup.
Got to the shop and it didn’t fit with my pan. Wth, ok, must be a 2wd pickup. Mind you, i should have just researched it but i didnt.
Went home and pulled the sludge motor up just enough to get the pickup out. It matched the PNP pickup that didnt fit the pan. So finally i realized that the PO mustve swapped the pan and pickup onto the sludge motor as it was a 2wd before. So the good pan and pickup were on sludgey and the original motor had a 2wd pan and missing pickup.
Doesnt explain why the 2wd runner at PickNPull had a 4wd pan but im done guessing.
Went back out there this morning to grab a hitch w/a harness(that needed a breaker bar to remove) and decided to grab the pan while i was at it. Hitch with wiring was 12 bucks and the pan was 11 so it was worth the 50 mile trek 2 days in a row.
Thanks to this guy for all the parts and hardware for a very reasonable price. Probably be back once i get into vaccuum lines and whatnot
TLDR: 2wd and 4wd oil pans and pickups are very different. I know that now and realize the deep part is even on the opposite end of the pan. If you look at diagrams its pretty obvious but i never realized it as ive only looked at the sludge motor in the runner.
–02 bmw 540i6
–19 Highlander SE
Old 08-05-2018, 10:50 PM #48
swelleriffic's Avatar
swelleriffic swelleriffic is offline
swelleriffic is on a distinguished road
I didn't mean to "like" your misfortunate pick-n-pull weekend, but I just found this thread and your work looks awesome. I'm in E. Texas (Longview) and if I ever need a machine shop I know where to go! Great job so far.
1999 white SR5, highlander springs, CB/ham radios
2002 silver SR5 (sold 10/14)
swelleriffic is offline   Reply With QuoteReply With Quote
Old 08-06-2018, 09:47 AM #49
Joelzy's Avatar
MY GARAGE
Joelzy's Avatar
MY GARAGE
hahahaha thank you!
It was a pain and hot as hell but worked out and got a lot of good stuff for about 40 bucks so, now that its over, no complaints.
I highly recommend Dennis Wells, i drove down there more times than i should have and i know its a much much longer hike for you but it was well worth it for the work they did and the very reasonable price.
–02 bmw 540i6
–19 Highlander SE
Old 08-06-2018, 05:15 PM #50
phattyduck is a jewel in the rough phattyduck is a jewel in the rough phattyduck is a jewel in the rough
All 4Runners have "4WD" pans. PreRunner Tacos too. 5-lug Tacoma's only have the '2WD' pan (also T100's, but different story there).
'16 Honda Odyssey
Old 08-06-2018, 05:26 PM #51
Joelzy's Avatar
MY GARAGE
Joelzy's Avatar
MY GARAGE
Ok so i'm not crazy then, the swap must have just come from a taco and they swapped pans. Thank you for the clarification i thought i was losing it.
–02 bmw 540i6
–19 Highlander SE
Old 08-07-2018, 10:20 PM #52
Joelzy's Avatar
MY GARAGE
Joelzy's Avatar
MY GARAGE
Welcome to tonight’s episode of “Learn From my mistakes” with Joel the Toyota noob
Got the pickup and pan situated then flipped her over to start on timing
Got it completely ready for the belt before i realized something wasn’t quite right.
With this pin facing down, the marks on the cam gears face down when timed :|
Well thats not right... they should be facing straight up, 180 degrees from where they are, which would line up with the notch in the timing cover.
Update: ok so they weren’t in the wrong heads they were just upside down. The machine shop aligned the double dots when in order for the cam gears to line up TDC they needed to be aligned to the single dots.
Moral of the story: make sure your pins are facing upward when you put the cams in. If not, they are assbackerds
Got it all put back together and torqued with the single dots lined up and the pins upward.
Now officially timed
–02 bmw 540i6
–19 Highlander SE
Old 08-12-2018, 09:08 PM #53
Joelzy's Avatar
MY GARAGE
Joelzy's Avatar
MY GARAGE
Got it back together up to the plenum and VCs and brought it home yesterday!
Pretty exciting and also picked up this gem from a local on CL.
Love the analog incline and alt like this.
motor is around 1700 now, replacing all the sensors adds up but didn't want to have to do it later on some of the harder to get to parts.
–02 bmw 540i6
–19 Highlander SE
Old 08-12-2018, 11:22 PM #54
4Reak Show's Avatar
4Reak Show will become famous soon enough 4Reak Show will become famous soon enough
4Reak Show's Avatar
Dude. If you don't use those gauges lemme know. I call dibs on them for the right price. Killer addition.
Old 08-13-2018, 11:50 AM #55
Joelzy's Avatar
MY GARAGE
Joelzy's Avatar
MY GARAGE
will do but i gotta warn ya, i definitely think they'll be going in the 4runner.
the first time i saw them i knew i'd own a set. it was just a matter of waiting to find one.
–02 bmw 540i6
–19 Highlander SE
Old 08-13-2018, 12:36 PM #56
4Reak Show's Avatar
4Reak Show's Avatar
Yeah I hear you. I'm in the same boat. Tough to come by these days. Post up when you get them mounted! Very cool addition, if even for a novelty
Old 08-14-2018, 09:35 PM #57
Joelzy's Avatar
MY GARAGE
Joelzy's Avatar
MY GARAGE
Due to rain delays i can’t pull the old motor yet but i can start cleaning the heck out of this thing.
Seems to be seeping between the trans and transfer case so i’ll be splitting and resealing it once its degreased a bit.
Any suggestions on anything else i should look for? Had new oil in it that i just drained and the shifter bushing looks new.
PO bought a cheapo clutch that i’ll be throwing out for an OE as well as a throwout bearing
Also, this build is still pretty cheap and i'm considering a supercharger to change that. is it worth it? TRD, magnuson or which brand is preferred?
–02 bmw 540i6
–19 Highlander SE
Old 08-20-2018, 12:06 PM #58
Joelzy's Avatar
MY GARAGE
Joelzy's Avatar
MY GARAGE
Simple green wasn’t cutting it, purple power to the rescue.
Got most of the junk off this thing finally and though i didnt get a pic, i split the transfer case off and replaced those seals. Might still do the output shaft seals although they are new but homeboy used the cheapest stuff possible.
Hoping to pull the sludge motor out this week and continue cleaning and if all goes well, i’ll be able to install the clutch, mate the longblock to the trans and shove it all in this weekend. Might be wishful thinking but im not too far from it if im not missing throwout lever parts.
New OE clutch kit came in and the TO bearing has a clip with it which i am assuming is the only thing i need to hold the lever on it. Havent checked yet though.
Also ordered all the oil for the motor, trans, transfer case and diffs while i was at it... ouch grand total will be right around 2k once i order the radiator and lower hose.
–02 bmw 540i6
–19 Highlander SE
Old 08-21-2018, 09:05 PM #59
Joelzy's Avatar
MY GARAGE
Joelzy's Avatar
MY GARAGE
While waiting for some stuff to come in i decided to go ahead and check the front trans input shaft seal.
Had completely overlooked it while replacing the rest of the trans/transfer case seals but im glad i went back and pulled the plate to check it because it was the original seal and a good amount of it was stuck to the inside edge of the plate.
–02 bmw 540i6
–19 Highlander SE
Old 08-24-2018, 10:52 AM #60
Joelzy's Avatar
MY GARAGE
Joelzy's Avatar
MY GARAGE
Alrighty guys and gals, I yanked the sludge, attempted-swap motor out last night and I'm about ready to install the rebuilt motor, trans and transfer case.
You might tell me if I'm crazy here but this is the plan:
Bolt the motor and trans together, but leave the TC off for now. I'm taking off the core support and condenser anyhow to replace so i can hopefully swing the whole thing in the front without too much trouble assuming the hoist and load leveler do their jobs. Issue with this might be the hoist rolling smoothly with the extra weight but i won't know until i start.
worst case, i bail on that and rent a trans jack to put it in afterwards.
thoughts?
also, for anyone who has done this or similar, anything i need to watch out for or do first?
Found out the motor mounts are different between 2w and 4w so i swapped those and some accessory brackets from the sludge motor. Also made sure to pull off the oil cooler and i'll be resealing it onto the rebuild.
Are there any other things i need to do on the back of the motor before installing?
–02 bmw 540i6
–19 Highlander SE
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
